Differential/Carrier and 3.73 Gears
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by CRANKSTERWATCH, Aug 14, 2015.
  1. Aug 14, 2015 at 3:56 PM
    CRANKSTERWATCH
    CRANKSTERWATCH [OP] Well-Known Member
    Carey
    SW Oklahoma
    2008 PreRunner
    Magna Flow Cat Back Exhaust 6" Pro Comp Lift Katzkin Leather Nathan Airchime Train Horn Dual Viair Compressors Gentex Comp/Temp Mirror Kenwood DNX9980 Head Unit Focal PS 165FX Focal PC 165 Focal FPS 4160 AMP JL Audio Stealbox JL Audio XD 1000 LED Bed Lights LED Aux Backup Lights LED 20" Light Bar in Grill KC Highlites Driving Lights Camera Source Back up Camera Kenwood Front Camera
    Complete Unit from a 2008 Tacoma Pre-Runner with approximately 70K miles. Excellent shape and ready to install. I changed to 4.10 ratio.
    I will consider separating the gears from the carrier.
    I will cover shipping to the lower 48 not to exceed $75.00
    $275.00
    ******SOLD*****
  2. Aug 14, 2015 at 5:43 PM
    chadlogan112
    chadlogan112 Well-Known Member
    Chad
    Florida
    Bilstein 5100 Front and Rear, Maxtrac Spindles, Icon AAL, 285/60/18, 18x10, 5% Tint, K&N Intake
    No locker I assume?
  3. Aug 14, 2015 at 5:54 PM
    CRANKSTERWATCH
    Carey
    SW Oklahoma
    2008 PreRunner
    No Locker. Wish it did.
  4. Aug 15, 2015 at 9:35 AM
    CRANKSTERWATCH
    Carey
    SW Oklahoma
    2008 PreRunner
  5. Aug 16, 2015 at 8:09 AM
    CRANKSTERWATCH
    Carey
    SW Oklahoma
    2008 PreRunner
    Make an Offer
  6. Aug 17, 2015 at 11:25 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    What is involved in swapping out gears? and what ratio does my 2015 V6 trd off-road have?
  7. Aug 17, 2015 at 12:46 PM
    CRANKSTERWATCH
    Carey
    SW Oklahoma
    2008 PreRunner
    The install was pretty straight forward. I used the following link as a guide.
    https://www.tacomaworld.com/threads...d-installation-of-e-locker-3rd-member.193828/
    It took me about 3 hours to complete using basic hand tools. It was really a simple process.
    I don't have any idea what the stock gear ratio is for a 2015 V6. At the risk of assuming, I'm guessing yours came with the 3.73 ratio from the factory. I may very well be wrong in that assumption. Regardless of the stock ratio, I don't think my differential would be of any use to you, unless you just wanted the carrier to install a new ring and pinion and keep your factory differential intact.
  8. Aug 18, 2015 at 12:17 PM
    CRANKSTERWATCH
    Carey
    SW Oklahoma
    2008 PreRunner
    Bump. Someone Make me an offer. I will split the carrier from the Gears.
  9. Aug 18, 2015 at 12:21 PM
    Large
    Large Red
    Not as hard as one would think, and you have 3.73 but this carrier won't work on your truck.
  10. Aug 18, 2015 at 12:38 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    Would this drop into the 5 lug? There are a lot of conflicting comments about what does and does not fit. Would not mind having a bit more get up and go with my bigger tires on.
  11. Aug 18, 2015 at 12:42 PM
    CRANKSTERWATCH
    Carey
    SW Oklahoma
    2008 PreRunner
    I honestly wouldn't know the answer to that. I can tell you it came out of a 2008 Pre-Runner V6 automatic. The differential has some casting numbers on the housing that someone may be able to decipher. My axles were six lug. Sorry I cant be of much more assistance.
  12. Aug 18, 2015 at 12:44 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    Well, I will search around and see what I can find out. Maybe I will call the dealer and ask them..... they would know right? :rofl:
  13. Aug 18, 2015 at 12:47 PM
    CRANKSTERWATCH
    Carey
    SW Oklahoma
    2008 PreRunner
    They should but i wouldn't hold my breath. You may call the folks at East Coast Gear Supply and see if they have an answer. They seem to be the gurus on the Toyota differentials and they have excellent prices.
  14. Aug 19, 2015 at 12:15 PM
    CRANKSTERWATCH
    Carey
    SW Oklahoma
    2008 PreRunner
  15. Aug 19, 2015 at 12:18 PM
    Large
    Large Red
    No it won't work unless you swap the axle.
  16. Aug 19, 2015 at 2:44 PM
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    How do you know if this is true?
    Like Artruck, I hear conflicting things...I have 3.31 gears 5 lug manual and I wanted to swap to 3.73 from the V6 Tacos. I thought about this sale, but I'm too far away. I can buy locally at salvage yard...so I want to confirmation as well. If this is true, I think it would benefit Artruck to get 3.73...my intention is to also swap gears. 3.31 is crappy for 2wd 5 lugger.
  17. Aug 19, 2015 at 4:52 PM
    Large
    Large Red
    The wms-wms measurement for a 5 lug axle is 60", the 6 lug axles are 65". I'm not sure if it's just the shafts that are shorter but the axle housing itself is definitely different than the 6 lug. You could take a gamble and buy it to see if it works and take out the guessing but I'm pretty sure it won't. Good luck.
  18. Aug 19, 2015 at 11:33 PM
    imom
    CAL
    2014 Regular Cab
    I PM'd a member on here that actually did this swap. So I"m not sure if you ever did it, but he just told me it was done without an issue. I'm not sure how the longer axle would matter. If the 3rd member fits...then it fits.
  19. Aug 20, 2015 at 3:53 AM
    Large
    Large Red
    Well buy this one and let us all know how it works. All I said was the wms measurements aren't the same from the 5 lug to the 6 lug trucks and the axle shafts aren't the same length.
  20. Aug 21, 2015 at 11:22 PM
    CRANKSTERWATCH
    Carey
    SW Oklahoma
    2008 PreRunner
    Price Drop- I'll pay shipping to Lower 48
