Difference in brake drum part numbers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BTLowry, Nov 9, 2021.
  1. Nov 9, 2021 at 5:24 AM
    BTLowry
    BTLowry [OP] Well-Known Member
    Texas
    99 SR5 4x4 xcab
    Gathering stuff to redo brakes on my 1999 4x4
    Looked up part numbers for brake drums and there are 2 part numbers
    4243135180
    4243135210
    Both the Toyota site says are a for for my truck by serial number
    Top one is ~$15 more
    I cannot find anywhere that tells me the difference
    What am I getting for $15 more?
    Also it has this in description (this is just a part)
    How do I use/interpret this?
    From 198508 to 198808.
    00003K0501 0; LN66,RN6#,VZN6#;
    From 199902 to 200112.
    000013 0; UCK30,40,VCK30,40;
  2. Nov 9, 2021 at 7:41 AM
    BTLowry
    Texas
    99 SR5 4x4 xcab
    That is what I was afraid of
    I had a 99 Super Duty that was mid year model and it was a PIA to get parts right half the time
  3. Nov 9, 2021 at 7:42 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    You're correct, both of those part numbers come up under the same reference number:
    I'd be willing to bet these belong to either the truck - 02/03 (with the parking brake cable above the axle housing) and the 03-04 (with the parking brake cable below the axle housing), but it's just a guess, and I wouldn't have a clue on how to tell the drums apart.
    Question though- Can you try turning your existing drums? I had mine turned @ 145k without an issue. Took them to a local shop, and they turned them around in 45 minutes for around $15 a piece. It was a ton cheaper than $170-190 bucks!
    Also... I feel like the wheel cylinder and shoes are more important to get OEM parts for over the drums- So you might want to check the local parts stores and see what their higher-end options are if you're set on new ones.
  4. Nov 9, 2021 at 7:55 AM
    BTLowry
    Texas
    99 SR5 4x4 xcab
    Definitely going to look into turning drums, just collecting part numbers to be prepared in advance.
    Wheel cylinders and shoes definitely getting replaced
    Truck is 99 model with parking brake above axle I am pretty sure
  5. Nov 9, 2021 at 8:09 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Have you worked on drum brakes before?
    If not, I HIGHLY suggest getting the drum brake tool kit, specifically the spring retaining tool and the shoe pliers. I think HF sells a cheap kit. They will make your life SO MUCH easier. I've done my shoes once without, and learned my lesson the hard way. The second time was a breeze.
    Also, if you're replacing your wheel cylinders, I highly suggest a Motiv power bleeder... and obviously flushing the entire system to get as much of the old fluid out as possible.
  6. Nov 9, 2021 at 8:34 AM
    BTLowry
    Texas
    99 SR5 4x4 xcab
    I have but I may grab that cheap set of tools
    Will look up power bleeder
  7. Nov 9, 2021 at 10:22 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I can`t be sure some Trucks have different size Brake Lining
    For Years I used Raybestos Brake products Now I have gone to Napa Ultra Premium for Brake Parts.
    Even at 30% off List Toyota Brake Drums are a little expensive.
    Good Luck getting Brake Drums Turned No one in my area does it any longer It is no longer cost effective
  8. Nov 9, 2021 at 3:08 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I looked at the OEM shoes, and it's easy to tell which diagram is which for the parking brake cable variation based on the backing plate and bell crank position.
    Diagram 470418 is above the axle
    Diagram 473102 is below the axle
    HOWEVER, both of these diagrams call out to the same shoe reference and part number: 04495/04495-35230. That part has the related part number 42431-35180 for the drums. I don't know if that means anything... Also worth mentioning, that both of those diagrams have the same callout for the backing plate, which obviously is not correct.
