Diagnostic Code P0136
Discussion in 'Technical Chat' started by bhenderson, Mar 31, 2009.
  1. Mar 31, 2009 at 9:13 AM
    bhenderson
    bhenderson [OP] New Member
    '04 Tacoma TRD
    Hello! My dealership has had difficulty finding out why my Tacoma has the check engine light on. Having checked the system with my code reader, it came up with P0136. This means there is a "sensor circuit malfunction." Specifically, it is an air/ fuel corruption. Any ideas as to why the dealership cannot/ does not want to help me? How can I fix this problem and turn off my check engine light for good? Thanks!
  2. Mar 31, 2009 at 9:39 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    Oxygen O2 Sensor Circuit Low Voltage-bank 1 sensor 2. Could have been a misfire or bad gas. Id reset and not worry about it. If it comes back on try replacing that sensor.
    What year? If its new, I would reset it and write it off as a fluke.
  3. Mar 31, 2009 at 10:10 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Apr 17, 2015 at 10:10 PM
    taco4tim
    taco4tim New Member
    Phoenix, AZ
    '00 Tacoma 2.4L
    I replaced both O2 sensors and completed a drive cycle and code still pops up. The sensors were caked with black smoke residue. What else could it be? Please Help!
  5. Jun 28, 2016 at 3:43 PM
    jahsonferg
    jahsonferg Member
    new hampsha
    96 3.4 one ton almost
    Cut your cat off replace w straight pipe leaving o2 sensors in place.
  6. Jun 28, 2016 at 4:46 PM
    tpotnoc
    tpotnoc Sit on my face
    Bellingham, WA
    15 2.7 DCSB PR
    Is that the only current code? Read the Long term fuel trim if possible, this will give you an idea of what's going on.
  7. Jul 15, 2016 at 11:54 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    check for proper connection and or corrosion at the connection.
  8. Jul 22, 2016 at 3:55 AM
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
    My truck has engine light on and the battery light as well any ideas taking it to toyota to do a diagnostic test. Help
  9. Jul 23, 2016 at 9:48 PM
    wilcam47
    Will
    Bourbon state
    get the codes pulled. Battery light usually comes on when the battery is going out or gone and or the alternator might be going out or gone.
  10. Jul 23, 2016 at 10:25 PM
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
    I found out what happened. I broke my spindle idk how or what but I'm going get e locker
  11. Aug 3, 2016 at 10:38 AM
    Rickhead
    Rickhead Active Member
    SW Washington
    2011 Tacoma TRD Sport
    I used to get O2 sensor codes on my 2000 Tacoma. Turned out to be the MAF sensor being grimed up with air filter oil from my K&N. I removed it and cleaned it with carb cleaner, reinstalled it, then removed negative battery terminal to reset and everything was good. Then I cleaned the K&N air filter and used a lot less filter oil. I hope this works for you.
  12. Aug 3, 2016 at 10:40 AM
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
    I think it's my differential the spindle
  13. Aug 3, 2016 at 10:45 AM
    Rickhead
    SW Washington
    Understood. I was replying to the original post of the O2 sensor code. I just looked at the original post again and it was from 7 years ago!!! Hahaha. Oh well, I am sure they have it figured out by now!
  14. Aug 3, 2016 at 10:50 AM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    They make MAF cleaner. I would use it rather than carb cleaner especially since it's electronic.
