Detailed bed dimensions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by forty2, Nov 10, 2015.
  1. Nov 10, 2015 at 3:13 PM
    forty2
    forty2 [OP] Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    My Google-fu game is weak and I can't find detailed dimensions for the short bed. If someone could pull these measurements for me I'd really appreciate it:
    Oh, and bed depth, wheel well height, and top of bed to top of cab height as well. Thanks.
  2. Nov 10, 2015 at 3:45 PM
    OnceARunner
    OnceARunner War Eagle!
    Georgia
    2016 DCSB TRD Sport Tacoma
    Happy to do it tomorrow afternoon if no one else can get to it before then.
    C41n and RON_TRD Sport like this.
  3. Nov 10, 2015 at 3:47 PM
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    A - 25"
    B - 60 1/2"
    C - 42" C @ Top of well 45 1/2"
    D - 52 1/2"
    BED DEPTH - 19"
    WHEEL WELL'S - 9 1/2"
    TOP OF BED TO TOP OF CAB - 20 1/2"
    Menardo, edlsen, Punkface and 37 others like this.
  4. Nov 10, 2015 at 4:34 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Perfect. Thanks a lot.
    RON_TRD Sport likes this.
  5. Nov 10, 2015 at 5:06 PM
    The Fluffer
    Andrew
    Scottsdale, AZ
    boughten
    No problem, only took a second.
  6. Nov 10, 2015 at 6:34 PM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Care to share what you are planning to do with those measurements?
  7. Nov 10, 2015 at 8:16 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Sure, planning a lightweight slide-in pop-up made primarily from Cana-Core or Nida-Core. Doing a simplified preliminary CAD model to determine materials needed. I can usually get a screaming price on Fiberlay stuff and if Cana-Core prices out okay I'm going to plan on getting what I need on my next supply run later this month. Actual construction won't be until spring at the earliest, and knowing how my shop time usually goes that might be spring of 2018...
  8. Nov 10, 2015 at 8:55 PM
    M16
    M16 Well-Known Member
    interesting thread. if you're gonna sleep in a short bed, you better measure twice
    KB Voodoo likes this.
  9. Nov 10, 2015 at 9:12 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Got it covered.
  10. Nov 10, 2015 at 10:00 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    How about the good bed; the long bed?
  11. Nov 10, 2015 at 10:04 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Make me one with the good transmission; the manual transmission.
  12. Nov 10, 2015 at 10:14 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Final design will be done in AutoCAD, but down and dirty is faster in SketchUp:
    This gets me close enough material wise to figure out how much I need. Will be talking to my sales guy tomorrow to price it out. If Cana-Core is cheap enough I'll get materials right away, if not there's no big rush.
    Lid from carbon fiber, balsa and foam should come in under 20 lbs. Main unit structure from honeycomb composite panel and aluminum will be close to 200 including door hardware and cab window. All up weight target, with pop-up canvas and gear, is 500 lbs.
  13. Nov 10, 2015 at 10:27 PM
    TacoDan723
    TacoDan723 Well-Known Member
    Dan
    Pacific Northwest
    2015 MGM Tacoma Limited
    interesting...
  14. Nov 11, 2015 at 5:12 AM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    How high is it? Flush to roof?
  15. Nov 11, 2015 at 7:30 AM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Can't wait to see this thing!
  16. Nov 11, 2015 at 7:35 AM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Yes, needs to be able to sit below two kayaks and a paddleboard while in motion.
  17. Nov 29, 2015 at 8:45 PM
    elliotts
    elliotts Well-Known Member
    Seattle, WA
    2016 Black Tacoma TRD Off-Road DCSB 4x4
    Do you guys know if the bed dimensions have changed at all between the Gen2 and Gen3 ?
  18. Nov 29, 2015 at 9:07 PM
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    I know it is slightly deeper on the 3rd gen (an inch?)
    I know that folks have been buying the bed mats for the 2nd gen and they fit the 3rd gen perfect. So we can deduce that the basic floor dimensions are very similar.
    Someone else may have more details, but that should give you a rough idea.
  19. Nov 29, 2015 at 10:50 PM
    Denver2890
    Denver2890 Well-Known Member
    Denver
    Kentucky
    2016 Tacoma TRD OR 4x4 Quicksand
    Sounds cool. I will keep an eye out on this one for sure, here is the solution I found for camping in the short bed. image.jpgimage.jpg
    t2c, Speedbird, doctorscott and 13 others like this.
  20. Nov 29, 2015 at 10:55 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    I saw that in the caps thread (and in SEMA coverage). I think it's a pretty cool solution but I wonder how it'll do in a downpour and through heavy use?
    Anyway, I didn't end up picking up materials just yet, Nida-Core is going to cost considerably less. Probably going to wait until late spring at the earliest to get started, shop's way too cold to start doing any major composite work anytime soon.
