Did any of you remove your plastic bed rail caps before installing your shell?
Discussion in 'Tonneau Covers, Caps and Shells' started by tacotmac, Mar 26, 2017.
  1. Mar 26, 2017 at 3:00 PM
    tacotmac
    tacotmac [OP] Well-Known Member
    Athens, GA
    '12 DCLB
    Thinking about doing this to get the shell a little lower down on the truck for a better fit.
    Good idea/bad idea?
  2. Mar 26, 2017 at 3:03 PM
    no vtec 4me
    no vtec 4me Well-Known Member
    Kevin
    West Chester, Pa
    2017 Tacoma TRD Sport
    I would say bad idea, as the caps are designed to sit on top of the rails.
  3. Mar 26, 2017 at 3:04 PM
    tacotmac
    Athens, GA
    '12 DCLB
    thats kinda what i'm thinking as well, but just seeing if anyone had tried it
  4. Mar 26, 2017 at 3:08 PM
    Abragus
    Abragus Well-Known Member
    Adam
    Suffolk, VA
    I didn't want the cap to be riding on the paint/metal so I didn't want to remove the caps.
  5. Mar 26, 2017 at 3:11 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    I did remove my bed rail caps and waterproof underneath and reinstalled. Made my cap more waterproof going through car washes.
    BassAckwards and henryp like this.
  6. Mar 26, 2017 at 3:12 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    I did both ways on my second gen. Looks cleaner without, but worked just as well with. You'll just need extra insulation at the front if you leave them on (there will be a gap since the caps sit higher than the front rail). There are rubber strips you should get either way. Found mine on Amazon. Good luck.
  7. Mar 26, 2017 at 3:23 PM
    MrOlearhy
    MrOlearhy One day at a time. Sometimes minute by minute.
    Tedd
    NW corner
    Small useful for me stuff.
    KB Voodoo and Tsinajinii like this.
  8. Mar 26, 2017 at 3:28 PM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
  9. Mar 26, 2017 at 4:14 PM
    MrOlearhy
    Tedd
    NW corner
    From memory about 3/16ths. They are beef. The tailgate caps adds real weight to it. One other thing I'm looking at adding is the Total Chaos bed stiffeners To prevent bed spread.
    http://www.chaosfab.com/2005-2015-Tacoma-Rear-Channel-Bed-Stiffiners-48675
    One of the most truthful things I've seen posted is once you've joined this site your screwed. At least your wallet is. Lol
  10. Jun 18, 2017 at 7:23 PM
    03maurderman
    03maurderman Well-Known Member
    There is no way to get a good seal with the rail caps on...I mean does anyone think that gooping the front panel with silicone, foam, or any other crude way to fill that gap a good job? Getting that Cap/topper to fit & seal, is the most important step in the installation....My question is there an aftermarket thin smooth rail cap that will give a good proper base on both sides and the front bulkhead? Voodoo Fabrication makes a 3/16 steel cap which looks good, but its heavy & still leaves the problem with the bulkhead....
  11. Jun 19, 2017 at 6:10 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Our side rail caps are 1/8" thick.
  12. Jun 19, 2017 at 8:41 AM
    03maurderman
    Voodoo....Thanks for the correction on the thickness....Do you offer the cap that goes on the bulkhead?.....Can these rails be picked up at your location?
  13. Jun 19, 2017 at 8:42 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    We don't offer the cap for the bulkhead.
    Yes, you could pick them up at our shop.
  14. Jun 19, 2017 at 8:52 AM
    G.T.
    G.T.
    CONUS
    Removed mine.
  15. Jun 19, 2017 at 8:56 AM
    03maurderman
    Can call you but, in case others are watching this thread....Is there a reason why you don't offer the cap for the front bulkhead? Seems you have the tail gate covered & the front is where all the seal issues are.....A full uniform perimeter would solve the seal issue best?
  16. Jun 19, 2017 at 9:00 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I don't think anyone ever asked for that piece.
  17. Jun 19, 2017 at 9:51 AM
    03maurderman
    I find it odd that no one has ever asked for the bulk head piece...after they installed your side rails, what did they do about the 1/8 gap in the front? Which goes back to my original statement....If your side rail caps are 1/8 in thickness, this leaves a 1/8 gap at the bulkhead.... So filling that gap with silicone, foam, or strips of rubber from Amazon..is not a correct solution, at least not in my book....If you have a solution for the bulkhead I'd like to consider it, before buying the side pieces.....
    As an FYI, I'm ordering an ARE commercial, wedge, barn door cap, insulated, on & on... Its going to run around $3500. and I'm shopping it...Not for price, in as much as my comfort level in the dealer....One of my questions I ask is "What do you do about the gap at the bulkhead"? assuming I leave the OEM caps on the bed....I get some pretty wild answers, along with "Oh Toyota's are the most problematic for water leaks" but most tell me, No problem, we fill the space up by doubling up in the double sided tape, silicone, and what ever it takes....Guess what...I'm not buying the cap from them....Yeah its cost $$$ to do the job right, and I'm not balking about the $270. for your side rails, well worth it, if the cap sits on the bed correctly, and it can't, if you don't have the piece for the front.... If you don't do the job right, then don't do it at all.... That's my rant......
  18. Jun 19, 2017 at 9:55 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I'm not really sure, but it hasn't been a concern as far as I know.
  19. Jun 21, 2017 at 2:48 PM
    red79cj7
    red79cj7 Well-Known Member
    Middle GA
    2016 DCLB 4x4 TRD OR & 2011 DCSB TRD OR
    2016 - Toytec 3" Coil & AAL Lift, 265/75/16 BFG KO2s, 100XQ Topper w/Thule Tracker II Racks, Pop N Lock Tailgate Lock 2011 - Leer 100XQ Topper w/Thule Tracker II Racks, Pop N Lock Tailgate
    left my side caps on with my Gen 2 with a Leer 100XQ. I wasn't there when the dealer put it on, but I would assume they applied weather stripping to both sides and bulkhead. Very little leakage in bed... isolated to somewhere around the bulkhead corners.
    I will be selling the shell soon and will see what's underneath when I take it of.
  20. Jun 21, 2017 at 2:50 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I thought about it, but I opted to leave them on because the installer said to leave them on and the shell was designed to work with them. Waterproofing and looks aren't a huge deal because Snugtops have a lip that covers the joint, I can't see the bed rail cap anyway. Your bigger problem with waterproofing will be around the tailgate anyway.
