DEI DBALL2 Remote Start Install using OEM fob - 2017 Tacoma Push to Start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gpb, Dec 22, 2016.
  1. Dec 22, 2016 at 5:09 AM
    gpb
    gpb [OP] Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Content removed.
    Mods think that an image of a dog peeing on a photo of a war criminal is inappropriate.
    I think I won't support this site with my intellectual property.
  2. Dec 22, 2016 at 5:19 AM
    PJnc284
    PJnc284 Well-Known Member
    Garner, NC
    2016 Tacoma TRD Off Road 4x4
    :popcorn:
    I had been working on this long drawn out idiots guide to this but @gpb covered most of it so I'll just provide a few more pictures and charts as you can never have too many of either. If I fat-fingered something, let me know.
    For those doing their own kits, below is a diagram of the dball connectors showing which wires are used and those that can be removed if desired along with what the finished product looks like. The pins are easy to remove using a small precision flat head screwdriver or needle by applying downward and outward pressure towards where the wire enters the connector. The dball wire locations below are labelled based on the connector color and the pin number so B3 would be blue connector, pin 3 or the Tan/Black wire for HS CAN High.
    Overview of the layout under the dash. Each point is labeled with a number which is used in combination with the pin # to give a location. (ex. 2-16 would be the PTS Output on the Smart Key ECU Assembly)
    Wire pairs:
    Schematic of how the PTS and SLP wires run to the Smart Key ECU allowing you to avoid removing the steering column cover and pts buttons.
    Connection layout
    The Ground and 12V connections should be fairly self explanatory so I'll skip those especially the ground since some may prefer different locations.
    2. Smart Key ECU Assembly (Beige or tan, beige or tan, I don't know what the hell they are but they work.)
    3. OBDII Connector (Directwire image was better than mine so I just re-labeled it. Once again, blue or light blue. Whatever, it works. Some have managed to get the cable holder that holds the obdii wires off the bolt holding it to give more slack to work with. Was tired and figured I'd probably just end up breaking it so I left it alone.)
    4. Main Body ECU Connector
  3. Dec 22, 2016 at 5:42 AM
    Asus
    Asus Well-Known Member
    2017 Super White Tacoma TRD 4x4 OFFROAD
    CanyonRunner likes this.
  4. Dec 22, 2016 at 6:18 AM
    buckin taco
    buckin taco Well-Known Member
    Cort
    16 TRD OR DCSB MGM
    Awesome, great write up.
    CanyonRunner, gpb[OP] and opentang like this.
  5. Dec 22, 2016 at 6:27 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    :popcorn:
  6. Dec 22, 2016 at 6:45 AM
    CanyonRunner
    CanyonRunner 100% PENETRATION
    Pacific Northwest
    2016 TRD 4X4 DCSB
    $$$ Money Pit $$$
    Way to go gpb
    *Also, FYI most places will flash that device for free before they send it so you don't even need the xkloader.
    gpb[OP], dYL0n and PJnc284 like this.
  7. Dec 22, 2016 at 6:50 AM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Awesome, thanks!
    16tacoblue and gpb[OP] like this.
  8. Dec 22, 2016 at 6:52 AM
    Frogsauce
    Frogsauce Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    Good job @gpb, I knew it was only a matter of time before someone figured this out and shared the wealth.
    CanyonRunner and gpb[OP] like this.
  9. Dec 22, 2016 at 6:53 AM
    CanyonRunner
    Pacific Northwest
    2016 TRD 4X4 DCSB
    $$$ Money Pit $$$
  10. Dec 22, 2016 at 6:59 AM
    asiantaco 253
    asiantaco 253 Well-Known Member
    PNW
    2016 Toyota Tacoma Inferno DCLB TRD Offroad
    Cool
    gpb[OP] likes this.
  11. Dec 22, 2016 at 7:09 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Since you called me into this thread (which I was prepared to ignore).....
    You don't seem to understand that TW supports its vendors, and the vendors support TW.
    You can call us "greedy fucks" if you want, but all we've done is create a simple to install kit that eliminates all the programming, and we offer it at a great price.
    By the way, here is the order link for our kit: http://www.kbvoodoo.com/shop/remote-start-kit-for-toyota-tacoma-2016-2017-preorder
  12. Dec 22, 2016 at 7:24 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    This is *almost* the same argument as the pop-n-lock.
    You could source the pop-n-lock actuator yourself for $10 and have to do the mounting and wires yourself vs paying $98 for the pre-package pop-n-lock. It's preference. What the OP did was give people choice.
    gpb[OP] and Ch78 like this.
  13. Dec 22, 2016 at 7:27 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    We didn't do anything shady. You were acting like a jackass and the moderators cleaned up your garbage.
    rysingsun, Hank Heel and Ch78 like this.
  14. Dec 22, 2016 at 7:33 AM
    winston50
    winston50 Well-Known Member
    Had it not been for @nickj718 no one would even have this. Did anyone think of that? Also the directions posted here are the same as his video........
    You guys also know KB Voodoo pays to be here right?
    This is a board that people come to for suggestions, help and ideas. Stop polluting it with hostility its getting quite crazy. I'm almost positive canyon runner was the bullied unpopular kid in school and is a dick for that reason. Your comments provide no help so just shut up
    evansdmax, Ch78, facefirst and 2 others like this.
  15. Dec 22, 2016 at 7:38 AM
    winston50
    ^ Ban this guy already
    Hank Heel likes this.
  16. Dec 22, 2016 at 7:38 AM
    CanyonRunner
    Pacific Northwest
    2016 TRD 4X4 DCSB
    $$$ Money Pit $$$
    Didn't you support the other thread enough already....
  17. Dec 22, 2016 at 7:40 AM
    CanyonRunner
    Pacific Northwest
    2016 TRD 4X4 DCSB
    $$$ Money Pit $$$
    I have posted way more threads helping this community for free than you bud, of you're 40 post here, how many have been in that thread...
  18. Dec 22, 2016 at 7:41 AM
    winston50
    Doesn't matter your attitude sucks and calling people out is plain bullshit
    Ch78 and Hank Heel like this.
  19. Dec 22, 2016 at 7:48 AM
    PJnc284
    Garner, NC
    Hopefully this doesn't turn into a shit show. This thread was the original intent of nick's thread. Remote start for $45 or less. Sounded great, right! I'll give it to nick for suggesting the idea but he certainly didn't develop it. It was just a matter of running across it and pretty sure I saw it mentioned elsewhere but it didn't seem to gain any traction. As for the directions being the same as the video, there's only so many ways you can take panels off and or connect wires. All of the wires are already there in the DEI diagram aside from the change to using the smart key ecu assembly which isn't too difficult to figure out after taking a gander at the factory service manual. There is a place for pre-made kits but people like alternatives. btw- my kit from nick is finally out for delivery today. That one will be up for sale on Monday as I made my own while waiting!
    Walter Scott said it best "Oh, what a tangled web we weave. When first we practise to deceive!"
  20. Dec 22, 2016 at 7:51 AM
    cheuer
    cheuer Well-Known Member
    Utah
    2016 DCSB TRD OR 4x4 Blazing Blue Pearl
    Leer 100XR, Mobtown Offroad Sliders
    ^ This. I went the DIY route with the pop-n-lock and I'll probably do the same with this kit too. Thanks @gpb for the write-up.
    That said, for anyone that's not super technical or is inexperienced with electronics, the kit offered by KB Voodoo is the way to go.
    gpb[OP] and KB Voodoo like this.
