DIY Aluminum bumpers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kiwijay, Sep 2, 2019.
  1. Sep 2, 2019 at 9:44 AM
    Kiwijay
    Kiwijay [OP] Member
    2015 Toyota Tacoma crew cab
    3” lift
    Hello all.
    I drive a 2015 4 door Tacoma and
    I’ve been getting my truck into rougher and rougher places over the last few hunting seasons (because it can) and I’ve finally decided it’s time to get into a winch front bumper and maybe tire carrier swing out rear bumper. I need them to be economical and made from aluminum as I carry a pretty full payload a lot of the time and weight is an issue.
    I have looked at many options and another taco buddy suggested Pilfrybilt but we all know that story. Pre fabricated units seem over priced so I’ve started looking for a decent DIY setup. I have access to a professional welding shop (and instructor) so this seems like a good way to go. Does anyone have any suggestions please?
    Must haves:
    Aluminum
    Strength
    Winch mount
    Fog lamp cutouts
    Would likes:
    LED light bar capable
    Headlight and grill loops
    Skid plate
    Thanks in advance for all your sagely advice.
    Cheers.
  2. Sep 2, 2019 at 9:48 AM
    4x4runner2002
    4x4runner2002 Well-Known Member
    Zach
    2002 4x4 limited
    suspension and armor
    whatstcp likes this.
  3. Sep 3, 2019 at 9:15 PM
    Kiwijay
    Kiwijay [OP] Member
    3” lift
    Thanks these look great but the $850 extra cost to change from steel to aluminum is a bit steep. Cheers.
  4. Sep 3, 2019 at 9:31 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Are you looking for CAD files to make your own (you intend to do all the welding and have the metal cut) or are you looking for a vendor that makes aluminum bumpers that you'll buy bare metal or powder coated and install yourself?
    Kiwijay[OP] likes this.
  5. Sep 4, 2019 at 7:55 AM
    Kiwijay
    Kiwijay [OP] Member
    3” lift
    Sticky taco,
    I could certainly work with the CAD files however a pre cut kit that I can weld myself would be ideal.
    Cheers.
  6. Sep 4, 2019 at 8:05 AM
    Kiwijay
    Kiwijay [OP] Member
    3” lift
    Whatstcp,
    I understand that aluminum is expensive as a base material but 135% price increase doesn’t make sense to me. I’m aware of the need for suspension upgrade and have that in the works but when you’re packing a weeks worth of cold weather equipment and food and a wee boat and a couple of other blokes, every lb counts so I’m trying to work out the best and cheapest route for optimum performance.
    Didn’t think of the battery upgrade for the winch though so thanks for the heads up there.
    I’ll shoot Coastal an email and see if they can work with me a bit.
    Cheers for all the advice. It’s a lot more complex than I thought.
  7. Sep 4, 2019 at 8:33 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Personally wouldn't trust a rear swingout bumper made of aluminum. I'm even hesitant on steel ones when one is asking to carry a 34"+ tire, fuel cans, ... then take it off road.
    whatstcp and Kiwijay[OP] like this.
  8. Sep 4, 2019 at 8:51 AM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    I want CAD Files......
  9. Sep 4, 2019 at 9:33 AM
    concentric_killa
    concentric_killa Well-Known Member
    2011 4x4 DBL Cab Taco
    +3.5 TC Long Travel DMZ Spring Under Nitro 4:56 Gears Custom Snorkel List Goes On..
    If you want strength, go with steel especally for housing a winch. Sure Aluminum is lighter but it has an elastic modulus that is 2/3 less than that of steel, meaning for the same strength as a steel counter part, you would need 2/3 more material. Also, the welded joints of aluminum are much weaker than that of steel. In order to regain strength of an aluminum joint that is welded, it needs to be heat treated.
    If you are concerned about weight, have you looked into stiffer suspension packages or even gears?
