Decked traction surface
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigFatDynamo, Jan 8, 2023.
  1. Jan 8, 2023 at 4:48 PM
    BigFatDynamo
    BigFatDynamo [OP] Well-Known Member
    Charlotte, NC
    2019 TRD OR
    I'm looking for traction surface options for the top of my Decked. I know the company makes an marine eva foam for $500 and a bed mat can be had for much less. But has anyone applied a bed liner product to the decked plastic?
    how well does marine eva hold up? I may buy some off Amazon but can it take a beating?
    the bed mat is another $80-100# I don't want to add on. Can thinner rubber be glued on?
    I do not have a cap, my bed is open, so it needs to hold up in weather.
  2. Jan 8, 2023 at 5:00 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Plastic to plastic really doesn't stick well unless one is heated to almost liquid.
    I'm only giving you the cliff notes version. There are lots of different plastics and they all react differently.
    Great question. I'm in to hear other responses .
    BigFatDynamo[OP] likes this.
  3. Jan 12, 2023 at 3:13 PM
    GC4x4
    GC4x4 Well-Known Member
    Greg
    2016 Tacoma DCSB Limited 4x4
    Suspension: Front: King Coilovers SPC UCAs Rear: Deaver U402 Stage I King RR 2.5 Shocks Archive Garage Hammer Hangers Other: OME Carrier Bearing Drop Kit Diff Drop Kit Wheels: OEM SEMA 4Runner TRD Pro Wheels 285/70r17 Falken Wildpeaks Other: TRD Pro Grille Chrome Delete (mirrors, handles, badges, fogs) Bike Storage: Dakine DXL Tailgate Pad and RockyMounts
    Bump for this as well. Very interested.
  4. Jan 12, 2023 at 4:48 PM
    BigFatDynamo
    Charlotte, NC
    2019 TRD OR
  5. Jan 12, 2023 at 4:58 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    You just want a grip/traction surface that won't slip? What about this:
    https://www.ebay.com/itm/361946610137
  6. Jan 12, 2023 at 5:14 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    Interested as well. Looking for something that will keep things from sliding without ruining the aesthetics of my rear seat delete . Anybody with goose gear address stuff sliding around or is that why I should have bought the goose gear?
    GC4x4 likes this.
  7. Jan 12, 2023 at 5:14 PM
    GC4x4
    Greg
    I’ve been looking for a rubber mat in the right size (to trim down) that’s heavy enough to lay flat on its own and not slip (like the OEM bed mat). If anyone has recommendations from experience, all ears
  8. Jan 12, 2023 at 8:22 PM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Nuanchu A Roll Large Semi-Finished Striped Door Mat Waterproof Entry Mat with Rubber Lining, Indoor and Outdoor Rug for Wet Weather, Entrance Shoe Scraper, Kitchen, Bathroom (31.5 x 39.4 Inch, Gray) https://www.amazon.com/dp/B09Q571JBH
    I use a couple of these with some small selftaping screws with flat round heads to hold it down.
    #8 x 1/2" Phillips Modified Truss Head Self-Drilling Tek Screw, Zinc-Plated Steel for Sheet Metal Attaches Wire Lath to Metal Studs - Box of 100 https://www.amazon.com/dp/B0768MR94M
  9. Jan 13, 2023 at 7:05 PM
    GC4x4
    Greg
    Nice, any pics?
  10. Jan 13, 2023 at 7:35 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    When I got my Decked, I simply cut my OEM bed mat shorter and it fits and works great. Since the Decked doesn’t go all the way to the tailgate, the OEM may hung over a bit before I trimmed it.
  11. Jan 13, 2023 at 9:50 PM
    Jc_dabs
    Jc_dabs Griselda.taco
    Jesus
    Long Beach ca
    2021 tacoma Trd or
    Looks like over priced skateboard grip tape
    Stuck in VT likes this.
  12. Jan 13, 2023 at 10:07 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I bought a 5 foot bed mat that already had cut outs for bed stiffeners and put it in the top of my decked drawers for my 6 foot bed. Cutting the sides was required so I can have access to the side compartments. I put a screw going through the bed mat into the top of the decked drawers to stop the mat from sliding. And if you’re wondering, I only paid $40 for the 5 ft bed mat.
  13. Mar 21, 2023 at 4:00 AM
    BigFatDynamo
    Charlotte, NC
    2019 TRD OR
    If you don’t mind adding more dead weight, then the battle mat or similar thick rubber that will lay still on the highway seems the way to go. It can be cut to fit between the core-trax.
    Otherwise, I've put rubber feet on some of the things tote around - specifically plastic bins when I take the fam camping - that keep stuff from sliding around. Similarly, I keep a small roll of TPU membrane handy to throw down as a mat as needed.
    while there are chemicals that inhibit adhesion to HDPU, I decided to scrap any (semi)permanent application of rubber to the Decked, so that I could shove heavier items around without pulling up or snagging a thinner applied rubber. Plus the surface pattern doesn't really allow for full surface contact.
