Diff drop, is it worth it?
Discussion in 'Suspension' started by PFD FIRE, Aug 10, 2018.
  1. Aug 10, 2018 at 7:50 PM
    PFD FIRE
    PFD FIRE [OP] Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    Question: I’m about to get 33s and ICON suspension installed on my 2nd gen Tacoma you think I would need a diff drop/spacers to keep the drive-line and CV angle closer to stock? I would hate to stress those components. Off Road Warehouse in San Diego recommends I get them installed but I’ve been hearing nothing but negative responses on the diff drop.
    Anybody out there with experience having a diff drop installed on there tacoma? Do they really make a difference?
  2. Aug 12, 2018 at 12:34 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    I thought diff drops on a 2nd gen were a no-no?
    inwood customs likes this.
  3. Aug 12, 2018 at 12:39 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Diff drop is Worthless on 2nd gens.
    Now, rear end shims or a carrier bearing drop are beneficial at times.
  4. Aug 12, 2018 at 2:04 PM
    PFD FIRE
    David
    San Diego
    Thank for the heads up, lots of people are telling me not to do a diff drop on the 2nd gen tacoma
  5. Aug 12, 2018 at 2:25 PM
    License2Ill
    Ian
  6. Aug 12, 2018 at 2:34 PM
    PFD FIRE
    David
    San Diego
    Yeah! I’ve seen that post. Part of the problem is that he had those things protruding from his skid plate, and because of it, it got cought against a rock or something. I know I would have issues installing my existing skid plate if I go with the diff drop. So it’s definitely a no go on the diff drop for me
  7. Aug 12, 2018 at 2:49 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    I don’t know if I should admit this or not but I have them on my truck. I bought most of my parts from total chaos and they sold them to me. At the time I didn’t ask if they were recommended or not but they didn’t say not to use them on my 2nd gen. I’ve read many posts about how they’re a waste and have considered removing them but when it comes down to it I keep forgetting about it. I’d call total chaos and ask them how then feel about them. The guys who work there use these parts on there trucks and would value their opinions. My truck just doesn’t get driven much but when it comes down to it I may remove them.
    PFD FIRE[OP] likes this.
  8. Aug 12, 2018 at 7:08 PM
    PFD FIRE
    David
    San Diego
    I just don’t see the benefit of dropping the diff on a 2nd gen tacoma. I just hear more bad then good from these things installed
  9. Aug 12, 2018 at 7:19 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    I’ve owned my ‘06 for 12 years. Lifted it in ‘08 I tore through 3 boots in a couple years then put in a diff drop. It’s been around 7-8 years since dropping it and I haven’t torn a boot. Everyone that says don’t do it are regurgitating something they heard from someone that knows someone that knows something or they are the guy with the shitty skid plate design. You’ll hear “it doesn’t improve angles, it just rotates the diff”. That’s not true. When you lower the front of the diff while installing you can see the angles decrease. It’s cheap, and it worked for me. There are skids on the market that work with it as well, I’m fully skidded. Wheel all over. Ran 6 miles of the Rubicon last weekend.
  10. Aug 12, 2018 at 7:32 PM
    dustin19d
    Dustin
    Washington
    I see you’re a fire fighter. Thank you! Even if you don’t work wild land fires. Northern California is so fucked right now. Last week I was in Tahoe and Lasen, never seen so much smoke. I’m in Angelo Nat Forest tonight, headed out to Tucson tomorrow. They had a huge staging area off 101 in Ukiah for the Mendocino Complex Fire, hundreds of tents along the side of the Highway for the guys.
    maxtherat and PFD FIRE[OP] like this.
  11. Aug 12, 2018 at 9:55 PM
    PFD FIRE
    David
    San Diego
    Thanks for the appreciation. Our department sent two crew B3762 and OES 308. One went to Ferguson the other Mendocino. I work on a truck company so I stay in my district
    dustin19d likes this.
  12. Aug 13, 2018 at 12:11 AM
    License2Ill
    Ian
    Not trying to dispute your claims. But a few factors will come into play with cv boot angles. Primarily if you upgraded your leafs for increased weight (weight that I see you have in the back there).
    IOW, have a 2" (in the rear) raked stock truck. Put a 1K# load of concrete in the bed. What are the front springs doing? That's right, cantilevered by weight, the front springs decompress giving you undesired lift. Even more so with warn out springs not capable of handing any increased weight. That in turn increases boot rub and demise of your CV boot.
    You by chance upgrade your leaf pack 4-6 years ago?
  13. Aug 13, 2018 at 12:50 AM
    dustin19d
    Dustin
    Washington
    I hear you. Yes, I’ve beefed up the rear over the years to keep the stock rake. But a diff drop helps in the above scenario...?
    maxtherat likes this.
  14. Jun 10, 2024 at 1:31 PM
    IA DIY
    IA DIY Well-Known Member
    Iowa
    2008 DCLB 4x4
    Good info! I skipped the diff drop on my 2008…would only have exposed the diff to xtra damage.
  15. Jun 10, 2024 at 3:44 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Old thread but here's my experience. 2007 with a 2" lift. Without the drop a few boot ribs hit... with the drop they don't. Been on for 17 years with zero issues... still on the original boots. No rock crawling... just light offroad.
    IA DIY likes this.
