Detailed bed dimensions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by forty2, Nov 10, 2015.
  1. Apr 18, 2020 at 2:00 AM
    #61
    the_life_and_times
    the_life_and_times Well-Known Member
    2016 F150
    BamBeds, Squam_Taco and harryn like this.
  2. Jun 6, 2020 at 12:30 PM
    #62
    TacosRacingKTM
    TacosRacingKTM Active Member
    Josh
    '20 White 4x4 Taco CrewCab
    It appears the only file type available is .skp. Is there a way to convert these over to .dwg, so I can use these files on AutoCAD?
  3. Jun 8, 2020 at 6:51 PM
    #63
    the_life_and_times
    2016 F150
    I honestly don’t know. I would imagine so, but not sure how.
  4. Mar 18, 2021 at 9:24 AM
    #64
    TacoFranz
    TacoFranz Well-Known Member
    Thomas
    4x4 Tacoma SR5 Double Cab
    by the way, I was just trying to find the GEN 3 dimensions of the bed and what the differences are between a 2020 vs a 2021 short bed, if any at all. So, this is what I have researched. I had a 2020 SR5 DC SB 4x4 and I looked it up and compared with a TRD OR and found that year there were side-bed compartments on the left and on the right with the TRD OF and the Sport having on one side the 120 volt / 400 W power outlet, which my SR5 didn't have. Now I have a 2021 (long story) TRD Sport DCSB and that one has exactly the same dimensions in the bed but it has only 1 side-bed compartment (as small one and the power outlet next to it). I will show pics here. And the measurements - pic is not mine, but taken from a prior poster on this thread and double checked all my dimensions.
    There may be measurement diff's varying at around 1/4" to 1/2" increments, and that is probably just inaccuracies in measuring it, probably on my end (the bed length "B" is one of those examples because the bed is really 1/2" shorter than the Bed-Liner installed over it). I think it is the same, no diff between the G3's in my opinion. Anyone care to comment? The reason I am looking at these dimensions is because there is a company that makes these fold-out lockable tool boxes for the left/right of the truck bed and I wanted to buy a set, but they said it will fit the 2020 model but not the 2021 model. And that is just not possible... What are the differences why that would not fit?
    Thanks so much
    TacoFranz
    Lord Jr. Light, C41n and DirtyDan like this.
  5. Mar 21, 2021 at 9:52 AM
    #65
    wysgary
    wysgary New Member
    Gary
    2019 Taco Sport DBL Cab LB
    None Yet but working on it
    hi all thanks for the info, since no one posted this i have converted the sketch up file to cad 2004 format so you all should be a able to open it
  6. Mar 22, 2021 at 9:50 AM
    #66
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Anyone have a sldprt or stp file of the DCSB bed?
  7. Apr 3, 2021 at 8:20 PM
    #67
    Jimbofrith
    Jimbofrith Member
    Jimbo
    Fort Collins CO
    2019 Cement TRD Off Road
    Does anyone have bed measurements for 3rd gen 6ft bed ? Looking to make platform bed with 2 drawers.
  8. Apr 4, 2021 at 4:17 PM
    #68
    the_life_and_times
    2016 F150
    Parras, MrKatanga and Pyrotech like this.
  9. Apr 13, 2021 at 7:50 AM
    #69
    Nic7320
    Nic7320 New Member
    First off, thank you to everyone that provided dimensions and cad drawings.
    I'm working on a lift mechanism to rise about 54 inches and support 800 lbs. The plan is to use four 3/4" acme threaded rods at each corner inside schedule 40 steel pipe with chain and sprockets to lift four corners at once -- eventually with a 12V motor. I'm an EE, not an ME, so anyone that can help with advice will be appreciated. I haven't used autocad in a while, but I'll get my system up and get this going soon.
    MrKatanga likes this.
  10. Aug 29, 2021 at 3:05 PM
    #70
    ac2ndGenTacoma
    ac2ndGenTacoma Well-Known Member
  11. Mar 1, 2022 at 2:11 PM
    #71
    bigwill837
    bigwill837 Well-Known Member
    Will
    Austin, TX
    1996 HZJ75 Land Cruiser Pickup
    Does anybody have this dimension? From the top of the wheel well to the top of the bed rail track?
    BA27-EEDD-DF15-4-C4-C-89-FC-2-E8682-CA2-_6aa9515a359f9d0f839058bd007acad276b6dece.jpg
  12. Mar 1, 2022 at 4:15 PM
    #72
    bigwill837
    Will
    Austin, TX
    I tried that already. The tape measure came from Qatar with the truck…but I can’t read Arabic.
    8120-AAC8-F5-C4-4-E8-C-824-F-AF9318-CCD6_b462f12978b7ab5a0ab8ec7614eab2d4b8531c1f.jpg
    Seriously though, if you get a chance, the dimension on the Taco would really help me out. I’m trying to retrofit a Pelican case mount in the Land Cruiser bed.
    (Updating my vehicle sig too).
    Thx.
    Doobfucious likes this.
  13. Mar 1, 2022 at 5:08 PM
    #73
    slowpoke16taco
    slowpoke16taco Well-Known Member
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stock, but not stock (but stock)
  14. Mar 1, 2022 at 6:26 PM
    #74
    bigwill837
    Will
    Austin, TX
    Thank you, I appreciate it.
  15. Mar 26, 2022 at 5:41 PM
    #75
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    Don't have my truck yet, but starting to plan/build out my bed rack. Can someone pull a couple of dimensions for me, please?
    What is the outside to outside dimensions of the top cap on the bed rails 6" in from the front, over the wheel wells, and about 6" in from the tailgate? I think they will be close, but I think there is a slight taper towards the back, no?
    Thanks to whoever can assist.
  16. Jul 22, 2024 at 8:27 PM
    #76
    EireBleuTacoma
    EireBleuTacoma Well-Known Member
    Brien
    North Austin, Texas
    2016 SR5 Tacoma
    Grille Guard, Wheels, Tires, wrap, blacked out decals
    Hey does anyone run a crossbed tool box on their 3rd gen? I have been looking for a small box to carry some emergency equipment that has been occupying my back seat, but so far the options are small in between wheel wells, or too wide to fit in between bed rails. I know there has to be something out there without me dragging the brake out and making a custom one. Any ideas or suggestions are golden. Looking to stay with matte black but a rattle can will fix it if not black.
  17. Jul 22, 2024 at 8:30 PM
    #77
    EireBleuTacoma
    Brien
    North Austin, Texas
    2016 SR5 Tacoma
    Yes, but you have to use the SketchUp desktop app and then save file as vector, or DWG. The program can read and save in both file formats.
  18. Jul 23, 2024 at 7:59 AM
    #78
    moto.hermit
    moto.hermit Well-Known Member
    JD
    Munford, AL
    '20 SR5 DCSB 4x4, '25 Suzuki DR650, '16 Triumph Scrambler
    Stock-ish
    I picked up one from Tractor Supply when I first got my truck. I think it was generic for a mid-sized pickup. I think there's some pictures earlier on in my build thread. It's been sitting at my house for the past couple years though. If you were closer I'd let you have it for $100.
  19. Dec 24, 2024 at 11:59 AM
    #79
    Tronfunkblow
    Tronfunkblow Well-Known Member
    California
    2017 DCLB TRD OFF-ROAD 4x4
    MT64s, Icon RXT Leaf Springs, Topo Topper
    I know this is old, but thank you for this file. Instantly helping with the build out design.
