Did Rock Lights on the truck - A Different Way
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MR.WaynesWorld, Apr 23, 2022.
  1. Apr 23, 2022 at 5:46 PM
    MR.WaynesWorld
    MR.WaynesWorld [OP] Well-Known Member
    Wayne
    North East Pa
    2021 Black Tacoma Limited
    **** 2021 Mods **** Sokietech No Drill Hood Struts (Replaced) Color Matched Mirror Caps Color Match Door Handles SUPAREE LED Side Mirror Turn Signal Lights AVS Dark Smoked Hood Bugflector (Removed) Meso Black Interior Door Handles AVS Window Vents AUTOGINE Super Bright 6000K White LED Vanity Mirror Lights 3D Rear Tacoma Letters Matte Black OEM Blacked Out Emblems OEM Black Trim around Fog Lights Full BedRug AMP Research Bed Extender LoMax Tonneau Cover (Replaced) RBP 77-Spike Wheels 18X9 (Replaced) Nitto Terra Grappler G2 tires 285/60 (Replaced) Blacked out Toyota emblem on steering wheel Night Shade Front Grill (Replaced) Dark Tint Front TSS Emblem (Replaced MBRP Dual Exhaust KTJO Door Pod lighting Window Tint, 5% in the back 30% up front MESO Chrome Delete center console MESO Chrome Delete Vent Rings **** 2022 Mods **** Cali Raised Steel Front Skid Plate (Replaced) Ice Blue Map and Dome LED bulbs Rek-Gen XL Mud Flaps - Black on Black All interior trim painted Matte Black with Flat Clear Coat Aqua Blue Foot Lights - Front and Rear MESO Switch Panel Custom Layout MESO 3 Switch Overhead console panel MESO Chrome Delete Climate Control Rings UpTop Bravo Roof Rack Extreme LED 38 inch LED Light Bar in Roof Rack Diode Dynamics LED Strip Grill Lights Meso Ultimate Tail Lights (Replaced) Rock Lights - 8 Cyclone V2's (Replaced) UpTop Roof Rack Grab Handles UpTop Scene Pods with Baja Design Rock Lights Diode Dynamics Elite Series Fog Lights CaliRaised Stealth Bumper 30 inch Infinite Offroad LED Light Bar X2 Zeak 10,000 Winch KTJO Driver's Side Grab Handle LambTek Winch Switch Boomers "faux" TRD Pro Shift Knob Tacoma Lifestyle Smoke Third Brake Light Blacked out Instrument Panel Lens Diff Drop Dobinson's Suspension, Front Coil Overs, UCA's, Rear Shocks and Leaf Packs DB Customz Grill, Color Match with RGBW LED Letter Lighting **** 2023 Mods **** PowerTrays Tray with Busemann Fuse Relay Pioneer DMH-WC6600NEX Maestro RR2 SiriusXM SXV300 Tuner BoxWare Anti Glare HU Screen Protector Varity of cables and adapters Focal ACX 690 Front Speakers (Replaced) Focal ACX 165 Rear Speakers (Replaced) Diode Dynamics Stage Series Rock Lights - 3 in each wheel well Diode Dynamics Flush Mount Brackets Revolver X4s Tonneau Cover UpTop Roof Rack Grab Handles V2 Raceline Compass 17X9 wheels Toyo Tires Open Country A/T III 275/70R17 Tacoma Beast Infinity Tail Lights Taco Clout Wide Angle Convex Mirrors - Heated + Turn Signals + BSM KTJO Powered Folding Mirrors **** 2024 Mods **** Lighting Trendz Glow LED lights in Grill Lettering Cali Raised Cat Shields The Sub Box Shop Sub Amp box Rockford Fosgate 10 inch 4 ohm Dual VC Sub Kicker 3.5 inch speakers in dash (Replaced) Auto Harness House harness adapters for speaker wires Alpine PXE-C80-88 8 Channel Amp. Polk Audio DB 6502 Front Doors Polk Audio DB 6502 Tweeters in Dash Polk Audio DB 652 Rear Doors Hidden LED's in Bed Charvonia Design Bed Rail Tie Down Anchors Charvonia Design Bed Tie Down Anchors Charvonia Design Bed Floor Tie Down Anchors Charvonia Design Billet Battery Tie Down Redline Hood Struts TRD Pro Hood KITT Scanner LED in Hood Scoop Cali Raised Aluminum Skid Plate
    Finally finished up my rock lights.
    I have 8 Cyclone V2 under the truck, one in each wheel well and one under each door.
    Wired them up using the switched ground from the Dome light so when the inside lights dim down so do the rock lights and grill lights.
    Also did a DD Grill Lighting and wired the same.
    And as the topper, I can have all of them light up, only the grill lights, only the wheel lights, only the door lights or any combination of them I want. Plus if we're out and about at night I can luminate the same without the truck running or on Acc.
    Made my own brackets for the wheel wells and used Runnin 4 Tacos Cyclone V2 brackets for under the doors.
    20220424_002215138_iOS.jpg 20220424_002227740_iOS.jpg 20220424_002239849_iOS.jpg
  2. Apr 23, 2022 at 10:50 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    ALIENS!:alien:
  3. Apr 23, 2022 at 11:31 PM
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    So unnecessary and so damn cool lol
    GarlicFarts likes this.
  4. Apr 23, 2022 at 11:37 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Kev250R likes this.
  5. Apr 24, 2022 at 4:03 AM
    MR.WaynesWorld
    Wayne
    North East Pa
  6. Apr 24, 2022 at 12:43 PM
    toku58
    Mall Crawler!
    3??? Why 3?
    You only need on that is triggered by the ground from the dome lights. And you can run a switch with power so the rock light work as they should.
  7. Apr 24, 2022 at 4:21 PM
    MR.WaynesWorld
    Wayne
    North East Pa
    Because I can switch off any so they will not come on. So I can have just the lights under the doors come on when I unlock it. If I did one relay I could not do that. Cost me $10 for the two other relays and maybe another $10-15 for the wiring.
    Just wanted something no one else had or thought of.
    toku58[QUOTED] likes this.
  8. Apr 24, 2022 at 4:43 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Got any pictures of the mounts?
    I hav six cyclone V2 rock lights on mine and have been curious on how other members mount theirs. Also did the harnesses reach all the way to the back or did you have to modify it
  9. Apr 24, 2022 at 5:09 PM
    MR.WaynesWorld
    Wayne
    North East Pa
    I’ll get some pictures of the wheel well mounts for you. Here is the mount under the doors.
  10. Apr 24, 2022 at 5:10 PM
    AmateurTaco1313
    ROK
    Enough for now
    Nice! Very clean I gotta take a day and clean up my wiring all over.
  11. Apr 24, 2022 at 5:10 PM
    MR.WaynesWorld
    Wayne
    North East Pa
    Didn’t have a harness. For what I wanted to do I made my own.
  12. Apr 24, 2022 at 10:19 PM
    4x4.StatlerTaco.XVI
    4x4.StatlerTaco.XVI Well-Known Member
    Los Angeles
  13. Apr 25, 2022 at 3:17 AM
    MR.WaynesWorld
    Wayne
    North East Pa
    Front mounts,
    Rear Mounts,
  14. Apr 26, 2022 at 8:21 AM
    caribe makaira
    Caribbean, Puerto Rico
    How much relay chatter do you get? relays in the engine bay?
  15. Apr 26, 2022 at 9:23 AM
    MR.WaynesWorld
    Wayne
    North East Pa
    @caribe makaira No chatter when I unlock my truck. Yes relay's are located in the engine bay.
    Relay's are wired like this.
    From what I have read and researched with my switch turned off, in the cabin of the truck, pin 87a is connected to pin 30. So as soon as the switched ground is activated, truck unlocked or doors opened, the lights come on and no relay chatter. If I turn on the switch in the cabin I do hear a click of the relay connecting pin 86 to 30.
    I did not tap off the constant power for the dome light. I used separate constant power from my fuse block located on top of the fuse panel in the engine bay. One constant power line for the grill lights and one constant power line for both wheel/door LED lights. Both are fused at 5 amp.
  16. Apr 26, 2022 at 9:34 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Good for inspecting rocks or looking for oil leaks, I guess.
  17. Apr 26, 2022 at 2:21 PM
    caribe makaira
    That one is fine. A SPDT switch would do the same.
    The issue might be the added rock lights
    The OEM dimming circuit on the Tacoma only shows the maps lights, overhead lamp and key ring illumination sharing.
