Detatchable Awning Brackets
Discussion in 'Garage / Workshop' started by Digiratus, Aug 1, 2018.
  1. Aug 1, 2018 at 3:26 PM
    Digiratus
    Digiratus [OP] Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I’ve had this CVT awning for several years, evident by the older style (color) CVT logo. But figuring out how to use it effectively on my rig was not simple and always ended up on the too hard pile.
    [​IMG]IMG_4990 by mike digirat, on Flickr
    There were several obstacles to figuring out how to mount it. One was the design of my bed rack.
    [​IMG]IMG_4940 by mike digirat, on Flickr
    Because of its design, there were no aftermarket mounting solutions that I liked. This meant creating one. But a lack of welding and fabbing skills on my part was the second issue keeping this from happening sooner.
    Another challenge was where to mount the awning.
    A couple of years ago I had the good fortune to have a friend build me an awesome rear swingout type bumper complete with a nice fold out table. Combine that table with the tailgate open and I’ve got a great ‘kitchen’ space.
    [​IMG]IMG_4875 by mike digirat, on Flickr
    Since getting the bumper I’ve wanted to cover it with an awning to provide a place to hide under and cook under in inclement weather. You can imagine the feeling every time some rain or snow drove us into our tents when we were on one of our adventures. I would lament the fact that my perfectly good awning was sitting at home, not being used.
    [​IMG]IMG_3615 by mike digirat, on Flickr
    So last year I spoke with my friend Zane @Speedytech7 about this and began the process of formulating a mounting bracket design that could accommodate my needs. You see, unlike many awnings on adventure rigs, mine could not be ‘permanently’ mounted because the awning width is 55” and when mounted, it would be wider than the bed rack and RTT exposing several inches of the awning on either end to the elements.
    [​IMG]IMG_4987 by mike digirat, on Flickr
    I knew from Monte’s @Blackdawg experience from several years ago, that an awning permanently mounted across the back was vulnerable to getting damaged and/or otherwise knocked off its mountings on some of the tighter trails we do. This meant a detachable design was required. A mounting system that could be quickly and easily be mounted and removed in camp as needed.
    Enter Dan @turbodb, with his welding and fabbing skills and his garage, to turn Zane’s original concept into a practical reality.
    Here are some photographs of the process.
    [​IMG]0728181006 by Zane Roghaar, on Flickr
    [​IMG]0728181034_HDR by Zane Roghaar, on Flickr
    [​IMG]IMG_4939 by mike digirat, on Flickr
    [​IMG]IMG_4945 by mike digirat, on Flickr
    [​IMG]0728181055a_HDR by Zane Roghaar, on Flickr
    Attaching the permanent portion of the bracket system to the bed rack.
    [​IMG]IMG_4946 by mike digirat, on Flickr
    [​IMG]IMG_4948 by mike digirat, on Flickr
    [​IMG]IMG_4952 by mike digirat, on Flickr
    Dans nice mig welder that made quick work of all the welds.
    [​IMG]IMG_4954 by mike digirat, on Flickr
    [​IMG]IMG_4955 by mike digirat, on Flickr
    Some of the removeable pieces that make up the mounting system.
    [​IMG]IMG_4960 by mike digirat, on Flickr
    [​IMG]IMG_4964 by mike digirat, on Flickr
    This piece is permanently mounted on the awning itself.
    [​IMG]IMG_4966 by mike digirat, on Flickr
    [​IMG]IMG_4967 by mike digirat, on Flickr
    [​IMG]IMG_4968 by mike digirat, on Flickr
    And the three parts assembled and the awning deployed for the first time.
    [​IMG]IMG_4969 by mike digirat, on Flickr
    [​IMG]IMG_4970 by mike digirat, on Flickr
    All new metal primed and painted
    [​IMG]IMG_4971 by mike digirat, on Flickr
    Some close-ups of the assembled and mounted brackets.
    [​IMG]IMG_4974 by mike digirat, on Flickr
    [​IMG]IMG_4979 by mike digirat, on Flickr
    [​IMG]IMG_4975 by mike digirat, on Flickr
    [​IMG]IMG_4978 by mike digirat, on Flickr
    Some photos of it deployed.
    [​IMG]IMG_4981 by mike digirat, on Flickr
    [​IMG]IMG_4983 by mike digirat, on Flickr
    A new use for tennis balls to cover the ends of the permanent part of the mounting system so I don't poke out one of my eyes or bloody my forehead when loading stuff into the bed.
    [​IMG]IMG_4992 by mike digirat, on Flickr
    [​IMG]IMG_4994 by mike digirat, on Flickr
    [​IMG]IMG_4995 by mike digirat, on Flickr
    A special thanks to Dan and Zane for all the help. I can't wait to use this out in the real world.
  2. Aug 1, 2018 at 3:30 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Looks good buddy, glad I could pitch in a bit :)
    Digiratus[OP] likes this.
  3. Aug 1, 2018 at 3:34 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    I just got done with your post. First of all GREAT that you have functionality now,
    I have had an ARB I use on my rack for the past few years, there is no way in hell I would have gone thru what you did to do so, lmao !
    Nicely done !!!!:thumbsup:
    EPIC!!!
    Digiratus[QUOTED][OP] likes this.
  4. Aug 1, 2018 at 8:28 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Jeeeezzz who welded that shit. Look terrible!!!
    there the first welding shit talking post has been done. We can move on. :p
    Looks good! Similar to what i'd have done though a bit different. Hope it works out!
    BassAckwards likes this.
  5. Aug 1, 2018 at 8:46 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Those welds look perfect to me. Best ever! :brianr:
    And the design is a prototype for sure. At several points there was discussion about doing this or doing that. We'll see what improvements it needs through some real world use. :cool:
  6. Aug 1, 2018 at 8:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha best ever indeed :D
    And im sure it'll go through a few changes. Be cool to see where it ends up.
  7. Aug 1, 2018 at 9:05 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Any thoughts about drilling holes through the mount to slide a securing pin through? Would suck to have it opened and a have a strong wind flip it up off the mount posts.
  8. Aug 1, 2018 at 9:06 PM
    Speedytech7
    We talked about it, and it is looking pretty likely still. Eventually he'll drive off with it attached and that'll save it long enough, plus it makes setup easier.
    m3bassman likes this.
  9. Aug 1, 2018 at 9:44 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    :thumbsup:
    I totally agree. :luvya::luvya::luvya:
    Blackdawg[QUOTED] likes this.
  10. Aug 2, 2018 at 6:02 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Our swing outs are almost identical :thumbsup:.
    I really like the owning design, may have to borrow it.
  11. Aug 2, 2018 at 6:43 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    You can test fit it on one of my bed bars...:D
    JBTacoma[QUOTED] likes this.
  12. Aug 2, 2018 at 8:52 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Pretty sweet set up Mike. I always axed the idea of an awning because of how low my tent sits, but this looks pretty dam clever. :thumbsup:
  13. Aug 2, 2018 at 9:12 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks Tim. It was definitely a collaboration.
    A low RTT/bed rack is the challenge. We want a low COG so we compromise RTT height and give up the use of an annex and awning mounting.
    This is just a workaround to make it possible to stand under a mounted awning. :cookiemonster:
    Prayn4surf[QUOTED] likes this.
  14. Aug 8, 2018 at 1:57 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Saw this similar solution by @geoff325 in the RTT Owners thread.
