Dealer over tightened oil filter housing drain plug
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jc75754, Jan 29, 2018.
  1. Jan 29, 2018 at 5:47 PM
    jc75754
    jc75754 [OP] Active Member
    Justin
    North Carolina
    2001 tacoma
    first off I should have just done the last change myself after all the skidplate bolt issues, but I thought hey, it free so I'll make the, do it.
    Took it to a local dealer rather than the normal Boone dealership for oil service and they broke the weld on a fixed skidplate nut and never said boo, I checked it when I got home and gave them up the road for letting me drive off the lot without notifying me.
    Changing the oil today and the oil housing drain plug will not remove and it turns the whole housing. I cannot remove the plug to change the bottom o ring which I don't guess is a big deal unless you remove the plug.
    Looking at replacement housing it will be about 25-30ish to replace, but I think the dealer should replace the whole housing since it is under warranty.
    How big of a stink do I have to make in order to get them to replace the part? What do I have to do to prove that their dealer f up the part?
  2. Jan 29, 2018 at 5:50 PM
    jc75754
    Justin
    North Carolina
    2001 tacoma
    Forgot to mention the tab looked bent and to include pics.
  3. Jan 29, 2018 at 5:54 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Unless you have a really cool dealer I doubt they will cover it, they will just blame you for the canister being screwed up.
    Vbpiper likes this.
  4. Jan 29, 2018 at 5:54 PM
    ANTupLIFE
    ANTupLIFE Well-Known Member
    Anthony
    Chester, VA
    '16 TRD Sport 4x4 DCLB SW
    Had the same problem. One tab was broke and it was extremely tight. Breaker bar did the trick.
    Vbpiper and shakerhood like this.
  5. Jan 29, 2018 at 5:54 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Replace it with the metal one.
    Go get a reimbursement for it at dealer. Plus oil.
    They have the most lowest end techs doing that stuff.
    I had them forget to put a seal back on a drain plug which I supplied Mobil1 once on a car.
    Leaked all over the driveway. That oil is $$$.
    50 dollar certificate for parts, replaced oil and did it right, and they came out and cleaned my driveway lol.
    Had a white Tundra last year that oil was all over the bottom skid and blew back over the chassis from drive home on freeway. Paw prints all over the damm vehicle. I was pissed.
    Inspect your vehicle BEFORE you leave I have learned.
  6. Jan 29, 2018 at 5:56 PM
    joeythetruckguy
    joeythetruckguy Well-Known Member
    Joey
    Orange County, CA
    2017 Metallic Tacoma TRD Off Road
  7. Jan 29, 2018 at 6:14 PM
    jc75754
    Justin
    North Carolina
    2001 tacoma
    That was the type of canister I was looking at. If they will reimburse the cost for that it would be perfect.
    Do you think it would beneficial to call Toyota corporate? Had the tsb for the transmission done fast after that call
  8. Jan 29, 2018 at 6:15 PM
    2016Tacoman
    J
    I would try to handle it at the local level first.
  9. Feb 5, 2018 at 4:31 AM
    16tacoblue
    16tacoblue Well-Known Member
    2016 sport taco
    Colored chrome fenders name plates & tailgate emblem flat black.
    I seen a metal one with a fumoto valve for Taco's on this site some where, not sure where that link is.
  10. Feb 5, 2018 at 4:37 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Haha literally just went through this this past weekend... I was Youtubing how to take a damn oil filter drain off which was pathetic! I thought it might have been counter turned since it wouldn't move. Realized the dealership probably just over tighten and had to dump oil all over my skids and street... stupid new filter housings.
  11. Feb 5, 2018 at 5:38 AM
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    Went with the Baxter spin on adapter and now just use a normal filter. Much better than dealing with the canister. No o-rings to replace ever again.
    Pickupman2007 and 16tacoblue like this.
  12. Feb 5, 2018 at 6:41 AM
    Zoop
    Zoop Well-Known Member
    The other week I had to use a breaker bar to get the canister off! I'm happy my free service is over! DIY is the best way!
  13. Feb 5, 2018 at 6:55 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  14. Feb 5, 2018 at 7:08 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    I replaced mine after the 2nd oil change with an aluminum one and will be coming up on my 25k last service under the 2 year service agreement, but they won’t be changing the oil only rotating the tires and checking fluids..
    16tacoblue likes this.
  15. Feb 5, 2018 at 7:58 AM
    16tacoblue
    2016 sport taco
    thanks splitbolt, at least some of us can research better !! nice !
  16. Feb 5, 2018 at 8:00 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Try an impact wrench, the knocking may help separate it.
    Crom and 2016Tacoman like this.
  17. Feb 5, 2018 at 8:57 AM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    My input:
    - you want free, you get free and will cost you more later.
    - when I see somebody wearing gloves for on oil change as owner it tells me how much experience and how many time has done it.
    - trash that plastic junk canister and get an aluminum one.
    - get a good canister removing tool with 4 contact points.
    - make sure you put oil on the new gasket O rings to prevent them from binding and ripping off.
    - do not over-tight the canister or the bottom plug, in last turn it takes 1/10 turn to go from 0 to tight.
    Taco Addiction and 16tacoblue like this.
  18. Feb 5, 2018 at 9:32 AM
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    does this mean that wearing gloves makes you inexperienced, or the other way around? I could see arguments for both sides.
  19. Feb 5, 2018 at 9:36 AM
    shakerhood
    Southern Ohio
    I wear Nitrile Gloves, tired of years of chemicals and substances getting on my hands.
  20. Feb 5, 2018 at 9:43 AM
    Dacon
    Danny
    Gilbert, Arizona.
    Inexperienced.
    Oil is not going to burn your skin, give you cancer, loose your hair, stain your hand. I use bare hands and get very little on skin if you know how to do it.
    Unless you work as mechanic and under/over cars all day long, I see no need for gloves (unless from heavy leather to protect hand from cuts and scratches). Blue gloves is an indication of somebody that is watching YT videos or the local mechanic and gives it a try.
    When you have changes oils for 30 years in more cars than remember, gloves are an impediment and in the way.
    But then again, I have seen "men" using gloves to put bait on the hook when fishing...
    doannutglaze likes this.
