Dimmer Wire tap on 3rd gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ekimerpud, Mar 10, 2016.
  1. Feb 23, 2020 at 1:54 PM
    IntrepidTraveler
    IntrepidTraveler Well-Known Member
    Irv
    Aiken SC/ Carlsbad NM
    2020 TRD Pro Army Green
    So, do I have this correct? See below....
  2. Feb 23, 2020 at 2:56 PM
    IntrepidTraveler
    Irv
    Edit to add... close but no cigar. So I still need assistance.
    I have it hooked up the way I have shown, from my understanding of other posts. I checked last night when it was dark and they didn't light. But when I drove it today when it was light, they were lit, although the other switches weren't. When I turned the lights on, the other switches lit up, and these went dark.
    Also, there's another post on the forum where a member is making "daisy chain" in-line cables, so you don't have to cut factory wiring. I wish I had seen that post before I went at the wiring with my cutters. I still did a good job, but I did have to cut the wiring.
  3. Mar 28, 2020 at 2:26 PM
    remgu2000
    remgu2000 Keepin' on keepin' on.
    Ray
    Roswell, GA
    Used to have a 2017 Barcelona Red TRD Off-Road DCSB 4x4
    Howdy...did you ever figure it out? Just wired a CH4x4 switch for my LEDs and can't find the cable to connect the "Red2" wire.
  4. Mar 28, 2020 at 2:48 PM
    remgu2000
    Ray
    Roswell, GA
    Nevermind. The answer is in this thread. Dimmer cable is the green wire on the truck bed light switch.
  5. Mar 28, 2020 at 3:04 PM
    IntrepidTraveler
    Irv
    I did:
    GREEN - 12VDC (+) (low current, this is just to fire the relay coil, I have this wired via add-a-fuse to a switched circuit)
    RED1 - to the relay coil
    RED2 - ILLUM (+) - this is the cargo light green wire
    BLACK - Ground
    It functions as expected, although it is NOT dimmable.
    Check this thread for more info: https://www.tacomaworld.com/threads/accessory-wiring-with-ch4x4-switches-switch-illumination.655239/
    User caribe makaira was exceptionally helpful in making sense of it. Scroll to Post #12 on that thread for the actual switch "internals" wiring diagram.
    I also came across a post where someone was making some connector "extensions" that would allow tapping without cutting the factory wiring. Had I seen that before I brandished my wire cutters and soldering iron, I would have pursued it. Sorry, don't have that link any more.
  6. Mar 28, 2020 at 4:44 PM
    remgu2000
    Ray
    Roswell, GA
    Awesome info. Thank you. Will continue tackling it Monday.
  7. Apr 17, 2020 at 9:49 PM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    Thanks folks. This post was super helpful - especially the picture calling out the brown wire and implying the dash panel was easily removed. This got me right to the finish line on my lightbar using a relay and the same switch.
    RZ Rob
  8. Jun 30, 2020 at 8:40 AM
    wagmc
    wagmc Member
    Dashboard lights actually dim by varying the ground side potential. So the ground on the switch is not "ground" ground to metal somewhere, but needs to be the ground side of another switch illumination circuit. ie: the cargo light switch has a switch ground (I can't recall the color offhand), as well as an illumination ground (tan). This "illumination ground" is the ground you need to control your new switch illumination.
    HTH
  9. Jan 10, 2021 at 4:32 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  10. Jan 10, 2021 at 4:37 PM
    caribe makaira
    Caribbean, Puerto Rico
    Some have been able to get it done...most have not.
    Rock Lobster[QUOTED] likes this.
  11. Jan 10, 2021 at 6:16 PM
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    I ended up putting a variable resistor on the positive for my accessory’s (boost gauge in my case) backlight and adjusting the resistance to match the light intensity to where I keep my other dash lights.
  12. Jan 10, 2021 at 6:52 PM
    wagmc
    wagmc Member
    Yep. on the switch, green and red 1 are whatever you are switching. doesn't matter if it's positive or negative, all it does is complete the circuit.
    Red 2 goes to the light green on any illuminated switch (ie: cargo light switch).
    black goes to the beige or tan on any illuminated switch.
    on all illuminated switches on the tacoma, green is "positive" and beige/tan is "negative."
    Beige/tan does go to ground, but its easier to just tap the wiring at the switch.
    However, not all after-market switches are dimmable. If your switch is not dimmable, it will look like "on/off" because when the voltage drops below a certain point, it will just go dark.
  13. Jan 10, 2021 at 6:57 PM
    Gus87
    Gus87 Well-Known Member
    Chicagoland
    16 trd sport
    I’m interested in doing this but can’t find a write up on it. Do you mind explaining how you did it?
