Dealer refuses to install ecgs bushing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Diamond, Mar 25, 2020.
  1. Mar 25, 2020 at 2:16 PM
    #41
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    What's the warranty period?
  2. Mar 25, 2020 at 2:18 PM
    #42
    Bishop84
    Bishop84 Well-Known Member
    2 years labour, none for parts.
  3. Mar 25, 2020 at 3:53 PM
    #43
    Diamond
    Diamond [OP] Member
    Dave
    2016 Orange tacoma TRD
    Lots of different opinions . To be expected. Again, I had a very clear discussion with the service dept prior to pulling the trigger. It was a clear error on their part where the tech refused to install an aftermarket part and had no prior experience doing it. I was lied to right from the get go , they, "had done many" . Just plain and simply was bull shitted. My time like yours is valuable.Lesson learned. Had a few beers. Not he end of the world.
    Big tall dave and TimC like this.
  4. Mar 25, 2020 at 6:15 PM
    #44
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You are right, he got a yes from a service advisor! Even though OP explained it correctly, I bet the service advisor probably approved it, not knowing a ECGS bearing from a EGR valve to a cabin air filter. Once the mechanic looked at the order, he probably realized what they were talking about.
    P-Dawg and dpippel[QUOTED] like this.
  5. Mar 25, 2020 at 7:36 PM
    #45
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Lots to be said here but what I find alarming is no one has mentioned watching the 2 videos provided on the bushing web page, including the op. If you watch the video, the tech and I believe the designer of the bushing tells you there is a special tool required to remove the bearing. I retired from Autozone, and there is no rental tool to remove that bearing in the car. (edit 1) This is a difficult install and I know Senior Master ASE guys that would walk on the this job. I'm also a Kia and Ford service tech with back shop experience. In my opinion, there is no way to look up "book" time to do the job, either on Mitchel, or Alldata to price the job because it's a "custom" piece. You could estimate and add some fail time to it, but unless you've done the work, you have no idea what time it will take, not to mention the liability. I ain't nobody here. I'm just a old guy who's done some stuff. I always recommend you research the job, the shop, the tech and determine the best way to go. You took a eye operation to a ankle and leg doctor. Just sayin.
    Zim
    Edit 1. There is a inside pilot bearing tool with a slide hammer available, but it won't go that large a diameter. That tool was hand made buy the guy that did the first install.
    Z
  6. Mar 25, 2020 at 8:30 PM
    #46
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    There are plenty of bearing pullers that exist in sizes appropriate for the stock needle bearing. That said, most will cost more than the $45 for the tool ECGS sells for this.
    For example, the Toyota SST (09612-30012) is $130 USD:
    There are of course other blind bearing pullers out there that would easily take care of it as well. The bearing ID is 35mm, and the OD is 40.5mm if anyone is looking for a puller.
    Jeff
    BlkTaco47, SR-71A and Lt. Dangle like this.
  7. Mar 26, 2020 at 6:29 AM
    #47
    Diamond
    Diamond [OP] Member
    Dave
    I am in Hamilton, Ontario just in case there are any local guys with suggestions. Thanks all.
  8. Mar 26, 2020 at 6:43 AM
    #48
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    It's a shame they wasted your time, but if they don't want to do it, you probably don't want them to either.
    jsinnard and msgs350 like this.
  9. Mar 26, 2020 at 6:58 AM
    #49
    BrokeDownSouth
    BrokeDownSouth Well-Known Member
    Chase
    2019 TRD Off Road Super White
    I'm interested.
  10. Mar 26, 2020 at 7:03 AM
    #50
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    How much you getting?
    Zim
  11. Mar 26, 2020 at 7:58 AM
    #51
    Bishop84
    2 hours flat rate, new seal every time unless its backordered. The needle bearing paid the same so we use that labour.
    I'm in igloo land far far away.
    Tacman19[QUOTED] likes this.
  12. Mar 26, 2020 at 8:18 AM
    #52
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    Thanks. Good info. Some folks around here seen to think this is a air filter install paying .3. Lol
    Zim
  13. Mar 26, 2020 at 8:23 AM
    #53
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    Frame sprayed? With that stuff that dries black? I personally would pass on the dealer spray. Fluid film or use something of the equivalent on an annual basis and do the entire undercarriage. The dealer spray dries and cracks and just delays the inevitable rust. FF keeps on protecting
