Deciphering Toyota Part Numbers…
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KY_Rob, Mar 10, 2024.
  1. Mar 10, 2024 at 7:09 AM
    KY_Rob
    KY_Rob [OP] Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    Finding OEM part numbers from Toyota is frustrating for me. I’ve struggled with this for years. More often than not, I find them by accident.
    I can go to autoparts.toyota.com and fairly quickly find the assembly drawing with the part I need using the VIN. My problem comes from the number on that assembly drawing seeming not being tied to any damned thing anywhere else. The pic below shows an example. Circled in Red, are “part numbers” listed for front differential drain and fill plug gaskets. 41110N and 41110Q respectively. Except when I search those numbers, I get nadda. Nothing. Zilch. Or something completely unrelated. I’ve got to be missing something on how to decipher these numbers. Any help doing so would be greatly appreciated. Thanks!
  2. Mar 10, 2024 at 7:13 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    yeah same happens to me , it happened to me when i was looking for windshield blade.But that happened to me because i didnt want to go to toyota because they charge a lot
  3. Mar 10, 2024 at 8:06 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Former Toyota parts guy here... The prefix numbers in the pics, get you to what you are looking for. Then you go to the prefix number (first set of numbers) in the fische, online, catalog, and look up the correct suffix (second set of numbers), for your vehicle application. for Toyota (and most Asian Mfgr's) the first 5 digits are the part on the car. IE: 53301 is a hood, 53801 is a fender, 52119 is a front bumper fascia, 52159 is a rear bumper fascia etc... The second set of numbers is the base auto they fit. IE: 35070 Tacoma, 16010 Corolla... ect... If there is a third set of numbers, at the end, it is usually a 2 digit code, and it is for in color items, trim, mouldings. ect...
    I hope this helps. Ski
    Blak Shinobi, Chew and KY_Rob[OP] like this.
  4. Mar 10, 2024 at 8:10 AM
    skidooboy
    central lower mich
    In the above circled items, the 41110Q is what appears the lower diff drain seal prefix. then you go to that number in the catalog, and find the rest of the number. The same with the 41110N but, that appears to be the fill/level check hole seal. You need the full number, to get the full Toyota part number, to search online for the correct part you are looking to buy. Ski
    KY_Rob[OP] likes this.
  5. Mar 10, 2024 at 8:32 AM
    KY_Rob
    Rob
    North East Ohio
    Kinda, sorta…not really. Thanks for trying though. Probably need to have access to more than just the parts website is what I’m gathering.
  6. Mar 10, 2024 at 9:39 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Rockauto has a reference to oem part# for most parts
