Differential and transfer case Ravenol fluid
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sh56, Jan 28, 2024.
  1. Jan 28, 2024 at 5:40 PM
    Sh56
    Sh56 [OP] Well-Known Member
    Shara
    2022 Lunar Rock Tacoma TRD off road
  2. Jan 28, 2024 at 5:44 PM
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    They're highly regarded in the Euro car world. Use with confidence!
  3. Jan 28, 2024 at 5:45 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Top shelf
  4. Jan 29, 2024 at 3:00 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I used Ravenoil when I changed oil in both diffs and transfer case this summer.
  5. Jan 29, 2024 at 4:02 AM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
  6. Jan 29, 2024 at 4:12 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    I used Ravenol, when I did the diff's and T-case on my 19 sport. I researched it a little bit, seems like decent stuff. I have their trans fluid too but, havent brought myself to swapping it out just yet, at 40,000 miles. Ski
  7. Jan 29, 2024 at 4:28 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I bought WS trans fluid from dealer, wasn’t going to risk compatibility with the Ravenol
    908tacoma likes this.
  8. Jan 29, 2024 at 4:45 AM
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    Redline mtlv in my t case and mt90 in my manual trans. Then amsoil severe gear 75w90 in my diffs. Everything works fine.
  9. Jan 29, 2024 at 5:02 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    The differentials and transfer case are tried and true technology. Nothing has really changed since the 70s in there. As long as it's got some oil of some type it should be fine, but i'd make an effort to put in gear oil at least.
    Chew likes this.
  10. Jan 29, 2024 at 5:06 AM
    MGMDesertTaco
    I did a bit of research a while back and discovered many were using Ravenol for the transfer case and Redline 75w-90 GL5 for the front and rear diffs. I shopped around and found the oem fluids for not much more than the cheaper alternatives. :notsure:
  11. Jan 29, 2024 at 8:22 AM
    gasganofj60
    gasganofj60 Well-Known Member
    87 FJ60 & 21 TRDOR
  12. Jan 29, 2024 at 10:41 PM
    chasecmc
    chasecmc Well-Known Member
    Chase
    2017 DCSB TRD OR
    GFC
    A lot of threads about this, I’ve personally decided to only run the Toyota OEM transfer case fluid. The additive package in the ravenol is very different. Does that mean it’s bad fluid? No. But it isn’t a direct copy by any means.
