decent tires that have raised white lettering
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tehkoema, Jan 20, 2018.
  1. Jan 20, 2018 at 8:58 AM
    MTSN
    MTSN Well-Known Member
    Denver
    17 Tacoma TRD Off Road
    Yes I agree it's all in the experience. I happen to have a lot of experience with KO2s - I've had them on a 100 series Land Cruiser, 200 series Land Cruiser, a JKUR, and now my daily driver which is also a 200 series. An all terrain will never be the absolute best at any one category, but the KO2 is very good in 90% of conditions from the hot sandy desert in Baja to frozen mountain passes. I've had mine in myriad conditions from muddy and frozen trails, dry boulder/rock gardens, and all kinds of pavement, and they're quiet, long lasting and always perform well. The biggest 2 issues with them IMO is thick mud and icy roads, but it's not a dedicated mud terrain or dedicated snow tire which is to be expected. I'm no BFG fanboy either - I've also recently and been a big fan of the Nitto Ridge Grappler, Duratrac (although I've seen many sidewall failures on rocky trails and howl after 5k miles even when rotated), and Mickey Thompson ATZ P3. Not a huge fan of Toyo AT2s any more with how much tech has improved in AT tires in the last 5 years, and I'd like to try the new Falken Wildpeak AT3 which appears to be the best value on the market right now. I don't run KO2s on my Tacoma, but I ran 37" KO2s on my JKUR and they performed well in some tough conditions:
    R4p6z8NoTpavYh-uk4Rv7Kiv2IhqoJAQWNeWOIfL_22b2c637971c572835b73926dee759d36ad5e62f.jpg
    WmF6CBbyu1pUONOKEKzN2nqZGLi-R9LgIJmhGZ-1_9dcd5237aca7ece30a8459b3e90382a5c570db8a.jpg
    12RT-fVSUlKYWfMVVbzUfzKB4vj7B2XjNuQta8oi_8abb241b87860cba29b1e81fe399e6e865ac4497.jpg
  2. Jan 20, 2018 at 9:01 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Wish I had a reason to buy these. That assymetric tread just looks cool to me but I don’t really wheel the truck so...and they are $$$.2846EFD2-8E63-4A84-A53B-49F1ADD5F19B.jpg
  3. Jan 20, 2018 at 9:03 AM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    The sidewall on the ko2 is way stiffer than the duratrac but the duratrac in the same size is wider on the rim. I had the duratracs on my Tacoma for about two hundred miles then had ko2s put on due to balance issues which turned out to be a problem with the installers rather than the tires. The duratracs looked way better IMO but I'd rather have a more durable sidewall.
  4. Jan 20, 2018 at 9:05 AM
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    You can now get the 285/70 17 in C weighing in at 51lbs which is pretty good.
    Mountain[QUOTED] likes this.
  5. Jan 20, 2018 at 9:30 AM
    2010tacoma2tr
    2010tacoma2tr Well-Known Member
    Now THAT is a cool story bro..
    I had them and hated them. Moved to the Duratrac and never looked back.
    I am currently running the AT3's (SL) and they are holding up good. Haven't been on the trail with them, just snow and ice so far.
  6. Jan 20, 2018 at 9:40 AM
    NM Lance
    NM Lance Well-Known Member
    They are excellent in the snow and mud, but they chunk on loose, jagged surfaces. Hard desert caliche does a number on them. I still like them.
  7. Jan 20, 2018 at 9:42 AM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    I think the E load tires want more weight on them to work best. I stick a 40-60lb bag of sand in the back and haven't had any issues with heavy rain. Before I did that the back end would slip out when accelerating. Mostly that was probably the mold release agent when they were new, but the truck does ride better with the weight back there so I'll leave it until summer.
  8. Jan 20, 2018 at 9:50 AM
    NM Lance
    If you are wanting the solid white raised lettering, your options are pretty much limited to BFG's and maybe one or two lesser-known brands.
    White lettering is such a pain to keep bright though. I have gotten tennis elbow a few times from scrubbing white lettering with a stiff bristle brush and AJAX.
  9. Jan 20, 2018 at 10:56 AM
    Mountain
    Mountain Well-Known Member
    Revelstoke BC
    15 Acess Cab TRD
    I agree they need more weight, more weight than a Tacoma, I usually have between 200-300 lbs in the back. Ive got at least 60,000 km on a set of 265/75/16. I live in the mountains and have used them from Vancouver Island to Quebec. I can say they perform awesome at almost everything, except very wet roads/hydroplaning (puddles on the road that most other tires I've used would cut right through). They are heavy, 54lbs I think. I really wish they made this size in a C load range or less, that would be my perfect tire.
  10. Jan 20, 2018 at 11:17 AM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    I enjoy the BFGoodrich Mud terrains. Get a little hint of tread block hitting road on takeoff and stopping but other than that theyre pretty good. Also theres a good hum from the outside but ive coated my floors a couple times with sound deadening rubberized undercoat so its quite a bit quieter on the inside.IMG_20180107_170023.jpg
  11. Jan 20, 2018 at 11:20 AM
    Alembicguy
    Alembicguy Unconscious and liking it
    Jim
    Hibbing Minnesota
    2018 DCSB TRD Off-road (White)
    Lots of folks hate them because they can't afford them but that's none of my business.
    CruJones33 likes this.
