difference between yzzd3 and yzzd1 oil filter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by itzyoboipaul, Feb 5, 2014.
  1. Feb 5, 2014 at 10:51 AM
    itzyoboipaul
    itzyoboipaul [OP] Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
  2. Feb 5, 2014 at 11:06 AM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
  3. Feb 5, 2014 at 11:15 AM
    itzyoboipaul
    Paul
    PFville, TX
    2020 TRD OR Cement
    yea exactly what I did
    I called two dealerships here who told me d3
    went to ebay to check and saw d1
    WTF haha
  4. Feb 5, 2014 at 11:19 AM
    crawl
    crawl Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    D3 is longer with presumably more filter media. Chris 4x4 cut one open and it looked good so I started using it. Also my dealer said it was fine to use on the 2.7 4cyl.
  5. Feb 5, 2014 at 11:20 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    The D3 fits without any problems on the 4 banger. I figure the longer one has more filtering media, and the price is right, so I use that on mine.
  6. Feb 5, 2014 at 11:22 AM
    itzyoboipaul
    Paul
    PFville, TX
    2020 TRD OR Cement
    yea called two more dealership. they said d3 will fit, its a little longer . but the one specifically for the 4cly is the d1
  7. Feb 5, 2014 at 11:23 AM
    itzyoboipaul
    Paul
    PFville, TX
    2020 TRD OR Cement
    azreb
    longer means is it harder to maneuver/install in tight space or about the same??
  8. Feb 5, 2014 at 11:29 AM
    azreb
    azreb Geezer
    TN
    Installation is no problem. There are no obstructions.
  9. Feb 5, 2014 at 11:49 AM
    itzyoboipaul
    Paul
    PFville, TX
    2020 TRD OR Cement
    kool thanks
  10. Feb 5, 2014 at 11:57 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    I bought the d1 on accident one time. Went 6k on oil change rather than my usual 9-10k.
  11. Feb 5, 2014 at 12:01 PM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    I thought I saw somewhere that the D1 didn't have the anti-drain valve and the D3 did. (I could be mistaken.) The V6 has it's filter nearly upside-down (at least on the tow package models), so it definitely needs the D3.
  12. Feb 6, 2014 at 8:17 AM
    crawl
    Greg
    Valencia, CA
    all filters made for NON race applications have an anti-drain valve built into it.
