Diamondback cover mt bike mount
Discussion in 'Tonneau Covers, Caps and Shells' started by redtoespike, Jul 8, 2019.
  1. Jul 8, 2019 at 6:50 AM
    redtoespike
    redtoespike [OP] Member
    I recently installed a Diamondback Cover and wanted a way to mount my mountain bikes. I searched Tacomaworld and saw several bike rack mounting systems - which were nice, but I wanted to keep it simple AND I did not want to drill holes into my new cover. I decided to use the existing hardware and holes. I took some 1/8" flat steel and cut a shape measuring 5" x 7" (have to consider the width of the fork mount hardware), bent the steel to match the angle of the cleat surface (which is about the same on all 4 sides of the Diamondback). I matched the cleat holes in the cover and drilled holes for the fork mount, painted it, and "bobs your uncle", while, using the existing Diamondback hardware, I now have mt bike fork mounts that can be used at any cleat on the cover.
  2. Jul 19, 2019 at 8:17 AM
    ijskiak
    ijskiak Member
    2009 Toyota Tacoma Double Cab
    This is a great idea! I was thinking of adding bike mounts to mine (when it comes). Really like the idea of being able to orient them differently too! Nice!
  3. Jul 24, 2019 at 7:28 AM
    redtoespike
    Thanks. Just got back from trip to NM (from San Antonio, TX). Brackets worked flawlessly and I used both of them.
  4. Aug 27, 2019 at 10:47 AM
    Lazyninja27
    Lazyninja27 Nobody Cares. Work Harder.
    HTX
    Tacoma 2018 DCSB Off Road 4x4
    awesome idea man! What did use to tie down the rear wheel? any more pics with full shot of truck and bike?
    thanks!
  5. Oct 27, 2019 at 6:32 AM
    redtoespike
    sorry delay in replying. I simply used tie-downs to hold the rear wheels in place. I will see if i have a pic to share...
  6. Aug 21, 2020 at 8:36 AM
    redtoespike
  7. Apr 4, 2021 at 8:02 PM
    safetypro85
    safetypro85 T1 Tiny the Taco.
    Dave
    Woodridge, Illinois
    2020 Cement Tacoma TRD Off Road
    Just Getting Started...
    Solid idea. I'll be bending some plate to make mounts from the front side cleats for my SE.
