Dirt Designs 05+ Taco 4WD RACE kit
Discussion in 'Long Travel Suspension' started by dirt designs, Jun 28, 2013.
  1. Jun 28, 2013 at 6:04 PM
    dirt designs
    dirt designs [OP] Well-Known Member
    slo
    01 Tacoma race truck
    Only factory parts left is cab and frame rails
    Well heres the latest suspension im going to build. 05+ 4wd tacoma race kit. 3.5 over arms, boxed upper arms, boxed lower arms, heim steering, and 4WD BOXED SPINDLES!!
    Thats right FINALLY someone has fully fabbed spindles for a 4wd tacoma. Kit should cycle 14" bolt in travel with inner fenders and stock coil buckets. With coil buckets removed and inner fender wells removed the kit should be able to pull 16" of working 4wd travel. Kit will be cycling on the truck next week so i will have real numbers then.
    I just finished designing the kit today
    05taco4wd4_zps9b1a8222_d564049c134b59fb94d1bef085b5d5e330a138b1.jpg[/URL]
    There is very minimum bumpsteer (though i should have it all worked out next week).
    05taco4wd3_zpsf1137c01_8bfe010c883ef245b69260874b7d1da9f1cf6062.jpg[/URL]
    05taco4wd2_zps20dddde5_c2ca9941ffc4fc225a20a3faac358c34561a81ff.jpg[/URL]
    05taco4wd1_zpsa6c41ebc_4efc7187b56b79dfb92f0c4985af7a8c813bf9d4.jpg[/URL]
  2. Jun 29, 2013 at 5:41 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Is the spindle going to compatible with stock / regular LT applications? I can't see the pics so I don't know how you have the heims set up.
    Price point on the spindle?
  3. Jun 29, 2013 at 5:51 AM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Subbed
  4. Jun 29, 2013 at 8:11 AM
    dirt designs
    slo
    This spindle is specific for this kit. The reason being that the other lt kits on the market all use a single shear bolt on the lower and upper control arms. While i can double shear the upper arm bolts, theres no way to double shear the lower with how they have it arranged. With this kit i didnt want to just copy what everyone else was building and i wanted to make it the strongest setup i possibly could. The spindles on this kit use a double sheared upper and lower bolts for the uniballs making the joints a whole lot stronger.
    If I build spindles to work with other LT kits the price will most likely be around $1200-1300 a pair. If there are 5 people that want the spindles I can start designing asap. And yes, they will be beefy.
    The_Black_Pearl likes this.
  5. Jun 29, 2013 at 6:42 PM
    Ghost848
    Tony
    Alberta,Canada
    If u design these for stock application that would be bad ass too.... ;)
    Biscuits, jeff b and 12TRDTacoma like this.
  6. Jun 29, 2013 at 11:51 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    proprietary axles?
  7. Jun 30, 2013 at 12:10 AM
    Greytacoma1
    Greytacoma1 Senior Member
    dave
    Sacramento ca
    Tacoma dc lb
    Satoshi grill, Plasti derp, Ready lift kit, Wheelers 2 inch aal, Hella 700, Wheather tech floor mats, Blueinstinct armrest cover, sockmonkey bed decal, BHLM, debadge, 35% tint front windows, OEM roof rack, OEM step bar, TRD skid plate, tacomaworld.com decal, stock antenna trimed, gorilla extended lug nuts,diff breather mod, cab mount chop, AVS window visor, spidertrax 1.25 wheel spacers, toytec sway bar relocate, extra d ring mod
  8. Jun 30, 2013 at 12:22 AM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    Sub'd
  9. Jul 1, 2013 at 12:25 PM
    dirt designs
    slo
    nope, just 3.5 over axles. We got this set from tc
  10. Jul 1, 2013 at 12:27 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    hmmmm sub'd
  11. Jul 1, 2013 at 12:59 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Interested to see how this works on Joel's truck
  12. Jul 1, 2013 at 8:28 PM
    6spd
    san diego
    2023 4x4
    :cool:
  13. Jul 1, 2013 at 9:18 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
  14. Jul 2, 2013 at 8:39 PM
    dirt designs
    slo
    One side of arms and spindles are all ready to cycle. I will have some good pics tomorrow
    ChadsPride likes this.
  15. Jul 2, 2013 at 8:45 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Subbed.
    Will the spindles increase the track width or will the length be determined by the arms alone
  16. Jul 2, 2013 at 8:46 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
  17. Jul 2, 2013 at 8:47 PM
    Osugoose
    Osugoose Well-Known Member
    Sean
    Tulsa, OK
    2011 Sport DCLB 4x4
    885x w/ nitro sports,Dakars w/ 182,Katskinz two tone leather
    subbed, I'm interested to see how the shear joints hold up, what are your sizes for the joints?
  18. Jul 2, 2013 at 8:48 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    im keeping a very close eye on this
  19. Jul 2, 2013 at 8:48 PM
    Monster Coma
    Corey
    any Idea on price yet?
  20. Jul 2, 2013 at 8:51 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Subd for final product and testing.
