Distance with Gas Light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NJTacomaOffRoad, Feb 7, 2020.
  1. Feb 7, 2020 at 4:17 PM
    NJTacomaOffRoad
    NJTacomaOffRoad [OP] Well-Known Member
    Franco
    2015 Tacoma Access Off Road Pyrite Mica
    Working On It
    I have a 2015, curious if anyone knows how far roughly (I know it depends on driving habits) you can go with the gas light on? How much fuel is left? 1 gallon, 1/2 gallon? Thanks.
  2. Feb 7, 2020 at 4:32 PM
    Colin The Shots
    Colin The Shots Well-Known Member
    Colin
    B.C.
    SR5
    I've done about 120 km after the light once when I kept forgetting to get gas after work (two 60km round trips) It was all highway driving.
  3. Feb 7, 2020 at 4:40 PM
    ImMrCrash
    ImMrCrash Intermittent Error
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Bilstein 5100’s Dakar CS047R Supreme Suspension U-Bolt flip kit Sumo Springs Blue ADV Fiberglass Fenders 1st Gen Snorkel DV8 Apex Plate Bumper X-Bull 13k Winch KC HiLiTES 6x9 Trail-Gear Sliders 4x Innovations LCA Skids Spidertrax 1.25” Eagle Alloy 16x8 4” BS Fierce Attitude M/T 315/75R16 Bearcat 980SSB CB
    I’ve seen some complaints every once in a while where someone’s gas light isn’t accurate.
    For me it has always been very consistent at 3.5 gallons left until empty
    NJTacomaOffRoad[OP] likes this.
  4. Feb 7, 2020 at 4:41 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Roughly 3 gallons
  5. Feb 7, 2020 at 4:45 PM
    mx07gt
    mx07gt Well-Known Member
    I've done 50 miles and the gauge right at the E for another 10 miles. Didn't want to push my luck after that.
  6. Feb 7, 2020 at 5:04 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    This is my experience as well. I get 17 to 18 mpg. I rarely let my gas get low enough for the light to come on.
    Safely, 30 to 40 miles.
  7. Feb 7, 2020 at 5:06 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Same here
  8. Feb 7, 2020 at 5:08 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    When the "reserve" light on my 2015 goes on, I probably have less than thirty highway miles range left. I've filled up with as much as 20.8 gallons (into a 21.1 gallon stated capacity) when the light has just come on. I've driven 15 miles or so after the light came on and put in 20+ gallons many times.
    So I figure there’s a gallon or less in my truck when the light comes on. I often fill before the light illuminates.
    Unlike some reserve lights that are pessimistic about range and come on too soon, my Tacoma's reserve alert needs to be heeded.
    Bleep100 and NJTacomaOffRoad[OP] like this.
  9. Feb 7, 2020 at 5:10 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I thought I'd seen that you have 1/8 of a tank when the light comes on.
  10. Feb 7, 2020 at 6:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’ve done about 40 miles.
    Don’t think I’ll be doing that any more.
    It’s not good for the fuel pump, not to mention reading a few post where people ran out of gas before the fuel light came on. Thankfully for them then problem was easily fixed. But it took some a good while to figure out they were simply out of fuel.
  11. Feb 7, 2020 at 6:27 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If you let the light come on you're doing it wrong. There are too many bad things that can happen by letting the truck get that low on fuel. I've never seen that light on my truck. One issue, among many, is that if you have to drive up a hill with low fuel in the tank all the fuel goes to the rear of the tank and cannot get picked up by the fuel pump. You may still have 3 gallons, but the truck won't run.
  12. Feb 7, 2020 at 6:28 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    I always figure another 30 miles is safe. Any more than that on a trip and I’ll stop for gas.
  13. Feb 7, 2020 at 7:30 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I guess I own a unicorn then since I drive up a hill everyday leaving the house. Lol. I've generally filled up 10-15 miles past the light going on. Most I've gone is ~19.5 gallons on the gas meter.
  14. Feb 7, 2020 at 7:35 PM
    2DaMtns
    2DaMtns Well-Known Member
    2011 TRD Sport DCLB in MGM
    Lift, tires, stuff
    I've driven literally thousands of miles with my gas light on and never had an issue. Just under 150k miles and I run every tank until the light comes on. I've put as much as 20.3 gallons in but it's usually 18.5-19.5 gal to fill it.
  15. Feb 7, 2020 at 8:58 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Ive known three separate people who were always on E and always pushing it on fumes, constantly, not the brightest folks as they actually thought it was cheaper to put in a few bucks at a time rather than top it off. Every single one of them ended up pumping sludge from their tanks through their injectors and having issues. They blamed the car of course and not the driver. One of them also had never gotten an oil change and when I found out me did it for them there was all kinds of gunk on the filler cap and I’ve never seen oil that black.
  16. Feb 7, 2020 at 9:14 PM
    Ten Rounder
    Ten Rounder Old Man and his Dog
    Southwest Montana
    20 TRD Offroad, 19 4Runner Premium SR5
    Heated seats, It's Montana
    Fuel pump sits IN the bottom of the tank for cooling like a BMW. The light will give you a 2 gallon margin after that all bet are off.
    I've cooked two Beamer pumps in the past and won't chance it in the Tacoma, you have to drop the tank for replacement
  17. Feb 7, 2020 at 9:15 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    About 3-4 gallons left when the light comes on. I fill about 17-18 gallons when it comes on. For me, I get 11-14 mpg so I approximate 40-50 miles. Your mileage may vary. I am lifted 3" with lt 285/75r16
  18. Feb 8, 2020 at 6:04 AM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    You know what your tank holds. 80ltrs. When the light comes on, get to the nearest station, fill it to first click off, don't over fill. 80ltrs - what you put in= reserve. Just my $.02CAD, eh?
  19. Feb 8, 2020 at 6:15 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    fuel is cheap compared to injectors & pumps
  20. Feb 8, 2020 at 7:52 AM
    tathambenjamin
    tathambenjamin Well-Known Member
    ben
    2008 4Runner SR5
    -2.5/1.5 spacer lift -270/65/17 Cooper AT3
    I have never understood the fear of running the pump too low. I’ve probably owned 20 vehicles, run several out of gas, run several low on gas. Never experienced any issues with the fuel pump or fuel system.
    when my light comes on I have pretty much 3gal left in the tank. I get between 13-18mpg depending on where/ how I’m driving.
