Differential oil (front & rear) replacement schedule?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 5.0Dave, Jan 31, 2017.
  1. Jan 31, 2017 at 3:44 PM
    5.0Dave
    5.0Dave [OP] New Member
    2010 Tacoma 4x4 6-cyl TRD Sport
    none
    I have 57K on my 2010 Tacoma 4x4 (6-cyl). The dealer reported replacing both differential oils at 30K. I don't tow/haul or use my truck off-road, only occasional use of 4WD in snow or on my steep back yard. Do those fluids really need to be replaced at 60K? Dealer will charge an extra $200 for 60K service with fluid change. Service rep said a lot of owners wait till 100K.
    Thoughts on this? Thanks!
  2. Jan 31, 2017 at 3:46 PM
    reefnfeef
    reefnfeef Well-Known Member
    Bridger, MT
    '14 Pyrite Mica DCLB TRD Sport
  3. Jan 31, 2017 at 3:50 PM
    Toyojake
    Toyojake Well-Known Member
    Jay
    Central TX
    2009 T4R Sport 4x4
    I would say to have them done. Diffs are one of the most neglected items on a truck, and one of the most important. I have always changed my gear oil every 30k and I've never experienced a problem with them on any car/truck I've owned. Don't forget the T-case too, just need oil and a handful of crushwashers.
    File IFR likes this.
  4. Jan 31, 2017 at 4:12 PM
    Kevmeistah21
    Kevmeistah21 Well-Known Member
    Kevin
    Pasadena, CA
    2015 DCSB TRD SPORT 4x4
    5100/887 LR UCA HS 3-Leaf AAL's SCS Stealth 6's BFG Ko2 285/70/17
    30k - front diff, rear diff, and transfer case with amsoil severe gear.
    I change my tranny fluid during this service as well.
    Norton likes this.
  5. Jan 31, 2017 at 7:00 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Maybe I'm too lazy or cheap but when I change mine, I just wrap the threads of the plug with some Teflon tape. I've never replaced the crush washers and I don't have an seepage......well, on my truck anyway.
  6. Jan 31, 2017 at 11:00 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1 for Amsoil Severe Gear 75W-90.
  7. Feb 1, 2017 at 5:05 AM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    Mush Mouse likes this.
  8. Feb 1, 2017 at 6:00 AM
    badger
    badger Well-Known Member
    07 SR5
  9. Feb 1, 2017 at 6:21 AM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    Do it yourself, it really is basic and easy. I use Mobil-1, I change my rear every 30K and I did the front and transfer at 60K. Front was pretty nasty but the transfer looked pretty fresh. The rear is always dirty after 30K.
    I put 900-1,200 miles on in 4WD so far this winter so i'll probably change my front again before next winter.
  10. Feb 1, 2017 at 6:53 AM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
  11. Jun 1, 2020 at 8:30 AM
    sbayer91
    sbayer91 Member
    My dealership just quoted 460 for front and rear diff “service”. Is this just the oil change or do they do something else along with that? Way too much money for such a simple process.
  12. Jun 1, 2020 at 8:34 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Save your money and do it yourself so you can do more mods and or maintenance.....Go Team TW!
    Rambo MARINE Recon and Kenstogie like this.
  13. Jun 1, 2020 at 8:48 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    what else is there to do? I would think that’s just the fluid change. Doesn’t even include the t-case???
  14. Jun 1, 2020 at 9:05 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Do it your self
    Buy the correct gear oil as mentioned
    One quart hand pump
    Just be sure you remove the fill plug first
    Don't drain then can't for some reason get fill plug loose
    New crush gaskets are a good idea...especially the drain
  15. Jun 1, 2020 at 9:09 AM
    sbayer91
    sbayer91 Member
    I don’t even know what else there is I was just so surprised by how high the quote was I thought there was something more. Definitely doing it myself!
  16. May 15, 2021 at 7:35 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    And knowing it was actually done.
  17. May 15, 2021 at 7:39 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    FWIW, my '06 2nd Gen has fluid service intervals as follows:
    30K front & rear diffs, transfer case fluid change
    100K Automatic Transmission fluid/filter change
    These tasks are simple DIY jobs. Just takes some time, fluids with a few gaskets and a filter.
    I would consider pushing the diffs and Xfer case to 33K, then these will match the Auto Tranny service interval.
  18. May 15, 2021 at 9:04 AM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    I did the first tranny “drain and fill” at 17k (right after I purchased the truck used). The fluid (~4 quarts) looked in really good shape so that seemed to be too early of an interval. I performed the next “drain and fill” 30k miles later. For me that seems to be the correct interval for my peace of mind. But I don’t tow anything and seldom have >500 pound loads in the bed. I never sent the fluid to the lab for analysis, so I just went by color and smell. Part of my transmission anxiety comes from owning Hondas, with the tranny being one of their weaker links, so my fluid exchange interval is likely more extreme than most folks on this forum.
    Since there is no dipstick the “drain and fill” process requires getting the tranny fluid up to a specific temperature then opening up the overflow drain port. If you search this forum you’ll find instructions how to do that.
