Did a retrofit and now the headlights wont turn off
Discussion in 'Lighting' started by stlntaco, Dec 25, 2015.
  1. Dec 25, 2015 at 5:41 PM
    stlntaco
    stlntaco [OP] Well-Known Member
    Jake
    California
    ̿̿ ̿'̿'\̵͇̿̿\з= ( ▀ ͜͞ʖ▀) =ε/̵͇̿̿/’̿’̿ ̿ ̿̿
    I have a 2014 Tacoma and i did a retrofit on my headlights with stuff through the retrofit source. I got everything wired up and things were working perfectly. When i started the truck the headlights wouldn't turn off at all. It doesn't matter what you do with the headlight controls they will stay on. When the truck is off you can turn the headlights on and off without issue. Anyone have any ideas on what might be wrong?
  2. Dec 25, 2015 at 10:03 PM
    snowbrdd
    snowbrdd Well-Known Member
    Seems like your truck is set to have the headlights operate as daytime running lights. You may have to do some sort of mod to disable that. Not too familiar with Tacomas, so it's just a suggestion.
  3. Dec 25, 2015 at 10:08 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    If you disco the battery and reconnect do they turn back on?
    Maybe you wired a constant hot power source on accident?
  4. Dec 25, 2015 at 11:33 PM
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    May be its a retrofail not retro fit. Your relay is malfunction replace it with auto zones relay it may solve the issue, other wise your girl is programmed to to drive with headlights on
  5. Dec 26, 2015 at 7:24 PM
    stlntaco
    Jake
    California
    I have the base model so I'm pretty sure i don't have an auto headlight feature. I have a moto control wiring harness that is supposed to just basically plug right in and then ground on both sides of the engine bay.
  6. Dec 28, 2015 at 9:20 PM
    Valsmere
    Valsmere Well-Known Member
    Brian
    New Jersey
    EXPENSIVE
    tail gate lock, rear view mirror bracket, hood hinge brackets, and the list grows.
    Ok this may sound a little weird but, mine was acting all weird today also. Mine would just turn on after the truck was run and shutoff. After about 20 minutes they would pop back on even the truck was off, as well as the headlights. So I pulled the bulbs out and my drivers side was messed up, aka the blue wire was cracked and a middle section in the bulb was all clouded over. So I'm thinking blown. I'll have to pop in new bulbs to see if that remedies the problem.
    For shits and giggles check yours out.
    SEE UPDATE BELOW
  7. Dec 29, 2015 at 1:05 PM
    Valsmere
    Brian
    New Jersey
    EXPENSIVE
    Update on my situation, it was the motocontroller. Apparently i have the older one and it took a shit on me. So to the op, check yours. Hope this helps out
  8. Dec 29, 2015 at 7:20 PM
    stlntaco
    Jake
    California
    I was thinking it was the motocontroller. Not sure how to check the wiring harness though.:rain:
  9. Jan 4, 2016 at 7:28 PM
    Valsmere
    Brian
    New Jersey
    EXPENSIVE
    Just an update for my situation it was my controller. I hope the op is still watching this thread so it may help him out
    TRSJimmy likes this.
  10. Jan 4, 2016 at 7:48 PM
    stlntaco
    Jake
    California
    I'm still watching:thumbsup: I am going to completely redo everything on Wednesday and inspect the wiring harness.
  11. Jan 4, 2016 at 10:08 PM
    Valsmere
    Brian
    New Jersey
    EXPENSIVE
    Cool let me know just curious
  12. Feb 24, 2016 at 8:33 PM
    stlntaco
    Jake
    California
    So I finally got the new relay tonight and plugged it in. Problem not solved...:( I also checked were the plug that connects to the factory harness and they were all in the right spot. I'm thinking now it has to be the ballasts. If the ballasts dont solve it..I'm stumped...
  13. Feb 29, 2016 at 1:53 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Are you side it's not a wide needing swapped on the factory harness bulb connector? Iirc I had to do this on mine. Because they're negatively switched. But not sure how it works on 2nd gens. Maybe email trs?
  14. Feb 29, 2016 at 8:29 PM
    stlntaco
    Jake
    California
    Just figured out the problem... The wiring harness I have only connects to the factory plug on the driver side and it is sensing that the passenger side is disconnected. It is telling the computer i have a headlight out and it is messing up the relay. The passenger side needs to be plugged in so i am trying to figure out how to get the plug plugged in without actually plugging the other headlight in. The plug needs to sense some sort of load for them to work correctly.
  15. Feb 29, 2016 at 9:58 PM
    NightProwler
    Harlan
    Maricopa, Az
    You should see if there's a module you can buy for that. Like mine. But mine only fixes the high beam indicator not lighting up. Not sure if itd work for yours. I think they make some just for that reason. Forgot what they are called. Just a little module that plugs in. Trs might have these too.
    Like this
    H4 HB2 HID Bi-Xenon Kit No Error Resistor H4 Warning Error Canceller https://www.amazon.com/dp/B00NQ4F1MY/ref=cm_sw_r_awd_Jat1wbCB6TA89
