Dealer says I need to replace both catalytic converters.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dkelley, Nov 11, 2017.
  1. Nov 11, 2017 at 5:13 AM
    dkelley
    dkelley [OP] Member
    David
    2013 Tacoma PreRunner TRD Sport Double Cab
    Yesterday my check engine and trac off light came on on my 2013 Tacoma with the 4.0. I took it to the dealership and they said that I needed to replace both cats and it would cost $2300. The truck only has 63000 miles on it so I thought it was odd that both cats would already need to be replaced. After I left the delearship I filled up on gas and drove 200 miles. I stopped at the store and when I got back in the truck both lights had went off.
    I haven't noticed any performance issues or bad feel milage. Do you guys think the truck truly needs the cats replaced? I asked the delearship what evidence they had that the cats needed replaced and they said that that was the code it threw. This is hard to believe because in my experience engine codes are fairly vague. Could this had just been a loose gas cap?
    Rambo54 likes this.
  2. Nov 11, 2017 at 5:23 AM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    Might be covered under the 10yr 100k mile emissions warranty.
  3. Nov 11, 2017 at 5:28 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I'd read your warranty as I think the cats are covered by the emissions section of the warranty.
  4. Nov 11, 2017 at 5:33 AM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    I straight piped my Jeep when the cat went bad. Not ideal but it cost about $20 and an hour or so of time. Sounds like yours are fine though.
    Rambo54 likes this.
  5. Nov 11, 2017 at 5:38 AM
    dkelley
    dkelley [OP] Member
    David
    After looking at the warranty, the cats are covered 8 years or 80,000 miles south they should definitely be covered.
    inwood customs and Rambo54 like this.
  6. Nov 11, 2017 at 5:39 AM
    dkelley
    dkelley [OP] Member
    David
    Is it normal for cats to go bad after only 65,000 miles?
  7. Nov 11, 2017 at 5:42 AM
    megillet
    Mark
    Atlanta, GA
    In my opinion, no. But I’m not a mechanic. I’ve also never had to replace any in any vehicle. Personally I would expect them to go at least 150k miles, if not longer.
    Rambo54 likes this.
  8. Nov 11, 2017 at 5:45 AM
    Boyk1182
    Northern Colorado
    I don’t really know, but there are people on this website with 200k and 300k+. I have seen what they say they replaced to get that high and I don’t remember cats being mentioned.
    Rambo54 likes this.
  9. Nov 11, 2017 at 5:48 AM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Like others said cover in warrenty
    Rambo54 likes this.
  10. Nov 11, 2017 at 5:52 AM
    Spintly
    Spintly Well-Known Member
    Greg
    Home of the Groundhog
    85 Single Cab Pickup & 2000 911
    I have 197k on my original cats.
    R0dzilla75 likes this.
  11. Nov 11, 2017 at 5:57 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    No. Catalytic converters go "bad" when they typically get plugged up by excessive fuel due to a skip in the engine or similar issue.
  12. Nov 11, 2017 at 5:57 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Yeah, something's not right there, but even if they are bad they should be covered up to the 80K mark. I would wait until it throws more codes, my guess would be loose gas cap or just a strange sensor anomaly.
    Rambo54 likes this.
  13. Nov 11, 2017 at 5:57 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Do yourself a favor. Get a cheap Bluetooth odb2 adapter and the torque app on Android. Read your own codes, research, fix and clear. You could do aftermarket cats for $100 each and get better flow. Usually o2s throw the code.
    Rambo54 and burlyb like this.
  14. Nov 11, 2017 at 6:02 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    It's fairly uncommon for cats to go at you mileage. Sometimes people will run old gas from their boat or mixed gas in there truck to get rid of it and they can run into problems. Should be covered under the emissions warranty.
  15. Nov 11, 2017 at 6:04 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Why would he do all that when they are under warranty and he could have it done for free?
    Rambo54 and gunn_runner like this.
  16. Nov 11, 2017 at 6:06 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    If the CEL comes back, it sounds like you need to try a different dealer.
    Blockhead and Rambo54 like this.
  17. Nov 11, 2017 at 6:11 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    if the cats have failed this early there is a reason over "normal wear"
    Raw fuel (misfire or faulty injector) or coolant (head gasket, cracked head) will take a catalytic converter out pretty quickly.
    does the vehicle sit and idle for long periods ? is your fuel mileage abnormally low ? loosing coolant mysteriously ? (these are possibilities for an example, not saying this is the cause)
    I do know of one instance where the nuts on the exhaust flange were not tight, the flange would flex ever so slightly, and the ECM picked it up as A/F sensor and or Cat inefficiency replaced the nuts and gaskets, tightened to spec, all is well, 200k on the truck
    just because there is a code doesn't mean that is the actual problem. A faulty thermostat stuck open not allowing the engine to reach operating temp could be the root cause, ECM should pick up on it, but not always.
    Currygoat and vssman like this.
  18. Nov 11, 2017 at 6:20 AM
    dkelley
    dkelley [OP] Member
    David
    I guess I should mention my truck has issues with spark knock when running regular unleaded. Delearship said this was normal, which I found odd, and told me to run premium gas. The knock has went away since switching. Could the spark knock,
    which
    went on for months, have caused the cats to clog? Should I be more worried about the spark knock? I plan to have a TSB performed that is supposed to help with the spark knock.
  19. Nov 11, 2017 at 6:25 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I had the knock issue with mine and did the TSB. I lost about 1mpg which, to me, means the new program added fuel. I'd pressure the dealer to specifically explain why the cats are bad and what caused the condition. As posted above, cats don't go bad by themselves without another issue creating a problem.
  20. Nov 11, 2017 at 7:19 AM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Get a 2nd opinion at an independent shop.
