Diff in lowering blocks and lifting blocks?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jeff6001, May 10, 2009.
  1. May 10, 2009 at 8:54 PM
    jeff6001
    jeff6001 [OP] Well-Known Member
    San Antonio, TX
    99 trd prerunner
    I'm asking this question cause their both the same size block, 3", same u-bolts and $40 cheaper. Whats the difference besides a different location?
  2. May 11, 2009 at 4:21 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I would assume you're referring to the suspension.
    Lift blocks go inbetween the leaf springs & axle perch on trucks with the springs OVER (ontop) the axle tube. The 4WD & Prerunner trucks run with spring-over axle.
    I'm not accustomed to the lowering culture.... so don't quote me on this. I'm just guessing.
    I would assume the lowering blocks go inbetween the leaf springs & axle perch on trucks with the springs UNDER (below) the axle tube. The 2WD trucks with 5 lugs have the springs under the axle.
  3. May 14, 2009 at 7:13 AM
    jeff6001
    San Antonio, TX
    99 trd prerunner
    So how does it lower it?
  4. May 15, 2009 at 7:25 AM
    reddoublecab
    reddoublecab Active Member
    Riverside, California
    There is no difference, same blocks can be used for lifting or lowering. If you want to lower 3", the blocks go between the rear leaf springs and axles.....hence shifting the rear axle up 3".
  5. May 16, 2009 at 7:27 PM
    jeff6001
    San Antonio, TX
    99 trd prerunner
    So how did you lower yours? Where did you put yours to lower it?
  6. May 16, 2009 at 7:39 PM
    reddoublecab
    Jack up truck, put on jackstands (Under frame). Then put jack under rear end. Unbolt the u-bolts on each side, jack up rear end and insert blocks between leaf springs and axle mounts. Lower jack so rear end is resting on blocks, re-assemble with new u-bolts provided in kit. Jack up rear end again, remove jack stands from under frame, lower jack.....your done.
  7. May 16, 2009 at 7:46 PM
    jeff6001
    San Antonio, TX
    99 trd prerunner
    And that will lower it or raise it?
  8. May 16, 2009 at 7:47 PM
    2toys
    2toys Well-Known Member
    Los Angeles
    01 Red Hot Double Taco
    Bounce the rear end (from jack) and tighten u-bolts again. Then after a couple weeks, check the u-bolts one last time.
  9. May 16, 2009 at 8:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you have a Prerunner, or 4x4, the blocks will raise the truck. If you have a 5 lugger, they will lower it. Orerunners and 4x4's have a spring over axel set up.
  10. May 17, 2009 at 5:32 AM
    Janster
    Jandy
    Lancaster, PA
    You have a Pre-runner, so the leaf springs are ONTOP the axle tube (Spring OVER axle).
    Do some research on Spring Under axle conversions or flipping the leaf springs upside down - if you really want to lower it. It'll be tons of work.
    You're better off selling it and buying another truck.
  11. May 18, 2009 at 9:36 AM
    jeff6001
    San Antonio, TX
    99 trd prerunner
    NO!!! I want to raise it. I just saw 3" lowering blocks for $47 with u-bolts and $7 shipping. and right next to them they had lifting blocks for $72?
  12. May 18, 2009 at 10:14 AM
    Janster
    Jandy
    Lancaster, PA
    That's a pretty large price difference between the two.
    So, to be on the safe side....I wouldn't buy the lowering blocks.
    You might want to compare the difference in the shape of the U-bolts between them. I'm gonna guess, the U-bolts are gonna be different (rounded and squared).
  13. May 18, 2009 at 7:22 PM
    jeff6001
    San Antonio, TX
    99 trd prerunner
    Have to see what bolts come with it. But thanks for the help.
