Dirt King LOWER CONTROL ARMS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GladiatorNOT, Jan 28, 2021.
  1. Jan 28, 2021 at 3:55 PM
    GladiatorNOT
    GladiatorNOT [OP] Well-Known Member
    2017 TRD OR
    Old Man BP51 coilovers Dakar HD leaf springs Icon Delta control arms TRD Pro rims with Kenda Klever RT 33x10.5 tires Exhaust mod TRD front skid, RCI tranny and transfer case skids Southern Style Slimline front bumper Baja Designs S8 bumper light Warn Zeon Platinum 10s winch 4.88 Nitro gears ARB front locking differential ARB twin air compressor X2 Power 27 battery RCI rear bumper with Rigid SRQ lights RCI rock sliders RLD canopy Dometic CFX3 55 refrigerator TRD Pro grill Front & Rear anytime camera Seat Jackers Diode Dynamics Pro fogs
    Has anybody installed a set of these?
    JuanitoBonito likes this.
  2. Jan 28, 2021 at 4:01 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    @ClassyTacos has them. You might find some feedback from the group buy over :thumbsup:
  3. Jan 28, 2021 at 4:06 PM
    su.b.rat
    su.b.rat broken truck
  4. Jan 28, 2021 at 4:42 PM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Im super happy with mine. My ride did get noticeably stiffer in the front, which I like. Also, no issues with steering or the wheel coming back to center after a turn. I have read about those issues in the past.
    I have an install video on my channel if you want to watch it in order to see some detail on the arms and the process. You know, not from someone trying to sell them to you. I hate my voice on video so there's that to deal with.
    @su.brat did you notice any change in the front end? stiffer/softer turning and such.
    install vid--
    https://youtu.be/O7HDMkByNeI
  5. Jan 28, 2021 at 5:02 PM
    GladiatorNOT
    2017 TRD OR
    Thanks for the posting. This might be my next mod.
    Now when you say noticeably stiffer do you mean that in a good way or is it so stiff that it might be a little jarring when you don’t want it to be? I personally like a stiffer ride but don’t want it to be uncomfortably stiff. And by the way, didn’t find anything “odd” about your voice in the video LOL
  6. Jan 28, 2021 at 5:08 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Yes, I have them. I’m about to buy the boxed uppers off a member too.
    dirtdryver and Csoth7 like this.
  7. Jan 28, 2021 at 5:32 PM
    ClassyTacos
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I am a horrible judge of to stiff/ jarring as I like all my vehicles that way. Currently if I hit a quick dip in the road at highway speeds I would say it might be a tiny bit jarring. I also have the preload set pretty high on the coil-overs, so that has an effect also. Now a lot goes into that, tire psi, preload, shocks and so on, not just LCAs. Best way for me to describe it would be I fell the road more/ better connected. Overall it just got a bit stiffer in the front. For me it was good. I'm also betting if I lower the preload it will get softer.
  8. Jan 28, 2021 at 6:20 PM
    su.b.rat
    yeah quite a bit tighter with the front end. I'm reinforced upper & lower (spindle gussets, Marlin frame braces & TC double shear), and all together it's great and pretty strong. the LCAs helped pull it all together... i had all the bits installed but added the DKs last and can definitely feel the difference every drive.
    ClassyTacos[QUOTED] likes this.
  9. Jan 28, 2021 at 6:25 PM
    su.b.rat
    the LCA's bushings will firm up minor movements and you'll feel more of the road and tires, but it all depends on your total setup, tire rating, pressures, etc. if you believe you need or just want these LCAs then don't let the bushings put you off. you can [and probably should] put your effort into tuning/tweaking your front end: suspension, alignment, tires. then you'll get things dialed in to your liking.
    ClassyTacos likes this.
  10. Jan 28, 2021 at 7:03 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    I installed the Camburg lower control arms (with uniball pivots at the frame & spindle) and I didn't notice any difference in ride on, or off road. I'm not sure how much of a difference you will see by swapping out your lowers with either polyurethane or Delrin or even uniballs vs. the stock arms. Maybe your pivots are binding up causing resistance ? My uniball pivots moved with no effort (by hand cycling) after I torqued down all the bolts. So I wonder if something is "off" with your bushing or bolt sleeve if you feel the ride is stiffer. You should hear no squeaks and certainly should not feel any additional resistance from suspension pivots ! Like you said that is going to be mostly determined by your spring/shock setup, bump stops, and tire configuration.
    The other possibility is that your stock lower arms were so blow out and sloppy that by comparison the new lower arms feel "stiff". The lower arms should only go up and down in a prefect arch. The stock rubber has some play in it so it might permit wobble side to side which you got used to? In terms of pivot types , which limit loose wobble / play in the suspension it's like this:
    rubber < polyurethane < delrin <steel uniballs
    05 4x4 likes this.
  11. Jan 28, 2021 at 10:11 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Are they better than tc's?
  12. Jan 29, 2021 at 5:04 AM
    jeremy5000
    jeremy5000 Well-Known Member
    Philadelphia
    I'd argue they're better for a street driven vehicle due to the outer pivots being ball joints rather than uniball like the TC ones.
  13. Jan 29, 2021 at 7:07 AM
    helix66
    DPRC
    2017 DclB TRDor MgM
    I have no knowledge of these, why would that be true?
    I would have guessed that a ball joint is weaker in any application.
  14. Jan 29, 2021 at 7:09 AM
    jeremy5000
    Philadelphia
    Uniballs will just be noisier and require more maintenance. Just because race car/truck parts are stronger, doesn't make them better for the street. Ball joints are sort of set-it and forget-it and it's a big plus on a street driven vehicle.
  15. Jan 29, 2021 at 11:06 AM
    2000prerunner23
    steve
    True . However , I have been running heim and uniball suspension parts for decades on most of my trucks and I have zero issues with sound or wear. I do live in So Cal , we have a very dry nice climate . I also only do desert off roading (no mud or salts). I would say once every 2-4 years I swap out uniballs or heim joins. I think polyurethane squeaks way more in my experience and using that grease gun to lube them is very messy (excess can drip over time and just looks sloppy and cheap)
    In my personal experience I would only use dry , strong, precise suspension pivots (heim uniballs), but again I live in a clean dry climate and I service all things myself. Keep the balls clean and use a dry lube once in a while. Literally no issues for years thus far ...
    I will admit a lot of the reason I run them is off principal lol. It sickens me to know that a “pivot” is not pivoting like it is intended to. What kind of messy crap “flexes” in all directions under load? Seems so cheap and compromised. It’s obviously a little extreme and impractical but it’s the same reason people run steel breaded hoses and AN type fittings in their engine bay as opposed to the cheap ass Chinese rubber hose and barbed plastic crap . Every thing else just seems like a chop shop fix ....
    jeremy5000[QUOTED] likes this.
  16. Jan 29, 2021 at 11:10 AM
    jeremy5000
    Philadelphia
    If I lived somewhere that they didn't salt the absolute hell out of the roads in the winter, I would be much more inclined to run uniballs or heim joints. I run them on my track car, and even from sitting in the driveway they have gotten nasty from the home owners association coming around and salting.
  17. Jan 29, 2021 at 11:10 AM
    upTOPoverland
    upTOPoverland Well-Known Member
    Drew
    2019 Tacoma TRD OR
    upTOP All the Things!
    both of the upTOP trucks have the performance lowers and boxed uppers with heim. We love them, it's the best product we have purchased from other companies. Most noticeable difference of feel over all other mods and its the only thing that hasn't broken
  18. Jan 29, 2021 at 11:18 AM
    OrangeCrash
    OrangeCrash Well-Known Member
    Kingman, Az
    I'm switching from TCs to DK ball joints because of the noise and the feel. When you're parking or going slow it always feels like I'm low on power steering fluid. TCs are great but the noise really increased when I added the lowers and it just feels a little weird to me.
  19. Jan 29, 2021 at 11:19 AM
    RyanDCLB
    4/19 DCLBOR
    Man, I just ordered these A-arm skids, but I'm regretting not buying the DK's LCA's already...
    I know when I go in for round two of suspension mods, I'll be installing these LCA's (along with the DK double shear kit) :frusty:
    :ohsnap:
  20. Oct 13, 2021 at 10:08 AM
    Hunter399
    Hunter399 Well-Known Member
    2018 White Tacoma TRD Off-Road
    TRD Pro Grill, TRD Pro skid plate, tuff skins stickers, rekgen mudflaps, 33'' tires, 17'' wheels. Nitro 5.29 Gears. Bilstein 8112 front/8100 rears. Icon delta joint UCA’s and RXT leaf pack. Baja designs Fog, squadron ditch lights, and 30” S8 light bar.
    Anyone know of a place with these in stock? Pretty sure my stock lowers are blown out.
