DieHard, Interstate or Optima?
Discussion in '1st Gen. Tacomas (1995-2004)' started by vin510, Oct 10, 2019.
  1. Oct 10, 2019 at 1:49 PM
    vin510
    vin510 [OP] Active Member
    Vin
    1995 Toyota Tacoma SR5
    Curious which battery is better for 1st gen? DieHard, Interstate or Optima?
    Thanks!
  2. Oct 10, 2019 at 2:35 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    All 3 are good brands. I like to use the biggest size with the highest CCA that will fit.
    suaveflooder and JC15Taco like this.
  3. Oct 10, 2019 at 4:05 PM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
  4. Oct 10, 2019 at 4:44 PM
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    Interstate Mega :thumbsup:
    cruiserguy likes this.
  5. Oct 11, 2019 at 12:02 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The brand that has the best customer service in your area.
    Since the company I work for is a Interstate dealer I might be somewhat partial .
    cruiserguy, CS_AR and vettehigh like this.
  6. Oct 12, 2019 at 8:00 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
  7. Oct 12, 2019 at 8:24 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    In one of my other car forums, we have a significant number of members from Canada and Alaska. The batteries that come up during extreme temperature discussion are brands named Northstar and Odyssey. If you're out in arctic weather, I can see how you want the best battery you can get.
    Looks like Northstar and Odyssey are in the $280 to $300 price range. Both batteries have loyal customer followings. I would be up for trying one if I had a local dealer.
    https://www.techbatterysolutions.co...MIyMCjoP-W5QIVEI_ICh2TZAocEAQYAiABEgIDH_D_BwE
  8. Oct 12, 2019 at 2:20 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Depending on your use, Optima is going to be the "best" but they cost like 2x as much as the others.
    Most batteries are pretty much the same anyway, just get the one that fits your budget and your CCA needs. Get one with a 3+ year warranty.
  9. Oct 12, 2019 at 8:32 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    If you go with an AGM or Optima battery make sure you keep it topped off with a trickle charger designed for AGM batteries, at least once a month. I run the X2 Power battery from "Batteries Plus" - two Arizona summers and still going strong. The true test will be what happens in the next couple of years.
    I had a bad experience with my Odyssey Extreme - only lasted 8 months before it died, but it's hard to tell if I just got a bad one or if something else caused the problem. I would give Odyssey another try if anyone sold them locally.
  10. Oct 13, 2019 at 1:12 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Dosent 4wheeler parts and desert rat carry them?
  11. Oct 13, 2019 at 7:38 AM
    Glamisman
    Glamisman Well-Known Member
    CS_AR likes this.
  12. Oct 13, 2019 at 8:00 AM
    1997tacomav6
    Denver
    Optima
    jammer likes this.
  13. Oct 13, 2019 at 8:13 AM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    Northstar
  14. Oct 13, 2019 at 8:23 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I’ve got a sears diehard platinum (rebranded Odyssey) it’s been in my Tacoma when it was running and now my Avalon. 6 almost 7 years later the things still testing good at 960 cca and it’s been through every winter.
    My optima before this one my father put in and it lasted 10 years before it failed.
    AGM is the way to go. Be it spiral or flat mat
    CS_AR likes this.
  15. Oct 13, 2019 at 8:26 AM
    1997tacomav6
    Denver
    My Optima last about 6-7 years so it seams, on my 3rd one in 21 years as a daily driver
    otis24 likes this.
  16. Oct 13, 2019 at 8:27 AM
    Empty_Lord
    Dan
    I was going to run another optima but sears was closer and the truck was dead in -20.. so yea. Been happy though
    Not fun doing the battery out in that cold though. My damn tools were frozen
  17. Oct 13, 2019 at 9:20 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    That’s a solid history.
    My red top just died after 2.5 years. It got replaced under warranty. I think It got deep cycled a couple times so might not have been the battery. I haven’t driven my truck in about 3 months and was starting it from time to time and one day-dead. I charged it and a few days later dead again. I’m leaving the new one unconnected until I’m driving the truck again.
    what are the warranties like on each battery? Optima red top is 3 years. Blue top is 2 years.
  18. Oct 13, 2019 at 10:18 AM
    ryans4x4
    ryans4x4 Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    Interstate Batteries, you can find them almost anywhere even in the smallest of towns if you travel and have problems with it and need to get it warrantied.
    CS_AR likes this.
  19. Oct 13, 2019 at 12:31 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Did you drill out your aluminum hold down to use the stock j-hook? The one that comes with those aluminum hold downs are kind of flimsy.
  20. Oct 13, 2019 at 12:34 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Odyssey is the shit!
    CS_AR[QUOTED] likes this.
