debating plastidipping my rims...if I hate it or mess it up, how hard is it to remove?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Grimble27, Jul 26, 2023.
  1. Jul 29, 2023 at 8:40 AM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Yeah I took the wheels/tires off (not the tires off the wheels)- it just makes doing them easier. I don't know if I can explain this clearly but will try. I take the blue tape and kind of make it into a little tube around the inside of the hole where the stud comes through. I really doubt if you got plastidip inside the hole it would matter but what I wanted to prevent was the stud maaaybe rubbing the plastidip and lifting it and it starts to come off the wheel - doubtful that would happen but I just wanted to be sure. Plastidip pros know that it will peel off easy and clean along edges and seams which is why it it is so popular - I have found it some spots like skinny window trim pieces for example - sometimes when peeling it off along the edge it will come off the piece you are trying to actually Plastidip - frustrating. In those places I use blue tape the same way I would with paint and before the plastidip is completely dry (give it a few minutes ~5) I peel off the blue tape to get a clean line without pulling off the Plastidip on the piece I want it on. But on wheels and chrome emblems that is not necessary. BTW you can tape off the tire from the wheel but I didn't - the plastidip peeled right off the rubber right along the wheel edge clean.
  2. Jul 29, 2023 at 8:46 AM
    Amorak
    Amorak Well-Known Member
    2021 Magnetic Gray Metallic Tacoma TRD OR DCSB Premium
    Hyperdip is smoother (more factory looking), choice of shine type finish, and supposed to be stronger...
  3. Jul 29, 2023 at 3:52 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Mine are peeling at the skinny part towards the tire. All four rims. Gonna buy a set of trds.
    Windmill[QUOTED] likes this.
  4. Mar 22, 2024 at 10:02 AM
    Hogan1966
    Hogan1966 Well-Known Member
    Kevin
    Loveland, OH
    2021 DCSB TRD OR - Army Green
    Blackout package - planned: black bed logos, black wheel vinyls, front seat window tint, tires.
    Truth...and, if you don't get it done right, they don't last.
  5. Mar 22, 2024 at 11:50 AM
    Csoth7
    Csoth7 Active Member
    2020 TRD PRO
    You can remove it with WD 40 and a pressure washer..EASY
  6. Mar 22, 2024 at 1:34 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Thank You for the Hyperdip info - may try it in the future; everything I have put the Plastic Dip on has pealed! Some I wanted to, some not. In general, no harm was done and easy to get off when wanted.
    Amorak[QUOTED] likes this.
  7. Mar 22, 2024 at 2:04 PM
    Beavis5220
    Beavis5220 Well-Known Member
    anybody do this with the wheel still on the truck??
  8. Mar 22, 2024 at 2:34 PM
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
    I did. i just put some plastic bags behind the wheels when spraying. You can stick playing cards in the tire bead if you're concerned about overspray onto the tires
    Beavis5220[QUOTED] likes this.
  9. Mar 22, 2024 at 2:53 PM
    Beavis5220
  10. Mar 22, 2024 at 3:00 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Update: I sold my O.R. rims with the Plastic Dip still on them. When the buyer bought them from me, we peeled part of one of the rims, and seemed to come off real easy. Now, I kinda wish I peeled them myself and asked more money for them.
  11. Mar 22, 2024 at 3:07 PM
    findbrianhere
    findbrianhere Well-Known Member
    Brian
    Bloomington, IN
    2016 Tacoma TRD Off-Road
    2.5" Old Man EMU Lift Add a Leaf Old Man Upper Control Arms 18" Black Rhino Rims 33" Nitto Grapplers Wescott Designs Rock Sliders Uptop Overland Alpha Cab Warren Synthetic Winch in-bumper Borla Exhaust Nitro 5.29 gears Genesis dual battery Morimoto headlights/taillights Injen Cold Air Intake
    I plastidipped the wheels on my jeep. It was easy to do, and stayed on until I needed new tires. Of course, the tire shop butchered it and I had to peel it off, which was easy, just a bit messy in places. As far as the lug holes, you do have to cover them. If you try to spray in the hole, then screw on the lugs, it will pull the dip and cause lifting. I made that mistake. My solution was to just spray it with the lugnuts covering the holes, but pull them off before it dries. That way it prevents drying and "coating" both the nut and friction area and does allow for the friction area (against the nut) to be dip free, hence no pulling when tightening.
  12. Mar 22, 2024 at 9:06 PM
    AssQuake
    AssQuake Unknown Member
    A.J.
    Washington
    4runner
    Made in Japan
    i didnt read comments above
    I hate plastidip but i found a neat way to remove it from wheels. Soak in WD40 and hit it at medium/far distance with pressure washer but the aftermath is messy and youll be finding plastidip all over your driveway and clogging your gutters. Platidip looks super ugly afterwards when it starts attracting brake dust and dirt. itll look nasty dry and brown.
    Again, i hate plastidip.
  13. Mar 23, 2024 at 7:31 AM
    Edaw33
    Edaw33 Well-Known Member
    2022 TRD Sport SW DCSB
    YouTube dot com
  14. Mar 23, 2024 at 7:38 AM
    boston23
    boston23 Well-Known Member
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    Heard it comes off super easy if you pre soak with wd40 and then just scrub it off
  15. Mar 23, 2024 at 11:29 AM
    #35
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    I have used Plastidip for years - the trick is to take your time with light coats. If you take your time and let it build up it will be very durable. Now that said I never put it on wheels just to black out chrome. The chrome black out on my 2018 Outback has lasted 5 years and it's been though car washes etc.
  16. Apr 1, 2024 at 10:23 AM
    #36
    Carpedm
    Carpedm Well-Known Member
    Annapolis MD
    2023 Lunar Rock TRD Sport DC SB
    Cup Holder Mod, bed cover, and steps.
    Interested in everyone's opinions on using plastidip or finding a vinyl sticker to cut myself in an effort to take the chrome bits on my Sport wheels and turn them bronze... Would anything work well vs spending the money on wheels?
  17. Apr 1, 2024 at 1:14 PM
    #37
    czukie
    czukie Well-Known Member
    Colorado
    ‘23 Tacoma Access Cab
    FWIW they make vinyl “inserts” for the off road wheels to delete the chrome. I have no experience with them, but might be worth considering if you don’t wanna do the spray on route (whether that’s plastidip or alternative)
  18. Apr 1, 2024 at 1:15 PM
    #38
    Carpedm
    Annapolis MD
    I haven't been able to find these in bronze! Definitely to black out.. If someone has seen bronze I am all ears!
