Differential Breather - When?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BattleKat, Jan 8, 2023.
  1. Jan 8, 2023 at 4:46 PM
    BattleKat
    BattleKat [OP] Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    When should someone consider installing a diff breather? If you aren't doing water crossings or any water crossings you do are 6" deep or less and you take them slow, is there any value?
    The ARB one isn't very expensive and heck it looks like I could do it my self. Just not sure I need one. But like 75% of my truck, it is cheap insurance of the unknown/unexpected encounter. I've even read a story or two of someone having fun street driving through puddles fast and getting water into the diff from horsing around.
    71tattooguy likes this.
  2. Jan 8, 2023 at 5:02 PM
    PTPinETN
    PTPinETN Well-Known Member
    Alan
    ETN
    I do mild offroading, forest service roads mostly, and have crossed some creeks.
    I did the rear diff breather mod as cheap insurance. My understanding is that the rear diff is the lowest of all, and it’s easy to move it up behind the tail light.
    Alan
  3. Jan 8, 2023 at 5:15 PM
    Bishop84
    Bishop84 Well-Known Member
    There's loads of opinions. Here's mine.
    Stock is fine for most of us. Extend it if you do a lot of water crossings. Or boat launches.
    The problem with stock breather is the diff is scorching hot from the highway, and when it rapidly cools off it draws in water from the stock breather. Boat launches are terrible for this.
    Most of us for off roading is highway, arrive. Deflate, gear up, chat, get ready, go. So the diff cools down and is fine to cross some water.
    The negative to the breather is, the hose can freeze or plug up on its own, and there's some stories on here regarding that. So it almost needs to be checked from time to time. Plus where its routed matters as it will smell of gear oil, so the tail light area is best. Not the cubby.
    SLeeper512, Chew, Junkhead and 5 others like this.
  4. Jan 8, 2023 at 5:55 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If it’s not broken, don’t fix it.
    Chew and Junkhead like this.
  5. Jan 9, 2023 at 5:29 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    IMO I’ve had mine for quite some time. Plenty of water crossing etc. I check it time to time no problems. Re geared rig recently diff oil looked fine no moisture etc. I’ve ran temp gun checks no excessive heat , cools quickly 34EDBFB8-F545-4636-BFF8-90E189920C86.jpg
  6. Jan 9, 2023 at 5:31 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Happy New Year Bro hope all is good :thumbsup:
    @BattleKat
    BattleKat[OP] likes this.
  7. Jan 9, 2023 at 5:32 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I did it on my 2nd gen, won’t be doing it on my 3rd gen. Stories of it getting filled with water due to condensation has changed my mind on it.
  8. Jan 9, 2023 at 5:52 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    25,000 miles. Over 200 water crossings well over the diff breather. Completely stock. No water in the oil.
    Coworker has a 2017 with 150,000. Launches a boat 3 times a week with the rear diff under water. Changed his oil for the first time in Nov and not a drop of water.
    I don't see the need for changing what Toyota designed.
  9. Jan 9, 2023 at 7:31 AM
    BattleKat
    San Diego
    All good, Happy New Year. How is the rain up north?
    71tattooguy[QUOTED] likes this.
  10. Jan 9, 2023 at 7:33 AM
    BattleKat
    San Diego
    Really? I hadn't read about that. How does it get condensation? The long breather tube getting condensation inside of it and it getting sucked in? I guess I could see that especially in colder weather. Cool air in tube mixing with warm air coming out of the diff?
  11. Jan 9, 2023 at 7:40 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I saw that East Coast Gear supply recommends using regular oil not synthetic in the rear diffs as well, they say that regular oil does handle water better than synthetic. I did have my breather freeze up on me last year, -30 C and I drove for 6 hours in that temp, blew my rear axle seals. I did redo the breather with a uni filter mini breather and this winter has not been cold like that so I am not worried about problems - this year.
    SLeeper512 likes this.
  12. Jan 9, 2023 at 9:19 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Thank you. Rain Is crazy up here bro
    BattleKat[QUOTED][OP] likes this.
  13. Jan 9, 2023 at 9:31 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I do water crossings and still run the factory breathers. I've seen more issues on this forum from breather mods than factory failures.
    I have an ARB diff breather on my shelf that I could sell you.
    Junkhead likes this.
  14. Jan 9, 2023 at 9:33 AM
    TexasWhiteIce
    Texas
    From what I read it’s condensation that settles in the bottom of the U on the hoses over time.
  15. Jan 9, 2023 at 10:31 AM
    TacoGranny
    TacoGranny Well-Known Member
    2020 TRDOR DCSB Cement 6MT
    33's, Sliders, Skid Plates, Softopper, ATH rear bumper
    I'm also in the camp that it's not necessary and can create more problems than it supposedly solves. I've never seen sufficient evidence to suggest that it helps anything. As already mentioned, I'm sure there are thousands of people that have their rear diffs in and out of the water hundreds of times at boat launches with no issues, otherwise I suspect we'd see the issue posted on here more often.
  16. Jan 10, 2023 at 11:17 AM
    BattleKat
    San Diego
    Really good feedback everyone, thank you.
  17. Jan 10, 2023 at 11:22 AM
    navin
    navin Well-Known Member
    Change the gear oil on a regular schedule. Im doing it every 10k just to do it. Gears and a Detroit Locker diff I want to protect. No extended vent tubes planned.
  18. Jan 10, 2023 at 3:51 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Someone on here mentioned to use clear tubing so you can see if it gets clogged.
