Difference in TRD Off Road suspension?
Discussion in 'Suspension' started by Karl77, May 13, 2020.
  1. May 13, 2020 at 3:21 PM
    Karl77
    Karl77 [OP] Member
    Kolton
    2009 Tacoma 4x4 V6
    I was wondering if there is a difference in the base suspension to the trd off road suspension. My whole suspension was worn out from the previous owner and I'm starting to beef up the build(bed rack and roof top tent, steel bumper and winch,ect). I'm also on a bit of a budget of about 1.6k. I have an open mind towards aftermarket but I've never needed new suspension before. Also I just put on 265/75/R16 BFG KO2's. Will I still have a slight rub or will this help. Not that that part matters too much. Thanks for your advice!!
    2009 Tacoma Access Cab Base model.
  2. May 13, 2020 at 4:12 PM
    zdski
    zdski Well-Known Member
    Zach
    Phoenix, AZ
    2011 DCLB TRD Sport
    5100s, AAL, TRD Wheels, 285 Ridge Grapps
    TRD off-road has bilstein shocks, but you can swap suspension directly from a TRD OR onto your truck. I would recommend looking into take-off suspension from 3rd Gen tacomas. People usually sell very low mileage suspension from their 3rd gen trucks for $100-$200. You will also get ~1in lift out of this setup on a 2nd gen, which could help alleviate any minor rubbing.
    However if you want to use more of your budget, you could look into an Eibach or Bilstein 5100 setup.
    Casper66 likes this.
  3. May 13, 2020 at 4:14 PM
    Big_Red_Taco
    Big_Red_Taco Well-Known Member
    SoCal
    Rad Red '08 DCSB TRD Off Road
    Mostly stock: AP rear plate bumper, CR D-Lights, 4600s
    As far as shocks are concerned, the base shocks are KYB, I believe. The TRD ORs use a Toyota design built by Bilstein. Incidentally, some will say that the TRD Bilsteins are the same as aftermarket Bilstein 4600s, but they are not. I have the 4600s and they are completely different shocks from the stock Bilsteins. Beefier than stock, but must remain at stock height. Bilstein 5100s, which you'll hear recommended a lot, are the same valving as 4600s but will allow stock height plus a lift, if you want, for not much more in price.
    What most people do is a front spring/rear leaf upgrade (or add-a-leaf) along with 5100s. That's the most common, bang for the buck aftermarket setup you'll see around here, that will also give you much more capability than the base model suspension.
    Not to knock the KYBs though - I rode a dirtbike with KYB suspension, and it was amazing.
  4. May 13, 2020 at 4:16 PM
    Big_Red_Taco
    SoCal
    Yes! A 3rd-gen TRD off road take-off is a great way to go too - I've seen low mileage springs and shocks for $200-300 for everything.
  5. May 13, 2020 at 4:24 PM
    Karl77
    Karl77 [OP] Member
    Kolton
    2009 Tacoma 4x4 V6
    Wow thanks. That's a lot of info. I've noticed around town that almost all the tacomas sit at different heights. Yet when I check them they appear to be running stock. Which led to my curiosity about a possible difference in the stock version and the trd version.
  6. May 13, 2020 at 4:31 PM
    Big_Red_Taco
    SoCal
    No problem! I went through all this when I finally replaced/upgraded my very tired original shocks after 185,000 miles. :anonymous:
  7. May 13, 2020 at 5:19 PM
    Karl77
    Karl77 [OP] Member
    Kolton
    2009 Tacoma 4x4 V6
    Ya I'm sitting at about 195 or something. They are very old and worn. Especially after two large trips back to back (about 5,000 miles each). Is there anything to worry about like my uca or lca if I went with third gen suspension? Any mounting issues or anything of the sort?
  8. May 13, 2020 at 5:30 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Just remember the stock Tacoma rear springs are composite and can splinter and usually sag alot quickly.
    My 09 I went with OME rear springs which also gets rid of the spring wrap causing shutter (plus a Tom Woods 1 piece driveshaft) and then stock springs on 5100s in front . As long as you keep the front lift to about 2" all OK and the rear up about 3" and towing settles to level and I have a shell and full steel skids. Many options and many posts to read to decide money/performance/how high.
    Update: Yea my use of composite may be confusing but the spring steel mix is substandard and fractures/splinters and can puncture the gas tank. Sorry for any confusion.
    Big_Red_Taco likes this.
  9. May 13, 2020 at 6:02 PM
    Big_Red_Taco
    SoCal
    The UCAs are the same on both generations - the LCAs are actually different, but I believe it all bolts up just right. I haven't done it myself, but plenty of others have. Check out this thread:
    https://www.tacomaworld.com/threads/3rd-gen-suspension-on-2nd-gen.487273/page-5
    This is the kind of setup I want to go towards in the future.
  10. May 13, 2020 at 6:22 PM
    Karl77
    Karl77 [OP] Member
    Kolton
    2009 Tacoma 4x4 V6
    Thats good to hear. For the time being I think I'll take that route then. Till I can afford the insanity of a build I want. Thanks for all the help!
    Big_Red_Taco[QUOTED] likes this.
  11. May 13, 2020 at 6:26 PM
    Karl77
    Karl77 [OP] Member
    Kolton
    2009 Tacoma 4x4 V6
    I'm a bit confused with all the problems mentioned. Are you referring to using aftermarket rear leafs causing the wrap and shudder or stock? I've always noticed a small vibration when driving and have looked in all the common areas including replacing my rear u-joints. Is that possibly what your referring too? My leafs are practically flat with an empty bed.
  12. May 14, 2020 at 12:27 AM
    muddog321
    FL
    Many many posts on that issue of shutter/vibration due to weak springs, driveline angles, the 2 piece driveshaft and center bearing, etc.
    Stock Toyota springs have a recall on them so check your VIN for it. They had a 3 and 4 pack so new my 09 had a 3 and any load sagged right to the stops so got free 4 pack installed that lasted about 4 years and they dropped so a load or towing right down on the stops. Toyota had their recall and a 2 year wait so I sucked it up and went aftermarket so I could tow my boat. Aftermarket springs are the correct fix as stock is for the pavement crowd that want soft and don't use it as a truck. Many opinions out there so good luck.
  13. May 14, 2020 at 3:12 AM
    Karl77
    Karl77 [OP] Member
    Kolton
    2009 Tacoma 4x4 V6
    Oh wow ok. Ya I live in Montana where half of the year I need at least 200lbs in the bed to help with the snow and ice, and now I just bought a bed rack and roof top tent. The tent alone is already 200lbs and I believe the rack is 85 to 100. I don't remember. So then that leads me to my next question. How big of a "lift" would I be needing on my leafs to match the 3rd gen stock height? I constantly tow and haul due to my seasonal job and the winter. Should I just do a complete aftermarket setup or would I be fine with 3rd gen stock front and aftermarket rear?
  14. May 14, 2020 at 4:09 AM
    muddog321
    FL
    Sorry but I have no insight into the 3 gen stuff on a 2 gen so read their posts. All my mods done before 2016 and 3 gens came out.
  15. May 15, 2020 at 7:10 AM
    Karl77
    Karl77 [OP] Member
    Kolton
    2009 Tacoma 4x4 V6
    Thats all right thanks for the insight. Ill just go with aftermarket suspension. I going camping a lot and constantly haul/tow something so it will be worth it in the long run to go with that. Thanks for the help!
  16. May 15, 2020 at 7:24 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    First I have seen that the rear leafs are composite.
    YF_Ryan likes this.
  17. May 15, 2020 at 7:30 AM
    Hans_Gruber
    Hans_Gruber Well-Known Member
    Nick
    13 DCSB TX TRDOR 6MT
    All Stock
    I just did 3rd gen suspension swap on my 13 with an aal in the rear. Gave 1 1/4 lift in the front and 1 7/8 in the rear. Sits higher in the rear, but with a few hundred pounds back there it will stay level with the front. I recommend for budget upgrade, all together was under 500 bucks for brand new shocks/coils aal and 1/4in spacer to fix taco lean and it drives like a new truck.
  18. May 15, 2020 at 7:45 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    HUH? are you confusing the leaf springs with the bed?
    Never heard of composite leaf springs so I did some google searching and searching on this forum, I don't see anywhere that these trucks come with composite leaf springs?
    ace96 likes this.
  19. May 15, 2020 at 8:55 AM
    ace96
    Western KY
    Mine have a lot of rust for being composite o_O
  20. May 15, 2020 at 8:58 AM
    YF_Ryan
    Kent, WA
    I guess our entire truck could be considered composite.
