Difference between a body lift and a suspension lift?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SkunkMan17, Jan 28, 2019.
  1. Jan 28, 2019 at 5:50 PM
    eimkeith
    eimkeith Well-Known Member
    J Keith
    '96 4Runner, '03 Taco
    neither will.
    right; there isn't one single method to clear larger tires.
    (and that isn't custom fab work; it's deletion)
  2. Jan 28, 2019 at 5:54 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    :jerkoff:
  3. Jan 28, 2019 at 6:12 PM
    eimkeith
    J Keith
    Ok, gotcha. school's out.
  4. Jan 28, 2019 at 6:35 PM
    Indy
    Indy Master of all I survey.
    Neither a body lift nor a suspension lift on their own gives any additional ground clearance. Not a tiny bit of an inch.
    eimkeith likes this.
  5. Jan 28, 2019 at 6:42 PM
    Danno1985
    Danno1985 Well-Known Member
    Milwaukee
    2003 Prerunner TRD Off-Road (RIP)
    Body lift won't help you there, because your frame and everything attached to it except for the body itself will still be stock height.
    I ran Bilstein 5100s up front at the middle setting for a mild lift with OEM springs on my '03 and hated the way it rode. It felt like the shocks had no travel at all. Typically I've had outstanding luck with Bilstein products, but one of the front shocks blew out prematurely and I replaced the entire strut assembly with Rancho Quicklift adjustable struts, which rode much better in comparison.
    Now, about the body lift... funny story. My 1st gen Tacoma was totaled by a texting driver few months back, and I replaced it with, yup, a Ferd. Unfortunately, Ford in their infinite wisdom decided to a. lower the 2010-11 model years to help with CAFE standards and b. make it nearly impossible to do any kind of suspension lift without throwing the stabiltrak into panic mode. So... in order to clear 31" tires, I got *gasp* a body lift. Not my first choice, but, you know what... it's fine. There's more room to work on stuff, the center of gravity stays low and nothing in the front end geometry changed, so I'm not tearing up ball joints. I do think they look less goofy on Rangers than on Toyotas, though, and the suspension geometry of the Toyotas makes it much easier to achieve a decent amount of suspension lift, so... I'd go that route if I were you. Maybe check the pizza cutter tire thread, too, if you want maximum snow traction.
  6. Jan 28, 2019 at 8:53 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Only tires will give you more clearance under the rear axle, but a suspension lift sure helps with the approach and departure scraping and keeps the body away from rocks.
    SkunkMan17[OP] and DW85 like this.
