Diff. Locker conversion price ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by scyot89, Oct 2, 2011.
  1. Oct 2, 2011 at 10:13 AM
    scyot89
    scyot89 [OP] Well-Known Member
    TJ
    South Carolina
    2015 TRD OR DCSB
    Stock
    My truck is a 5speed 4x4 but it is not a TRD model, so it does not have the diff. locker in the rear. I understand ARB makes one and it works exactly like the TRD does. Would it be better to get the ARB setup or get the toyota locker ? Has anybody takin they're truck to toyota and got the locker installed, how much was it, or is this something i could probably do myself in the shop if i got the parts.
  2. Oct 2, 2011 at 10:15 AM
    Davidson
    Davidson Well-Known Member
    Cody
    Elmendorf AFB Alaska
    11 trd sport
    5100's in the front @ 2.5", 1.25" allpro wheel spacers (Removed), painted front valance, BHLM, eyelids, Grillecraft grille, magnaflow catback ehxaust, k&n CAI, window tint, 2 10" kicker subs, painted badges, 5000k 55w HIDs (headlights & fogs), (2) 7" kragen HID lights behind grille, rear tsb (finally), AAL
    sub'd, also want to know this
  3. Oct 2, 2011 at 10:52 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Converting the 8.4 to accept the Toyota E locker is doable, but I hope you are not scared of welding, grinding, drilling and tapping your axle housing. Do a google search for it, there are plenty of writeups out there on how to do it.
    Here's one to get you started
    http://www.4x4wire.com/toyota/tech/electric_locker/
    The ARB air locker is far more plug and play, but it's going to cost you some coin. The locker itself is around $850 not including the compressor. Compressor prices range depending on which one you get. Installation prices also range from shop to shop. Typically about $500 if you let them do the whole thing. Add another $200 if you regear the 3rd member at the same time.
  4. Oct 2, 2011 at 11:17 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    ARB uses air pressure from an onboard compressor to engage the locker. Toyota uses an electric motor... not quite the same.
  5. Oct 2, 2011 at 11:35 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    seen many people throw the elocker in the none trd housing. gotta cut a notch in the housing tap some holes and wire it. more than most back yeard mechanics can handle. plus u gotta find a 3rd member... dont know about other places but being in CO they are hard to find, even harder to find cheap everybody wants one lol
  6. Oct 2, 2011 at 11:38 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The ARB is nothing like the TRD E locker. You need OBA to run ARBs. In other words about 500-1000 more bucks. ARBs are supposed to be stonger tho. You do have to tamper with the original diff housing tho, in order to get air into the housing.
    Easist way is to find an E locker 3rd member and swap it into your truck. Should only be about 300-500 bucks. You simply swap out 3rd members, or entire diffs, and then just some simple wiring.
  7. Oct 2, 2011 at 11:55 AM
    Alpha Q Up
    Alpha Q Up Well-Known Member
    Ruben
    San Jose
    2003 4WD DC Tacoma
    Damn that sucks. I thought it would have been easier.
  8. Oct 2, 2011 at 12:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    nope lol :p thats why its just nice to have it build in. Im going to get lockers tho. Need at least a rear
  9. Oct 2, 2011 at 12:36 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Conceptually they are the same, that being they are both a SELECTABLE LOCKER.
    You could not be more wrong. The third members do not just swap.
    Here's a visual on the housings for you. 8.4 on the left, TRD 8.0 on the right.
  10. Oct 2, 2011 at 2:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah well thanks jason. So I shall revise my statement. Easy way would be to sway in an entire ted e locker. Finding one though is a different story..
  11. Oct 2, 2011 at 2:17 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    To swap in an e-locker, you need the rear axle housing and the third member. If you're a 4x4, the gear ratio in the new third needs to be the same as your old one.
  12. Oct 2, 2011 at 2:20 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    have you though about a lockright locker?
    $350 and it pops right in
  13. Oct 2, 2011 at 2:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Correct. As most trds are 4.30 and opens are 4.10
  14. Oct 2, 2011 at 2:29 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    I have a similar thing in the works. At least I hope. I have a Trd sport, wanting to swap an axle from a member who has an e locker rear. Straight axle swap. What would need to happen to make it actually work in my truck?
  15. Oct 2, 2011 at 2:33 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
  16. Oct 2, 2011 at 2:50 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    :popcorn: Gots me some salty snacks waiting for the answer!
  17. Oct 2, 2011 at 2:57 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    OK,
    swap out your entire rear end is going to be cheaper than buying an ARB ???
    If you SHOP dealers for an ARB set-up they can be had for decent $$$$$..
    Who would not CUT a deal with a customer about to purchase $12-1500 of NEW parts and installation ????;)
    You then have a NEW selectable locker and On -board air with ARB's warranty behind it....:cool:
    Now the arguement will be made that an E-locker is Toyota and tested tough BUT you still have to re-install the locker( or rear-end), switches,wiring harness and the little misc. that always happens....
    Again ,your choice but out of the 2 ....ARB just seems easier.....
    Then again complicate it more and choose any of the other "Locker combo's" out there too.....Auburn gear as an example.....:rolleyes:
    RiceBurrito likes this.
  18. Oct 2, 2011 at 3:01 PM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    It is going to be significantly cheaper. Literally swapping axles cheap. Now the only thing I do not know about, it wiring. That is my true question. I know it will bolt directly up. But will it wire up easily????
  19. Oct 2, 2011 at 3:03 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Manual transmission TRD's are 4.10's
    Swap the axle and manually wire up the elocker to a switch.
    Again, as I posted earlier, review this how to.
    In the middle is the information on wiring.
    QMEDJoe likes this.
  20. Oct 2, 2011 at 3:04 PM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Damn. That's it? But is it worth it? I have an LSD rear right now, and legit have never gotten stuck
