Deaver J66 pack with what shock set up?
Discussion in 'Suspension' started by Matt719, Nov 6, 2013.
  1. Nov 6, 2013 at 8:28 PM
    Matt719
    Matt719 [OP] Active Member
    Placentia, CA
    2007 Prerunner SR5 -under contruction-
    Total Chaos UCA's, Fox 2.5 coilovers w/resi, 4 inch spindle, 1 1/4 inch front wheel spacers, deaver 12 pack (yes 12 it's built up j66) , bilstein 5100's, 285 Faulken wildpeaks, American Eagle Alloy wheels, Flowmaster exhaust
    I am installing my mid travel on saterday and am now wondering how to set up my rear. I used the search button and read through some threads and didn't find a exact answer to my question which is:
    If I want to run a deaver J66 pack (because I want minimal lift) what rear shock do I use? I want to stick with Fox shocks...
    Also I was seeing some guys cutting out the stock top shock mount off the frame and using hoops. Is there a place to order the hoops? I can do all the welding myself if this route suits me best. Also what shocks would I use on this route??
    any info would be very helpful and sorry in advanced for beating the dead horse if this question was already asked and I didn't see it.
    Oh and I have a 2nd gen double cab prerunner if it matters.
  2. Nov 6, 2013 at 8:31 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Here's a great Hoop setup from Pelfrey. I live right next to you in Yorba Linda If you can weld I got some work for you my brother.
  3. Nov 6, 2013 at 8:56 PM
    Matt719
    Placentia, CA
    oh cool Im a stones throw away from Yorba Linda. Im actually a welder/workaholic. Im up to my ears with work, kinda hard to get a day off.
    Anyway is there any other hoops out there for purchase? That set up is really nice but I cant see spending that much just on hoops and I most likely wont be running fancy bumps.
    Anyone have any info on the shock situation? Im pretty set on just running the deavers but don't know what exact Fox shock I will need. I noticed a 1" lift one for direct replacement but will that give me more travel?
    sorry for all the questions im just ready to be schooled with rear set ups
  4. Nov 7, 2013 at 7:10 PM
    Matt719
    Placentia, CA
  5. Nov 7, 2013 at 7:14 PM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    Im on the same boat but running 4'' alpro expos heres my check list:
    "Expedition" Heavy Duty Rear Leaf Springs (Pair) - 4" lift
    2005+ Tacoma rear Brake Lines
    BAMF 2nd Gen 12'' Shock Relocation Kit
    Fox Racing Shox 2.0" 12'' Remote Reservoir 980-02-034
    AllPro 2005+ Tacoma U-Bolt Flip Kit
    Here's the link for the relocation kit and a nice deal on the 12'' fox shock and kit:
    http://www.tacomaworld.com/forum/do...-tacomas-running-pelfry-bamf-shock-mount.html
    http://www.bayareametalfab.com/2nd-Gen-Shock-Relocation-Kit_p_14.html
  6. Nov 7, 2013 at 8:18 PM
    Matt719
    Placentia, CA
    thanks for the reply. Do you happen to have any pics of your rear set up? I went on that site and the pictures don't really show you anything. I want to see how they weld on and all of that. I see your local also are you guys going to all the tacomaworld meets?
  7. Nov 7, 2013 at 8:37 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    I go to almost all of them. Prolly be at tomorrow nights provided someone can pick a place.
  8. Nov 10, 2013 at 1:36 PM
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
    FWIW im running Ford F150 2wd 97-03 Rear shocks on my truck seem to work great with my set up PT#76656 @ NAPA .
  9. Nov 10, 2013 at 1:57 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    If you click the image gallery there is some more pictures.
  10. Nov 15, 2013 at 12:18 AM
    87Tcyota
    87Tcyota Paiza RIder
    Joel
    Whittier, Ca
    01 Lt taco
    Not sure what the best size shock would be but I'm running the j59 pack on my 1st gen and my shocks are limiting down travel.
