Discount Tire is making me MAD
Discussion in 'Wheels & Tires' started by bens06taco, Dec 8, 2018.
  1. Dec 10, 2018 at 7:15 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    these are the reasons I try to stay with OEM stock parts, using any aftermarket stuff always leaves the door open for more head aches and more money than originally thought to get it working right
  2. Dec 10, 2018 at 7:41 AM
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    I had a similar experience with Discount Tire. Always used them, they're great folks.
    I took my truck in to get new tires. Left with a TPMS light on. Brought it back and they said it was a dead battery in one of the sensors and it'd be $120 to replace it.
    It wasn't an issue before I took the truck in, so I asked what they might've done to damage the sensor and they said it wasn't damaged but they did do a calibration (or something they had to connect to the sensor to talk to it for some reason) and this sometimes drains a weak battery past it's critical voltage point.
    Since no other shop has ever unnecessarily connected to my TPMS sensors during a tire change (in any vehicle we've owned) I asked why they did it. They assured me it was them going the extra mile. I argued that their "extra mile" just put undue battery strain on my TPMS sensor and it'd be nice of them to replace it for free due to this unrequested check. They agreed and it's been fine for 6 months now.
    So, just an FYI...specifically request they DON'T connect to check the TPMS. If they do and kill your battery, it's my opinion that they're going to be held responsible as their actions created the issue, regardless of the TPMS being close to it's ~7 year battery life expectancy or not.
    bens06taco[OP] likes this.
  3. Dec 10, 2018 at 7:46 AM
    Muddinfun
    Muddinfun Well-Known Member
    There's no place on the sensor to connect to. They fed you a load of crap to try to cover their ass. Glad you called them out on it.
    JdevTac and bens06taco[OP] like this.
  4. Dec 10, 2018 at 7:48 AM
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    They connected wirelessly (probably just intercepted the signal the TPMS sends to the truck wirelessly). As I waited for them to fix it, I witness them doing it to other vehicles. It was a little handheld device about the size of a OBD II scanner that they held right up against the valve stems for a few seconds, then scanned through some info the device registered.
    tcjacado likes this.
  5. Dec 10, 2018 at 7:51 AM
    Muddinfun
    I find it doubtful that the sensors have 2 way communication, but I could be wrong. The thing that they held next to the wheel reads the sensor ID codes from the sensors.
  6. Dec 10, 2018 at 7:55 AM
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    I'd agree. Like I mentioned, I forget what their reasoning was or what they actually did, so I was just injecting the "calibration" as a possible scenario. I do know they read it in some fashion, not sure if that was just a poll on the unit to view battery life, status, record ID codes on each for the record, etc.
    Whatever the case; it taxed the units battery past a critical point so it must've been more power draw than the TPMS typically sees...or was coincidental in that it died right then and there. As far as I'm concerned though, it was an external influence on the TPMS sensor, outside it's normal operating conditions and it's what lead to battery expiration.
    bens06taco[OP] and Muddinfun like this.
  7. Dec 10, 2018 at 9:29 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yea keep holding it down through the blinks until it goes out, then release the button. You can do it engine running, engine off, doesn't matter as long as the ignition is on
  8. Dec 10, 2018 at 10:43 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    bens06tacko, sorry you are having trouble with your TPMS light coming on after installing new tires. I would recommend speaking to the local Store Manager to make sure they are diagnosing the problem correctly. The store cannot change batteries on sensors as they are sealed but they change the valve portion of the sensor any time a tire is dismounted to make sure there is not a problem with the valve stem leaking.
    It could be that your battery life has run its course as they normally last 7 to 10 years or 100,000 miles. If this is the case the store can use their Bartec scanner to find and diagnose the sensors.
    Muddinfun, jmanscotch and whatstcp like this.
  9. Dec 10, 2018 at 2:08 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    My 06 is at 146k and still has oem sensers, as for the reset hold button like they say and then give it a few days of driving.
    When I put my winter tires on stock rims on last month, I hit reset and it took a few days for the lite to go off.
  10. Dec 11, 2018 at 4:40 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Just bought new tire/wheel pkg from DTD over Black Friday
    NO TPMS sensors this time.....plain ole reliable $3 rubber stems......
    Buy a helluva good tire gauge for the $100 that the sensors cost !
    tacopolacko and Bebop like this.
  11. Dec 11, 2018 at 7:03 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    What are your plans for your TPMS light? TPMS pipe bomb?
  12. Dec 11, 2018 at 10:23 AM
    Discount Tire
    Arizona, USA
    We appreciate you posting a photo of your awesome looking tire and wheel package. Thanks for your support. :cool:
    Armed in Utah[QUOTED] likes this.
  13. Dec 11, 2018 at 3:07 PM
    Armed in Utah
    2003 Lexus LX 470
    Little furniture sticky pad.......works great !
  14. Dec 17, 2018 at 4:39 PM
    cramey74
    cramey74 Well-Known Member
    Stock for now
    I just had DTD mount/balance my Ray10s and Falkens. Tire pressure light has been on for a couple weeks now. Took it in today and they are replacing 3 of the four TPMS sensors. The truck only had approx 1000 miles when they were changed. Not sure what happened, but they are fixing the issue. That's really all I can ask for.
    Discount Tire likes this.
  15. Dec 17, 2018 at 4:47 PM
    #35
    T4RFTMFW
    T4RFTMFW Well-Known Member
    No TPMS in spare.
