Did Toyota fix the leaking coolant bypass pipe on 2020+ models?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by z1288, Sep 9, 2021.
  1. Sep 9, 2021 at 7:00 PM
    z1288
    z1288 [OP] Active Member
    Does anyone know if Toyota fixed the leaking coolant bypass pipe on 2020+ models?
  2. Sep 10, 2021 at 4:05 AM
    z1288
    Does anyone know if there is a version 2.0 of the bypass pipe that's been designed "stronger"?
  3. Sep 10, 2021 at 4:11 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I didn't know the bypass pipe was an issue in the first place. Must not be that common of an issue.
  4. Sep 10, 2021 at 4:19 AM
    z1288
    tonered and eurowner like this.
  5. Sep 10, 2021 at 4:23 AM
    catalina34
    catalina34 Active Member
    Trevor
    Dirty Jersey
    2020 DCLB OR
    ARE Shell
    The pipes are the same on the 20 and 21's per the most recent thread on the matter. Someone did find an all aluminum version used on a Lexus model, but it's not a direct bolt on as you'll have to reconfigure the hose coming out of it iirc You can likely find the thread here with some searching. I don't remember if they figured out a good combination of parts to make it a direct swap
  6. Sep 10, 2021 at 4:28 AM
    z1288
    You would think Toyota would have fixed this problem by now.... That's disappointing, I just bought a 2021. Seems like a ticking time bomb...
    22Coma6MT likes this.
  7. Sep 10, 2021 at 4:29 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    eurowner likes this.
  8. Sep 10, 2021 at 4:30 AM
    catalina34
    Trevor
    Dirty Jersey
    2020 DCLB OR
    ARE Shell
  9. Sep 10, 2021 at 5:03 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I asked a toyota tech i've know for years when i last saw him about any issues on the 2020 before biting the bullet to buy one. Said most issues on the earlier gen3 trucks have been addressed, but for some stupid reason you still have to pull the motor to replace that plastic bypass pipe between the cylinder heads. Just shrugged his shoulders when i asked why didn't they use a cast metal one.
  10. Sep 10, 2021 at 5:06 AM
    zoo truck
    None
    Its more common on older high mileage v6 engines. I don't do a lot of miles per year, and hoping these plastic pipes hold up for the life of the truck before beginning to leak.
  11. Sep 10, 2021 at 5:10 AM
    RedWings44
    Michigan
    There are threads on a lot of things but that doesn't make them common. I'm not trying to be an ass but I'm trying to say it isn't as much of a "ticking time bomb" as you think. I have a 2017 (late 2016) and haven't had any issues so far and I drive a lot. Granted I'm not really high mileage yet, but still. I'm at 53k but the last 40k was put on in the last year and a half, when I purchased it.
    Lt. Dangle likes this.
  12. Sep 10, 2021 at 5:10 AM
    RedWings44
    Michigan
    No problems so far on my 2017 (late 2016) and I drive quite a bit. Fingers crossed anyway.
    Kev250R and shakerhood like this.
  13. Sep 11, 2021 at 5:01 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    That cooling pipe could very well have been a defective batch. Why would you put a problem in your head that isn’t there. These trucks are not ticking time bombs. They are made very well. Just drive it and take care of it maintenance wise the best you can, and don’t read into these things so much.
    You have an awesome truck. Enjoy it !
    Steves104x4 and RedWings44 like this.
  14. Sep 11, 2021 at 5:56 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    61k On my 17, no issues.
    Speaking of time bombs, wait until you read about the timing cover leak. I mean, all modern vehicles are ticking time bombs in one way or the other.
    tonered and shakerhood like this.
  15. Sep 11, 2021 at 6:23 PM
    TruckGuy63
    Gilbert
    New York
    People are ticking time bombs for that matter. You can’t worry about everything
  16. Sep 11, 2021 at 7:08 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Pull the motor ?
    https://www.tacomaworld.com/threads/check-your-3-5l-coolant-pipe.531758/
    Intake manifold. See post #9
    shakerhood likes this.
  17. Sep 14, 2021 at 2:28 PM
    primemover
    primemover Member
    Our old 2016 3.5 Tacoma that used to be driven by the security department of the company that I work for had 194,000 miles on it after 5 yrs. Now our IT guy is driving it and coolant has never leaked and still not leaking from the bypass.
    Edit to add that my wife's 2017 3.5 with 41,000 not leaking as well.
    RedWings44 and tonered like this.
  18. Sep 14, 2021 at 2:31 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I think it was @Stocklocker that said every vehicle has a limited number of revs in the engine? Simple and true.
  19. Sep 14, 2021 at 5:38 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Everything has a limited life span.
    Some longer than others.
  20. Sep 14, 2021 at 5:44 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    It’s not a problem. Just because a couple trucks here and there may have experienced an issue doesn’t mean it’s systemic.
    RedWings44 and eurowner like this.
