Different Mobil 1 oils
Discussion in 'Technical Chat' started by cr500taco, Nov 28, 2021.
  1. Nov 28, 2021 at 3:09 PM
    cr500taco
    cr500taco [OP] Well-Known Member
    D
    Northridge
    4WD
    I usually use the regular Mobil 1 10w30 oil in my 3.4L. I see now that they have several different synthetic oils. Curious as to which ones you all use. I am leaning towards the Fuel Economy one. My motor only has less than 20K miles on it.
  2. Nov 28, 2021 at 3:12 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    As long as it meets the rating and weight in your owner's manual they are all good oils.
  3. Nov 28, 2021 at 7:08 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It doesn't matter, it's all the same
    6 gearT444E likes this.
  4. Nov 29, 2021 at 3:16 AM
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    Do you have data to back up the opinion?
  5. Nov 29, 2021 at 2:24 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I am curious if it's oil question season or something, I see alot of oil change interval/brand threads lately. The recommended oil viscosity and change interval is in the vendor manual. If you choose to deviate, so be it but don't look for advice here as everyone will have a different opinion.
    I'd offer no technical advice to the OP, but run it and see what happens, keep track of your MPG. With so many variables such as winter blend fuels, humidity, lead foot, stop/go traffic, I doubt you'll be able to correlate a difference in oil weight to MPG.
    JGO[QUOTED] and tcjacado like this.
  6. Nov 29, 2021 at 2:35 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I use the Valvoline, Pennzoil or Quaker State versions of Mobil 1.
    Specifically in the 5w30 edition.
    Just follow the recommendations in the Owner's Manual. Viscosity, API grade and change interval. Any brand or flavor that meets these recommendations will be sufficient.
  7. Nov 29, 2021 at 3:26 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    only difference the additive packages
    the rest is ALL Marketing
    use what Ur manual says ..........................U arent doin anything wrong
    if U are anxious to Every wind shift.....................U will tap dance on the head of a needle
