Disgusted with myself as nearly all brake lines are stripped
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yoyoboydoag, Apr 16, 2025.
  1. Apr 17, 2025 at 7:27 AM
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    They can get pretty tough to remove sometimes, you did the right thing getting a flare nut wrench, I stripped a couple before I learned that lesson lol. Maybe it was a poor quality one like said above, although I think mine is just some duralast from autozone. If I ever feel it start to strip I switch to vice grips if room allows and that usually works without too much damage if you get on it right. I may even just tighten it back up with a vice grip if I don't feel like replacing the whole line section. Penetrating fluid helpful as always and sometimes heat. If you ever know you're replacing the line just cut the line and hit it with an impact and a regular socket.
    po35042 and HondaGM like this.
  2. Apr 17, 2025 at 7:42 AM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    +1
    a400ryan[QUOTED] and HondaGM like this.
  3. Apr 17, 2025 at 12:07 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    cut, flare it and be done?
  4. Apr 17, 2025 at 6:39 PM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    [​IMG]At this point I would personally just cut the line close to the rounded off fitting and use a rounded nut extractor like the one pictured. Just be sure to hammer it on before turning.
  5. Apr 17, 2025 at 6:41 PM
    Homeline
    Homeline Well-Known Member
    2013 Access Cab 5-Lugger
    2" Leveling Kit, TRD skid plate, 16" Jeep wheels, Katzkin leather seats w/heaters, jump seat delete
    If using heat, apply it to the lower area the nut screws into. If applied mainly to nut, that's just expanding the nut, making it tighter.
    This may have already been mentioned, but tweaking nut a bit tighter first might overcome the seized portion.
    po35042 likes this.
  6. Apr 17, 2025 at 7:08 PM
    Waasheem
    Waasheem
    2007 xrunner
    I have a tiny pipe wrench I would use for this. It’s actually comically tiny, maybe 5” overall.
    Every once in a while I’ll come across a made in china hex head pipe plug that no tool fits good enough to loosen. That tiny pipe wrench gets it to loosen.
    Picture added for size comparison.
  7. Apr 17, 2025 at 7:11 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Not necessary, the brake fluid system is open to atmosphere through the reservoir.
    Brake fluid is designed to be pretty stable. If it was that prone to expansion when hot the reservoir would be bubbling over every time you drove to the grocery store
    Too Stroked likes this.
  8. Apr 17, 2025 at 7:35 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Vise grips. The flare nut is toast anyway.
    treyus30 likes this.
  9. Apr 17, 2025 at 9:36 PM
    EME
    EME Well-Known Member
    Nick
    05 Tacoma sport
    side note, before you actually crack the line, )once you over come the stripped issue) get a stick/bar/ broom handle and wedge it between the seat and brake pedal, to depress the brake pedal a couple inches, this will stop the fluid from draining the brake reservoir, which will save you from massive head aches when it runs dry and you have to bleed the abs. doing this stops virtually all fluid from leaking with the line removed. note disconnect the battery if your going to take a while to do the repair as the brake lites will be on.
    winkel likes this.
  10. Apr 18, 2025 at 1:42 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I work on dozens of brake lines a day from AMGs to grandma's 02 Camry. 10mm flare nut wrench on the brake line and on the opposing end you hold the other line with an open 17mm or whatever fits. Haven't stripped a brake line since 2006.
    In your case a brand nice large jawed Irwin vice grip.
    hinmo24t and EdgemanVA like this.
  11. Apr 18, 2025 at 7:42 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    I am restoring a MGA and needed to remove the brass temperature sensor from the head. Flare wrenches weren't working and did not want to round the brass too much. Bought a wrench to sacrifice, cut out a section of the closed end and welded on two nuts (one of which I drilled out the threads). Nice firm grip and got the job done.
    Naveronski, Max8, Littles and 9 others like this.
  12. Apr 18, 2025 at 7:44 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  13. Apr 18, 2025 at 7:45 AM
    Bishop84
    Bishop84 Well-Known Member
    I work on rusty brake lines as well and rarely use flare wrenches anymore.
    I heat up with a tiny butane torch, then vice grip it now. I have a fancy snap on flank drive that I use once its moving.
    Rounding brake lines is part of life on rusty cars, all you can do is learn from it. I've done far worse lol.
  14. Apr 18, 2025 at 7:49 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Thats tweaker'ish right there.....o_O:D
    Couldn't use a 3/8" or 1/2" drive deep socket in the appropriate size?
    or even a shallow...
    Never seen a temp sensor that I needed to go to this extreme...
    JAGCanada[QUOTED] likes this.
  15. Apr 18, 2025 at 8:01 AM
    #35
    JAGCanada
    Canada
    Car is a 1960 MGA. Temp sensor has a bulb that screws into the head and is filled with alcohol. Alcohol expands, moving temp gauge. Gauge in dash all the way to sensor in head is one part and can't be disconnect. I tried a 1/2" socket (modified with slot) and a hose clamp, but didn't do the job. 20250418_105206.jpg Resized_20240323_190307.jpg
  16. Apr 18, 2025 at 8:09 AM
    #36
    slater
    San Diego
    got it...:thumbsup:
  17. Apr 18, 2025 at 10:21 AM
    #37
    hinmo24t
    hinmo24t MAhole
    tom
    dartmouth, ma
    2015 TRD OR , blue ribbon metallic
    this thread will probably keep me away from brake lines until i absolutely have to
  18. Apr 18, 2025 at 10:54 AM
    #38
    Waasheem
    Waasheem
    2007 xrunner
    I’m diggin this. My tool box has lotsa stuff like that. Some ends up being a one time use, some are more useful.
    I’m guessing the correct tool would be a sensor socket. I bought this set & rarely ever use them.
    https://www.amazon.com/dp/B0012SCXHW
    Since 5/8 didn’t quite fit, it might be 15mm.
    https://shop.snapon.com/product/EMSM3815
    https://www.jbtools.com/lisle-line-...ukxXFIQo-RvJEfCc0IPDZBuhynJn0TNBoCn60QAvD_BwE
  19. Apr 18, 2025 at 11:29 AM
    #39
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I like making my own SSTs too.
    SST - Special Service Tool.
  20. Apr 18, 2025 at 7:49 PM
    #40
    winkel
    Corydon, IN
    Boy, that's the schnizzle, right there!
    I like it!
    Littles likes this.
