Dirt Bike trailer hitch carrier
Discussion in '1st Gen. Tacomas (1995-2004)' started by milehighliving, Jul 8, 2012.
  1. Jul 8, 2012 at 9:01 PM
    milehighliving
    milehighliving [OP] Well-Known Member
    Colorado
    03 Silver Xtra Cab 4x4
    2nd Gen SC, Addicted Front Bumper, Allpro rear bumper, OME Full suspension lift, LR UCAs, Extended brake lines, Goodyear Wrangler Duratrac 285/75/r16 with level 8 wheels.
    I've been looking into ways I can haul mine and my buddies dirt bikes on my tacoma. I have a shell and don't want to take it off in order to do this. I think I'm left with 2 options;
    1) tow a trailer - I'd rather not to because I have limited space to park trailer, and I can only travel 55mph legally.
    2) trailer hitch carrier - http://www.discountramps.com/double-motorcycle-carrier.htm
    I'm planning to lift my truck in the very near future, with that in mind with option 2, what would be my best option? I've done a fair amount of research, I was originally planning on an OME lift kit, but thought maybe someone who's done this could chime in.
    Thanks
  2. Jul 8, 2012 at 9:03 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    2 bikes on a single hitch carrier will exceed the tongue weight on the factory... and any aftermarket hitch that I'm aware of.
    I seriously don't know why they make those things for dual bikes and quads. The lever moment of the 2nd rail is too far away from the hitch and multiplies the weight to far above the design limits.
    One bike? You're okay but heavy.
    Two bikes? Get a proper trailer.
  3. Jul 8, 2012 at 9:12 PM
    dfrugia
    dfrugia Well-Known Member
    Goose
    Roswell, NM
    2012 DC TRD OFF RD 4X4
    Running boards w/steps, Weathertechs
    I wouldn't do that at all. Large risk of something very bad happening.
  4. Jul 8, 2012 at 9:19 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ya... couple of 50s or 80s for the kids or puttering around camp, maybe, but a 125 or larger is pushing 250 pounds wet (over 250 for models with e-start and lights).
    Just the two bikes blows tongue weight without factoring in the angle.
    Single bike? Ya... I see that all the time and even built my own.
  5. Jul 8, 2012 at 9:23 PM
    dfrugia
    Goose
    Roswell, NM
    Even with a single bike, if you hit a large bump that alone could break something.
  6. Jul 8, 2012 at 9:54 PM
    whereismymind
    whereismymind Well-Known Member
    Don
    Broomfield, CO
    2012 Tacoma SR5 MGM D-cab
    Toytec Ultimate lift,Spidertrax spacers,Light Racing Control Arms,285/75/16 Duratrac's
    I had that same double hitch mount one when I had my FJ Cruiser. With my wife's TTR125 and my 250 it was just under 500lbs. Most of the time I had one of the rails removed and only hauled my bike with it. Like others are saying it would be way too much weight to haul 2 full size bikes with it.
    If you do get one use ratchet straps and remember to strap the rear tire down. I would by that same model again. It was very well made. Got mine off of an eBay store I think for $180.
    OME is designed to handle heavier weight, but I would look into an airbag system. That might help keep from wearing out your suspension as fast.
    Next I bought one of the Harbor Freight fold up trailers. That way it could still be stored in my garage.
  7. Jul 8, 2012 at 10:00 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    trailer...
  8. Jul 8, 2012 at 10:15 PM
    milehighliving
    Colorado
    I hear you guys out on the tongue weight factor on a stock hitch (class II i believe), I just sold my hitch to install my All-Pro rear bumper and was looking at Class III trailer hitches (500lb. tongue weight limit). Bikes weigh about 253 lbs. each so that + the carrier would exceed tongue weight. Guess I'm going with a trailer.
    I've seen a few people rig up they're trailers for hauling gear and stuff off-roading, Might have to look into that more.
    Thanks guys
  9. Jul 9, 2012 at 5:46 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    And even if the bikes were only 150lbs each, you still have the lever moment.
    150lbs==150lbs==[RCV]
    Does not equal
    300lbs==[RCV]
    And depending on how long "==" is, even
    300lbs==[RCV]
    Just might exceed
    500lbs
    [RCV]
    Which is what the hitch was designed for.
  10. Jul 10, 2012 at 7:21 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I also have a H/F fold up ( 4:80 X 8 Wheels ) that I would like to use in case of an emergency to haul my bike which I figure weights 700lbs loaded with fuel and stuff, but feel that the trailer is to flimsy ( it flexes to much ) then there's the task of actually getting the bike on the trailer, as the approach is steep.
    I like your set up if it works for you.
  11. Jul 10, 2012 at 7:40 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Use a ramp to load the bikes... Any way you look at it, loading a bike on to a low trailer like that with open sides is a LOT easier than getting into the bed of a truck.
  12. Jul 11, 2012 at 2:06 AM
    whereismymind
    Don
    Broomfield, CO
    I used a ramp which is hanging off the back in the picture. After adding some bolts to the tongue of trailer the ramp was mounted with 2 wing nuts. The HF trailer does flex. To help correct it I used bolts instead of the hitch pins were the tongue would fold. I also bolted that long grey steel bar across the front. It provided tie down points that were more spread out and cut the flex way down. It actually towed really well.
  13. Jul 11, 2012 at 2:27 AM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    Go with the harbor freight fold up trailer if your worried about space, they are nice for what you want. Or rig up a sickass offroad trailer, it will just take up more room.
    I built my own trailer when I was a sophomore in highschool, all by myself.
    It's dirty in this pic, had been sitting a year or so outside.
  14. Jul 11, 2012 at 6:52 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    The trailer needs to tilt for loading, using a ramp with my bike will high center, on the bed of the trailer, before the rear wheel gets on the trailer. A ramp is fine for a dirt bike they sit a lot higher.
