DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Mar 28, 2016 at 11:24 AM
    #181
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    Sounds like you may have overloaded the circuit when you added the additional switch. Don't be surprised if the problem continues and you continue to blow that fuse.
  2. Mar 28, 2016 at 11:32 AM
    #182
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    Agreed. Going to see if it holds up moving forward. If it doesnt, then I can just unplug the newly added switch and figure out another solution later. Not a big deal if it doesn't illuminate.
  3. Mar 28, 2016 at 11:37 AM
    #183
    abarber11
    abarber11 Well-Known Member
    ATX
    2011 DCSB
    holy shit this is clean
    tacozord[OP] likes this.
  4. Mar 29, 2016 at 3:36 PM
    #184
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Hi all.
    My local shop can get SXL wire for me. If I order 12 gauge for some accessories will I have any issues connecting to the RTMR or to the waterproof connector jackets? Early in this tutorial I saw that 10ga wire had to be TXL in order to fit in the waterproof connections. Maybe 12ga can be SXL.
    TIA
  5. Mar 29, 2016 at 7:05 PM
    #185
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    I used 12 ga with no issues.
  6. Mar 29, 2016 at 10:26 PM
    #186
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Is Waytek still considered a good source for the MetriPack stuff and GXL wire?
  7. Mar 29, 2016 at 11:31 PM
    #187
    kitsym
    kitsym Well-Known Member
    Portland, OR
    2015 4x4 MGM DCSB TRD Sport
    Yes. I ordered a bunch of items from them.
  8. Mar 30, 2016 at 12:22 PM
    #188
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I discovered a 6-way MetriPack 280 connector while searching for suppliers. The delcity.net website has them as well as GXL wire with no minimum quantities if that matters to anyone. Also free shipping over $99.
    Actually they only have the female end. The guy didn't know why they didn't have the male part.
    They do have a 7 wire connector though in male and female...
    rob1208 likes this.
  9. Mar 30, 2016 at 4:09 PM
    #189
    SMunch
    SMunch Member
    GB running? Info??
  10. Mar 30, 2016 at 4:38 PM
    #190
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Here is the group buy. Once I finish reading this thread I might drop out though and go the DIY route.
  11. Mar 30, 2016 at 4:40 PM
    #191
    SMunch
    SMunch Member
    alphabravo likes this.
  12. Mar 30, 2016 at 5:47 PM
    #192
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
  13. Mar 31, 2016 at 12:22 PM
    #193
    tacozord
    tacozord [OP] Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    Not every Metri-Pack connector has a mating in-line connector. This is because many are for specific purposes. Here's a quote from www.metripack.com on the FAQ page:
    alphabravo[QUOTED] likes this.
  14. Apr 1, 2016 at 6:43 PM
    #194
    cutty01
    cutty01 New Member
    Hi, 4Runner guy here and new to this forum but active on T4R.org.
    First of all - props to @tacozord. Likely one of the best how-tos I have ever seen! I have been busy reading and researching parts for the last week.
    I messed up and bought a pre-wired Bussman Box from eBay (bodoke0326) thinking I could save myself some time and parts for the central fuse box. Nothing wrong with the product I bought, however I didn't realize until it arrived that it uses a 15303-5-2-4 Bussmann box (one internal bus) where as tacozord uses the 5303-2-2-4 box (two internal buses). Also the wiring is done differently.
    Here is a picture of the one I bought from eBay. Notice how it has a number of black ground (I think) wires in the middle of the box going to a common ground battery lead. I believe the one bus terminal is wired to the positive battery cable.
    My question is that I want to wire the relay accessories, fuse-only accessories, and switch wires the same way as in tacozord's tutorial. I don't understand how the fuse-only bus vs. separate buses for fuse and relay work on the 5303-2-2-4 work; but is it just a matter of adding a blue sea 5 gang common mini buss but not connecting it to the terminal in the 15303-5-2-4 (since it doesn't have an extra terminal)?
    Apologize in advance for being wiring illiterate.
  15. Apr 3, 2016 at 6:16 PM
    #195
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Ebay one uses 8g wire for positive lead this chart shows 4g more appropriate , OP agrees in his build
    DrFunker and Sandman614 like this.
  16. Apr 3, 2016 at 6:33 PM
    #196
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    If you have 80amps and a 3ft cable then 6ga works with 3% drop.
    If you prefer 1% voltage drop then same requires 3ga.
    If you run RTMR to opposite side of the engine bay the length will be more like 6ft. For this you need 4ga at 3% drop and 1/0ga at 1% drop.
    I use a free spreadsheet I found online but this online calculator is also nice. Or this one.
  17. Apr 3, 2016 at 7:18 PM
    #197
    IronPeak
    AuggieX
    Back to Back
    Thus the eBay one is underwIred as 8g doesnt show up on chart til you get down to 40amps probably rare but I would like the ability to run several of the accessories at same time without worrying about the wire heating up
    Edit: no longer see the pre-wired bussmann 15303 on ebay
    Takeaway? Build the OP one (best) or buy the other one from sandman614 or yotamatic
  18. Apr 5, 2016 at 6:02 AM
    #198
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    ;) I found you some battery cables to use from Shok @manethon :hattip:
    https://www.tacomaworld.com/threads/who-said-wire-cant-be-big-enough-shoks-new-8-0.425033/
  19. Apr 5, 2016 at 1:47 PM
    #199
    Yotamac
    Yotamac Well-Known Member Vendor
    Ze
    562- Cerritos, CA
    07 PreRunner
    Stuff, stuff and more stuff
    We use 4ga welding cable (made in the US) on all our kits. Its extremely durable and has superior voltage/ amperage capacity. Our kits are in Baja race buggies and hold up well to the elements.
    http://www.tacomapros.com/battery-cable-set/
    Sandman614 likes this.
  20. Apr 5, 2016 at 2:17 PM
    #200
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Ordered RTMR and OTRATTW switches and @paranoid56 brackets today.
