Decent amber fogs for on road use on a 3rd gen that aren't $400?
Discussion in 'Lighting' started by GawainXR, Sep 19, 2024.
  1. Sep 19, 2024 at 12:31 PM
    GawainXR
    GawainXR [OP] Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    I've been looking for round fog pods that will fit in the OEM fog light spot for a tacoma and have a beam pattern that's safe to use on the road.
    I really like the Baja design squadron-r although I'm hoping there's maybe an equivalent auxbeam offering that's not quite as expensive.
    I want better visibility with my fogs in dusty and snowy conditions but don't want to be the arse hole blinding everyone else.
    The diode dynamics SS3 are a bit more reasonably priced.
    Glenny likes this.
  2. Sep 19, 2024 at 12:38 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
  3. Sep 19, 2024 at 12:39 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Buy the pre-'19 model year trd oem halogen fogs. I don't have the part number offhand. They use an H11 (don't install an H9, they do not have an internal glare cap, instead relying on glare control from the filament by the h11's solid cap material) bulb, compared to the low power, low luminance H16 type fog lamps that come on other models and later years.
    The lens can be tinted by using either kapton tape/sheet (will get you the correct filtration for selective yellow color, is cheap, will hold up to the heat and is easy to peel off and replace if it gets nicked by road debris) or duplicolor metalcast anodize yellow spray paint (2-3 medium coats works well in my experience, and also results in the correct yellow color).
    Diode dynamics SS3 Sports are very good, but they do not run hot enough to keep the lens free of snow/ice buildup in cold weather.
  4. Sep 19, 2024 at 12:40 PM
    Clearwater Bill
    Billy
    Largo Florida
    @memario1214
    Solve this fella's problem. Maybe with a Tgiving sale or something? :D
  5. Sep 19, 2024 at 3:22 PM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Diode dynamics SS3 Sports are very good, but they do not run hot enough to keep the lens free of snow/ice buildup in cold weather.[/QUOTE]
    That's actually a great point and something that I had not considered for snow and freezing rain conditions, I definitely wouldn't want them getting iced up and obstructed.
    The next mods I'm planning are
    - Amber Road Safe Fogs
    - Stealth 32" Light Bar
    - Heated seats and covers (I think clazzio has the single insert dual seat adjustment knob?)
    - Removing my throttle controller and installing an AuxBeam switch unit
    - 12V Anderson connector mounted near bed.
  6. Sep 19, 2024 at 6:16 PM
    Toy_Runner
    99 4Runner SR5
    The <'19 trd fogs, kapton tape and a good set of h11's will definitely come in under budget and work well, then. My DD SS3 Sports work well in rain and fog, but I didn't have them mounted on my winter vehicle. Crash's testing shows they will ice over though
  7. Sep 20, 2024 at 8:09 AM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    drizzoh[QUOTED] likes this.
  8. Sep 20, 2024 at 8:20 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    my DD max fog lights seem to run hot enough for melting snow. at least the few times i have been stuck in it
  9. Sep 20, 2024 at 8:22 PM
    Azrael's Gaze
    Azrael's Gaze Well-Known Member
    Steve-O
    Springfield, Oregon
    2022 Black Tacoma TRD Offroad
    They do make stickers that make it sorta amber for cheap too lol
  10. Sep 20, 2024 at 8:41 PM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    These seem to check every box! Thank you.
  11. Sep 29, 2024 at 8:36 PM
    InThePlains
    InThePlains Well-Known Member
  12. Sep 29, 2024 at 8:40 PM
    Chriswhaaaat
    Chriswhaaaat Well-Known Member
    Alberta, Canada
    2024 Tacoma Trailhunter, 2018 4runner, 1977 FJ45
    Unfortunately you do really get what you pay for with the Taco fogs. I had the DD SS3 Pro’s, less than the elite but more than the sports, and they were outstanding. Probably about 350 US? (Not on sale)
  13. Oct 3, 2024 at 8:22 PM
    assist
    assist Roadside Assistance
    New Hampshire
    2022 Silver TRD S 4X4
  14. Oct 7, 2024 at 4:35 PM
    madpipetter004
    madpipetter004 Member
    2017 SR5 Quicksand Tacoma DCSB
    I also have Morimoto XB Type T fog lights. I got them off of TacomaBeast for $130 (used a promo code to get $20 from the original $150). They have a bright output and extremely easy to install and adjust. They work nicely for me when I'm on dirt trails at night compared to the stock ones. The housing is black and it's a nice aesthetic touch when the fog lights are off.
    Road_Warrior likes this.
  15. Oct 20, 2024 at 4:41 PM
    86_MR2
    86_MR2 Swallow my tranya
    North Chicagoland
    2022 TRD Off Road M/T, Neil Armstrong Edition
    For two years in a row now I've had problems with snow packing into the recess around the fog lights, adhering to the lenses and rendering them useless.
    The DD Max setup is the only LED option that gets hot enough to melt snow. Seems like a super product but, unfortunately, they're too expensive for something I have no need to use on a regular basis. That said, I went retro on the advice of crashnburn80 and found some H11 halogen fogs from the 2016-19 TRD trucks (part #s: 812200802000 812100802000). Vosla selective yellow H11's are the lamp. Total cost of this setup was about $120.
    Winter is coming. I'll report back with results.
    Below is post-aiming. Truck is 25' from the wall.
    Toy_Runner likes this.
  16. Nov 26, 2024 at 9:51 PM
    Light Bar Covers Ultd
    Light Bar Covers Ultd Member
    Ruben
    our amber pod covers go on any pods you got! They are magnetic and interchangeable so you can have amber, yellow, blue, and green! We are having a black friday sale going on now thru Monday 12/2 for 25% off all orders Discount code BLACKFRIDAY check us out www.lightbarcoversunlimited.com
