Did I damage my transmission running with low fluid?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, Dec 30, 2019.
  1. Dec 30, 2019 at 11:58 PM
    Tacomaislife
    Tacomaislife [OP] Well-Known Member
    Texas
    2002 tacoma trd
    I did flush on my transmission and forgot to check dipstick if it was full before I ran the truck around my neighborhood streets.i just remembered and checked it this morning to see the level and noticed it was missing 2.5 quarts. do u guys think I did any damage I already put those 2.5 quarts back in but I'm worried i damaged my transmission. The fastest I went was 25mph around the block and it sounded and felt fine yesterday .
    GQ7227 likes this.
  2. Dec 31, 2019 at 4:58 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    if its AT it should be 0k since you did not go very far or fast,
    just keep an eye and ear on it and check the fluid level occasionally
    good thing you caught the low level before it was driven more!
    MalinoisDad likes this.
  3. Dec 31, 2019 at 8:46 AM
    Willstutz7
    Willstutz7 Self-proclaimed, unjustified expert
    Will
    2003 TRD Off-road Extra cab V6 Prerunner
    3” allpro leaf springs; Bilstein 5100 shocks all around; thrush welded muffler back system; deck plate mod; 1.5” wheel spacers; rear led bumper light pods
    If it was and still is shifting alright and not making any noises you’re probably in the clear. I’m not a transmission expert though. I’d say since it didn’t try to lock into o/d and wasn’t driven long or hard then you’re probably ok
    Tacomaislife[OP] likes this.
  4. Dec 31, 2019 at 9:32 AM
    Tacomaislife
    Texas
    2002 tacoma trd
    Yes a auto transmission it was messing exactly 2.5 quarts I drove it to day did notice a slight hard shift on 1st I'm going to put in some bg transmission conditioner
  5. Dec 31, 2019 at 9:37 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I'd say you are fine. The A340 trans is actually pretty tough. And there's actually, like 13 quarts or fluid in there with the torque converter and everything. 2.5 quarts low for half a day, or so, isn't that big of a deal.
    You'd have experienced slippage if anything was real bad.
  6. Dec 31, 2019 at 9:58 AM
    Tacomaislife
    Texas
    2002 tacoma trd
    That makes me feel better I was kinda scared I missed something up good thing I only drove it like 10 minutes going between 15 20 mph
    six5crèéd and GQ7227 like this.
  7. Dec 31, 2019 at 10:14 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    10 minutes?
    Ya, I would absolutely not worry about that. That's actually not even much different than just running it up to operating temp to correctly check the fluid level.
    MalinoisDad and six5crèéd like this.
  8. Dec 31, 2019 at 3:13 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Quick question about checking transmission fluid level how long do I leave it running before checking it ?
  9. Dec 31, 2019 at 3:22 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    You want to leave it running until (at least) your coolant temp is at normal operating temp... then foot on the brake, slowly go from P to R to D to 2 to L and then slowley from L to 2 to D to R to P (pausing 5 or 10 seconds in each gear) then check fluid level on dipstick.
    Dipstick will have two levels.... lower is cold. That is for when filling the trans. It's the minimum amount you should really have in the trans... the upper level is the hot level. The hot level is the one you want.
  10. Dec 31, 2019 at 3:27 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Thank you
  11. Dec 31, 2019 at 3:33 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    One more thing. If you have to add fluid you will be filling through the dipstick hole so the fluid will be hard to read on the dipstick if you don't wait a minute or so for any residule on the walls of the dipstick tube to settle.
  12. Dec 31, 2019 at 3:34 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    is about 15 minutes okay
    Is it okay to fill when the trucks on
  13. Dec 31, 2019 at 3:35 PM
    Tacomaislife
    Texas
    2002 tacoma trd
  14. Dec 31, 2019 at 3:37 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Letting it run for 15 minutes is no problem
    YES, you WANT the engine running while checking/filling transmission.
  15. Dec 31, 2019 at 3:41 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Last time I filled my trans was when I swapped in this transmission. The truck ran for 30-40 minutes while I checked levels and went through gears and filled the trans.
    Don't be worried about letting it run "too long"... the only thing that makes it "too long" is if you run out of gas. You can leave it running as long as you need it to run, to get the fluid level right.
    Also, make sure you're on relatively level ground while checking fluid level.
  16. Jan 1, 2020 at 2:53 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Well then just my luck I tried screwing back the bolt on my 2004 Tacoma automatic and I tried using that tourcrench and I used 15 foot pounds well It keep turning and it didnt stop so I tried unscrewing it and well it wont come off now like what did I do wrong I first tightened it with my fingers then used the torch wrench at 15 foot pounds did I do it wrong I need a transmission pan now smfh
  17. Jan 1, 2020 at 3:14 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    You're talking about your drain plug?
  18. Jan 1, 2020 at 3:17 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Yeah wont come of after I toque it to 15 th e dame wranch didnt click so I stop turning and I tried taking it off to see if I did stripped and well I guess it did because it wont come off now smh
  19. Jul 19, 2022 at 5:24 AM
    Ž@¢K
    Ž@¢K Farts a lot..
    Ky
    2003 Tacoma TRD 4dr Prerunner 4wd conversion
    6”rough country lift, 35” bfg mud terrain, step bars, home made solid 5" bull bar frame mounted top and bottom with gussets ( used an excavator to completely suspend the truck in the air held only by the bull bar), 180k, no rust, no leaks, no cel's, no issues. 4wd conversion with front and rear e-lockers.
    I just did same crap, i changed tranny filter and only had 4 quarts (because everywhere says thats all it takes, WRONG!!). So after hot and running through gears (at..) i saw the level was well below the cool mark while warm.. tried driving to the store down the road but it was real timid about going into 1st gear.. once it grabbed 1st it was fine but only got harder and harder to grab first.. only went 25mph tops and made it a mile before i said nope, and turned back.. was worried i boogered the tranny also.. just did the timing belt, water pump, seals, valve cover gaskets and all that plus oil change and fuel filter (which sucked cuz my dumbass didnt depressurize the system..).. so yea.. also developed a slight tick but think i just overtightened a belt or something cuz it smelled like burnt rubber when made it back.. hoping is only a belt anyway.. and not that tranny.. or the timing belt somehow.. dunno.. is always my luck though.. sonething always comes back to give me a swift kick to the berries..
  20. Jul 19, 2022 at 5:32 AM
    Itsgottabeyourbull
    Itsgottabeyourbull Well-Known Member
    Tulsa Oklahoma
    20 Tundra SR5 TSS/ 02 Tacoma DCSB TRD OR
    You’re completely fine. If you drove it for 10K miles yeah you’d probably have issues… around your neighborhood.. lol you’re okay.
