Digressive vs Linear vs Progressive Piston & Valving Article (and video)
Discussion in 'Suspension' started by *TRD*, Aug 20, 2017.
  1. Aug 20, 2017 at 2:42 PM
    *TRD*
    *TRD* [OP] Well-Known Member
    Carson, Ca
    There are a lot of choices when it comes to what type of damping you want in your shocks so we put together an article which explains the different types, their benefits, and how they work.
    Article: The Pro's and Con's of Digressive, Linear, & Progressive valving, and how each one works.
    When it comes to Tacoma shocks Fox and King have linear pistons with fairly progressive damping curves while Icon and Bilstein use digressive pistons and digressive damping curves.
    This article is fairly generic and I'm happy to answer any specific questions you may have.
  2. Aug 31, 2017 at 1:38 PM
    *TRD*
    Carson, Ca
    Rico853 likes this.
  3. Aug 31, 2017 at 10:03 PM
    65skyturbo
    65skyturbo Well-Known Member
    Mesa, AZ
    06 Speedway Blue DCSB TRD Off Road
    Interesting, I learned something new. :D
    *TRD*[OP] likes this.
  4. Sep 5, 2017 at 11:42 AM
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    I'm sure you have forgotten more about shocks and shock tuning than I will ever know, but you state on your link that, " digressive valving will provide better handling than progressive valving due to the higher force at 2 in/sec."
    It seems to me that digressive / progressive does not necessarily mean that one will be stiffer than the other. Progressive / digressive only describes the shape of the force as a function of velocity curve, F(v) . Progressive is concave up or F''(v) is positive, whereas for digressive F''(v) is negative, and linear would be F''(v)=0. I see no reason why a progressive shock could not have a Force curve that remained greater than a digressive force curve for the entire range of v. That's not to say that any manufacturers are doing this but I found the information a bit confusing.
    Biscuits likes this.
  5. Sep 5, 2017 at 11:46 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    I would have gotten a much better grade in Calc 1 if all the test questions were phrased to reference suspension components
  6. Sep 5, 2017 at 12:40 PM
    *TRD*
    Carson, Ca
    Thanks for the feedback. I should clarify that the assumption was that they were being tuned for the same vehicle with similar use. So overall the net area under the curve would be similar, but digressive has more force at the low speed, and progressive has more force at high speed. Handling (cornering) happens at ~2 in/sec so the digressive shock will have better handling. Is that a better explanation?
  7. Sep 6, 2017 at 7:46 AM
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    2 things:
    It's been a while since calculus so I might have screwed this up but for the integral of F(v) I get units of mass/time. What would that represent physically? That is a mass flow rate but doesn't really represent anything to me in this context.
    Also, in order to have similiar areas, the progressive curve would need to be integrated over a longer interval; what would that mean?
  8. Sep 6, 2017 at 7:48 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
  9. Sep 6, 2017 at 2:19 PM
    Cougars
    Cougars Well-Known Member
    You have hit the nail on the head here. It describes the shape of the curve and is not enough information to determine whether one shock is stiffer than another. It is safe to assume that digressive will be stiffer in the low speed range than progressive/linear, but you cannot assume that one will be stiffer than the other in high speed ranges.
  10. Sep 6, 2017 at 4:07 PM
    *TRD*
    Carson, Ca
    We are only describing the shape of the curve, however the trade offs still exist and impact how the shock performs.
    Tuning a digressive piston to match the high speed compression performance of a linear piston is very difficult. The way they're designed results in the forces blowing off, and you'd end up with so much low speed compression it would be unbearable. The piston is a good indicator of how the shock will feel, especially on compression.
  11. Sep 9, 2017 at 5:57 PM
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    Please elaborate on what you mean by "forces blowing off".
  12. Sep 11, 2017 at 11:37 AM
    Cougars
    This is the simplest explanation i can think of but it gives a good overview of the systems. It is not a perfect explanation but if you arent familar with valving it should do.
    Digressive curves rely on high flow pistons and preloaded shim stacks in order to get high low speed forces (preloaded stacks) but reasonable high speed forces. The pistons flow enough oil such that the shims dominate the valving profile and at high shaft speeds oil flow through the piston is not choked. This provides moderate force ramp up from about 20in/s and up.
    Linear/progressive curves rely on low flow pistons and non-preloaded shims. This provides small low speed forces but large high speed forces. At high shaft speeds , >20in/s , oil flow through the piston is choked (low flow piston) which provides greater force ramp up than a high flow system.
  13. Sep 19, 2017 at 9:56 AM
    *TRD*
    Carson, Ca
    ready6delta likes this.
  14. Nov 5, 2017 at 10:33 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    It is my understanding that fox is linear and Icon is digressive, as mentioned above.
    I am interested in Fox DSC coilovers up front, but am intrigued by Icons RXT and more specifically Omega bypass rear shocks.
    The off-roading I do makes me lean towards linear valving, as I’m going faster over terrain. But still like the idea of being able to run a bypass shock.
    Would it be a bad idea to mix the two from front to rear?
  15. Nov 6, 2017 at 8:17 AM
    *TRD*
    Carson, Ca
    All bypass shocks are progressive due to the extreme amount of free flowing oil at slow speeds, so the piston design isn't the dictating factor.
    I'd pair them up.
  16. Jan 7, 2018 at 4:25 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Hey Ryan. Great articles and videos on your site. Easy to understand and it demystified a lot.
    I've seen a few questions mentioned on this site asking if it's possible to add a linear/progressive profile to ICON 2.5 coilovers. You stating it's difficult to valve a digressive piston to linear/progressive characteristics. Are there linear pistons out there compatible with Icon ID shock bodies and their corresponding shaft flanges?
  17. Jan 8, 2018 at 8:42 AM
    *TRD*
    Carson, Ca
    It's not likely, tolerances on those items are between 0.001 and 0.003", so it's a very precise fit.
    License2Ill[QUOTED] likes this.
  18. Jul 10, 2018 at 10:47 AM
    deuceb
    deuceb Well-Known Member
    Denver | Austin
    2018 Taco BBPDCLBTRDOR | 2004 MB SL55 | 86 VW GTI
    Thanks for these videos and explanations. It's been the most helpful thing I've seen with regards to picking suspensions yet, and I'll be ordering the Stage 5 kit from you as soon as I take delivery of my Taco in 2 weeks!
  19. Jul 10, 2018 at 4:54 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I too found the info on the Accutune Off-Road website extremely helpful. I spent probably 45 minutes on the phone with one of their reps (Andrew) and he really helped me figure out what would be best for my use. Pulled the trigger on a Fox 2.5 setup and can't wait for it to arrive!
    MCDavis, Sub_Par and *TRD*[OP] like this.
