Denso Fuel Pump vs. OEM
Discussion in '1st Gen. Tacomas (1995-2004)' started by CS_AR, Jul 27, 2019.
  1. Jul 27, 2019 at 9:54 AM
    CS_AR
    CS_AR [OP] Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    GQ7227 likes this.
  2. Jul 27, 2019 at 9:56 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Who's the manufacturer of the OEM pump?
    That's crazy my Walboro 190lph pump cost 1/3 that lol. Not that I really recommend it, it's noisy
  3. Jul 27, 2019 at 10:01 AM
    CS_AR
    Oh yea.. Denso.. Funny how its the same price difference and situation with Nissan.
    You can buy OEM for an additional $200 and get a new Hitachi in a Nissan box or buy a new Hitachi from Rock Auto in a different box that comes with the filter sock.
    Luv my yota and cruiserguy like this.
  4. Jul 27, 2019 at 10:07 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yeah the Denso usually is OEM for Toyota on the fuel pumps. And if not, are a solid manufacturer for many of the OEM parts, so it's safe. I've used Denso fuel pumps in my Land Cruisers. Cool thing is the Denso usually comes with the kit w/sock prefilter, and all the little things
  5. Jul 27, 2019 at 10:09 AM
    cruiserguy
    Elijah
    SEKS
    Just read your second paragraph and you stated what I just repeated. What happens when I open my mouth before listening (reading) all the way through:D
    CS_AR[QUOTED][OP] likes this.
  6. Jul 27, 2019 at 10:09 AM
    CS_AR
    That's right. I'm seeing that. They have more accessories.
    cruiserguy[QUOTED] likes this.
  7. Jul 27, 2019 at 10:10 AM
    CS_AR
    I always appreciate your posts.
    GQ7227 and cruiserguy[QUOTED] like this.
  8. Jul 27, 2019 at 10:38 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    A few years ago the Denso "kit" had everything including the sock. They were just under $100 and slowly went down to around $80, still with the sock.
    They were identical to the OE Denso pumps down to the absolute last detail. The one in your link has different color plastic than the OE but that is next to meaningless and says the sock is not included. The kit with the sock was Denso #950-0103. If you look up "pump and strainer" on the Denso site it gives #951-0001 with the same pic as Rockauto (no sock) so who knows.
    Useful Denso site http://densoautoparts.com/
    Get a new oval rubber tank seal as they deteriorate.
    The replacement sock was much finer than the OE. The semi stiff OE sock was more of a strainer and had a good sized hole worn thru from rubbing on the tank bottom.
  9. Jul 27, 2019 at 10:41 AM
    cruiserguy
    Elijah
    SEKS
    Dirty pool, have you really been able to get out daily or that frequently to wheel? Just noticed the phrase below your handle changed. Or is that your wish, as is many of ours?
  10. Jul 27, 2019 at 10:45 AM
    CS_AR
    Great info DP! The Denso seal and sock are on the list. I think that should cover everything?
    Are there any rubber hoses outside of the tank that I need to consider?
    I'm doing my usual parts collecting in advance for when I have the bed off for maintenance in Sept./Oct.
  11. Jul 27, 2019 at 10:47 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Closer to daily than weekly but still the goal, been on vacation for 17+ years.
    Thought I would change from song of the month.
  12. Jul 27, 2019 at 10:50 AM
    cruiserguy
    Elijah
    SEKS
    Gotcha, didn't realize you were already kinda on a permanent vacation lol.
  13. Jul 27, 2019 at 10:57 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    I'm a fan of dropping the tank for the swap for a number of reasons. If one forgets to first disconnect the short, semi hidden flex line right at the tank, it can be damaged.
    Looks like this, a sheathed "nylon looking" tube and not cheap. Later years had a different set up. Arrow is where it kinked.
  14. Jul 27, 2019 at 11:04 AM
    CS_AR
    Good point. I'm actually prepping the Taco to run for another good 15 or so years. So I'm on a mission to replace all things rubber that supports the engine running by end-of-year. I've already done the engine compartment with the exception of a couple of vacuum hoses that are on the list.
  15. Jul 27, 2019 at 11:55 AM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    The Denso ones work fine. I put three in other trucks and one in mine. Haven’t had issues, I do suggest the fuel sending gasket on the tank too, good suggestions out here. The female fuel line should be inspected for kinks like was said, they don’t always want to come off without twisting to shit.
    GQ7227 and CS_AR[OP] like this.
  16. Jul 27, 2019 at 11:58 AM
    CS_AR
    The sending gasket is?
    https://www.rockauto.com/en/moreinfo.php?pk=2142938&cc=1357589&jsn=9
    Luv my yota[QUOTED] likes this.
  17. Jul 27, 2019 at 12:01 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    I'm a fan of Aeromotive pumps as a replacement, sure they're higher flow, but they fit in the stock location nicely with the stock rubber isolator on the bottom and are quiet (looking at you Walbro you clapped out POS brand)
    1997tacomav6 likes this.
  18. Jul 27, 2019 at 12:02 PM
    Luv my yota
    00 turd lift 33's
    GQ7227 and CS_AR[QUOTED][OP] like this.
  19. Jul 27, 2019 at 12:14 PM
    CS_AR
    I'm going to remove the bed to sandblast and freshen up the frame. I have three kids and a neighbor that will help with the bed. I learned the beds are 6 bolts and 4 guys. I have that covered. The bed was off last week. Trying to figure what else to work on while I have the bed off.
  20. Jul 27, 2019 at 12:54 PM
    cruiserguy
    Elijah
    SEKS
    Nice big open work place, you lucky dog
    QMEDJoe and CS_AR[QUOTED][OP] like this.
