Dedicated snow tires or not
Discussion in 'General Tacoma Talk' started by Blanked, Jul 4, 2024.
  1. Jul 4, 2024 at 6:06 AM
    Blanked
    Blanked [OP] Active Member
    Kelly
    Still looking
    Do you run studded tires or not? Winter tires no studs? Or just all terrain? Where do you live so I can compare apples to apples. I am in north Idaho
  2. Jul 4, 2024 at 6:20 AM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    If you do a lot of highway driving in winter get a dedicated non studded pavement tire. Lighter and less noisy than a studded tire.
    Some AT tires do well in the snow but the tire compound freezes rock hard in serious cold and loses traction on frozen pavement.
    As usual, tire choice is a tradeoff. Skinny tires will also help on winter paved roads to cut through the white stuff and reach pavement.
    I've never encountered a situation where I felt I needed studded tires or even chains. 4x4 is great in the snow and ice.
    For snow wheeling tho a wider tire with a more aggressive tread works great.
    For reference in winter I drive my truck all over Appalachia region/the Dakotas/ NEK and sometimes that weird Canadia place up north.
    Normshark likes this.
  3. Jul 4, 2024 at 6:49 AM
    NEoffgrid'r
    NEoffgrid'r Well-Known Member
    Todd
    New England
    2023 TRD Sport 4dr SB
    None Yet
    I run studded tires from Nov-April in Maine. I have off-grid camp out in the sticks & it helps a lot if it's all ice after I do snow removal. The only downfall is less mpg. I will say when it's snowing & I'm traveling I do feel safer & I noticed the Tacoma is unstoppable with the 400lbs of sandbags I put in bed & my heavy tool box & gear. I still get 20mpg & to me that doesn't hurt the wallet too bad.... I just put on Falken Wildpeaks AT4w (I love so far) & I may see how they go VS studded tires on steelies. Which are a softer tire (Artic Claw's). I did notice a 2mpg drop.... I would say it depends on how many miles you put on in winter & how far you travel & conditions..
  4. Jul 4, 2024 at 6:55 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    I live in central B.C. We drive through all types of snow,light powder,slippery compact and heavy wet snow. I run a dedicated set of studded snows with a back up set of v bar chains. The chains I’ve used on a number of occasions and feel they are good insurance. If you travel remote roads get the best you can afford,being stranded in winter is no joy.
  5. Jul 4, 2024 at 6:57 AM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    I live in Northern Wisconsin and have been running dedicated winter tires on every single vehicle that I have owned since high school. We aren't allowed studded so I wouldn't know anything about studded tires but dedicated winter tires are 100% worth it. The confidence and safety they provide you is 100% worth the cost.
  6. Jul 4, 2024 at 6:59 AM
    Bitflogger
    Bitflogger Well-Known Member
    2024 TRD OR long bed
    Our experience with new or now era year-round 3PMSF tires changed any thoughts to do repeat any more dedicated winter tires and wheels. For most snow fall and snow storms their snow performance is fantastic. They are far superior to AT and M+S (all season) class tires on ice and snow. Current state of the art dedicated snow tires have some advantage on ice but are no good when it is warmer and inferior for lots of general driving.
    This is not how we felt only a few years ago. It is not saying the best dedicated winter tires are no good or not worth considering. It is saying considerable experience with both has us preferring this new category of tire for the total amounts of driving we do. There's still so much of winter that is not a storm or all snow and ice covered that we prefer this new type of tire because they are so good when weather his bad.
  7. Jul 4, 2024 at 4:15 PM
    Normshark
    Normshark Well-Known Member
    Great White North
    2014 Tacoma DCLB Limited
    What he said.
    Cheers
  8. Jul 4, 2024 at 8:04 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i think they have their benefits. but it comes down to the conditions of your area.
    in my area in nw indiana, snow doesn't stick around more than a few days on the roads. they salt everything.
    for me, i bought snow tires for my other vehicle, but can't justify running them when they end up being used on mostly-dry pavement for most of the snow season, regardless of the amount of snow that falls.
    snow tires absolutely do better on snow-covered roads. if you're out in the areas that either stay too cold to salt, or too remote for them to consistently plow, i would absolutely recommend the best snow tires you can get. but if you're anything like me, near a major metropolitan area, there's really no need for it other than while the snow is falling, and even then, most towns around me start making it illegal to drive unless it's an emergency under those conditions.
    G2.M6 and Stuck in VT like this.
  9. Jul 4, 2024 at 8:07 PM
    Bishop84
    Bishop84 Well-Known Member
    I always suggest running a 4 season all terrain on trucks first to see if its enough for the driver, especially in mild winters.
    Anywhere that has less than 6 hours of winter day light already know they need dedicated winters.
  10. Aug 11, 2024 at 11:19 PM
    nds0000
    nds0000 Well-Known Member
    If you want to compare apples to apples, you need to consult a website as motor1.com that has tested tires under exact the same conditions. Two stock vehicles with same tires may have different MPG, durability, better or worse control over the vehicle. It is not the tire, it's the driver... Contributing factors are also tire size, and year of manufacturing, as not seldom the profile gets changed over the years with the same tire brand and name.
    However, one universal factor for tire performance is the temperature. As I read, 7C is the magic number where companies recommend switching from winter to summer tires, as the rubber mix of summer tires hardens to fast and reduces the grip. Likewise, above 7C the winter tires do not perform well because of the mixture of the rubber. They wear fast and produce low MPG. Add rain to it and you set yourself up for trouble.
    AT M&S are normally a good mix for all year driving in moderate conditions due to the rubber mix and profile, but they may not be the optimal for either extreme condition and overall have poor performance when it comes to MPG, noise pollution, wear...
    This may help also: Summer tires vs. winter tires | Continental Tires (continental-tires.com)
    Now you have to decide what kind of conditions you are in, what kind of driver you are, what your budget is, what your risk acceptance threshold is...
    soundman98 likes this.
  11. Aug 12, 2024 at 12:25 AM
    AK Dudeman
    AK Dudeman Well-Known Member
    DCBLB OR MGM 22
    Studded & Sipped Snow tire. Winter.
    G2.M6, Unit59 and Steves104x4 like this.
  12. Aug 12, 2024 at 12:31 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    BFG commercial traction T/A have been kicking ass for 14 years IMG_6099.jpg
    Unit59 likes this.
  13. Aug 12, 2024 at 6:10 AM
    Bitflogger
    That does not seem to reflect the current marketplace. I've had Conti models with the DWS stamp and dedicated winter tires that have some negative aspects too. One of our vehicles had those Conti swapped for the Michelin CC2s. The CC2s are a whole other and better league. A modern state of art winter only tire has some slight advantage on ice but overall those CC2 perform all the time. That has me interested in the BFG OEM and 3PMSF versions of the Trail Terrain T/A (a Michelin brand) and Michelin's light truck 3PMSF tires.
    My experience with the modern all year 3PMSF tires and same for associates is they're also less prone to flat or be damaged from braking. Same time I'm ski area crew I also have to do 88 mi and 183 mi leg freeway trips when I disliked dedicated winter tires.
    Conti has been behind others but now I do see their General brand has all year 3PMSF offerings. With others experience and those Michelin CC2 SO good I'll be sticking with what gets same sort of top rated by owners reviews. As said earlier, I'm waiting to try the OEM Trail Terrain T/A before spending.
  14. Aug 12, 2024 at 6:33 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    NY/NJ border here but I occasionally travel 5 hours north to go snowmobiling in the winter and I run studded snows. I got the set of 4 for a good price on FB Marketplace and they happened to be studded. I'm not sure I'd have shelled out the extra money for studs if I were buying new. The truck has not disappointed me traveling up there and I'm sure having 600 lbs of snowmobile and gear in the bed don't hurt matters.
  15. Aug 18, 2024 at 9:42 AM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2021 4runner "Luna" 2023 Solar Octane MT "Solaris"
    This "in my opinion " is a no brainer. Dedicated snow tire.
    Oh and here is some advice: This does not come out of your mod Tacoma budget. Strike this line item from your "cost of ownership " this is about safety. It comes out of the "protecting my family; being a good husband, being a good dad" bucket. And the bonus is,,,, it's not bullshit, it's being a man and caregiver!
    BC Hunter likes this.
  16. Aug 18, 2024 at 10:00 AM
    soundman98
    NW Indiana
    lol, jokes on you! i don't have a family, not a husband, or a father! ha!
    G2.M6[QUOTED] likes this.
  17. Aug 18, 2024 at 11:10 AM
    G2.M6
    Fort Collins CO
    Dedicated responsible driver then...
