Difference between the 2.5 gen and 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeefedTacos, Aug 23, 2015.
  1. Aug 23, 2015 at 7:28 PM
    BeefedTacos
    BeefedTacos [OP] Well-Known Member
    Brian
    North Carolina
    2015 tacoma dcsb SR5 4x4
    None so far
    I'm interested in the difference. Obviously there is a minor body difference but were there any changes inside? I'm buying used weather techs from a 2010 and want to put it in my 2015.
  2. Aug 23, 2015 at 7:41 PM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    You're good! Do they have the little holes in them for your floor tabs? That will be the only problem you will encounter I think
  3. Aug 23, 2015 at 7:51 PM
    jayuu
    jayuu Well-Known Member
    Central Maine Highlands
    2017 Black TRD Sport DCSB 6 sp manual
    As Josh828 said, the attachment posts have changed, but the floor layout is the same. You'll have to remove the tabs from the floor (don't know if you can do that easily), or modify the mats. Of course, then you'll have two extra holes in the mat, which kinda' defeats their purpose.
    I recently traded my 2010 AC for a 2015 and kept the Weather Techs with the intent to use them in new AC. Bought Husky XACT fit mats when I discovered the WTs did not fit. Like the Huskys better.
