Dealer Cost For E-Brake Cable Replacement...??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crow Horse, Sep 30, 2020.
  1. Sep 30, 2020 at 4:02 PM
    Crow Horse
    Crow Horse [OP] Well-Known Member
    Central NY
    2012 DCSB TRDOR
    Has anyone had the dealer replace their e-brake cables and if so, what did it cost? Mine just started sticking although wiggling the cable released the e-brake. I watched a very good video on how to replace it but I'm not sure I want to go through all that. I know the cables run about $200+. I'm wondering what they nail me for the labor portion assuming nothing else was wrong.
  2. Sep 30, 2020 at 5:21 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Rock Auto, Raybestos brand is the closest to OEM imo.
    Advance and Auto Zone both had duralast. Don't waste your money.
    The hardest part of the job is taking the brakes apart. Removing the console armrest makes connecting the cables and cable jacket retainers much easier.
    Muddinfun and TnShooter like this.
  3. Oct 1, 2020 at 5:43 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Upon further research, being that wiggling the cable releases the e-brake, I'm guessing that the mechanism inside the drum is hanging up probably due to wear, rust and corrosion. I will have to pull the drum to confirm this. I hate working on drum brakes. Even more so, I despise dealing with rusty bolts. They'll make any job take infinitely longer than it should take.....
  4. Oct 1, 2020 at 8:11 AM
    Muddinfun
    Muddinfun Well-Known Member
    Grab ahold of the cable where it enters the backing plate and wiggle. It’s common for the aluminum fitting at the backing plate to corrode and break. If it’s broke, the cable needs replaced.
    Bishop84 likes this.
  5. Oct 1, 2020 at 8:29 AM
    beaudeen
    beaudeen Active Member
    Ontario, Canada
    2005 trd off road
    Just had both rears replaced last week...parts were from dealer $140 CDN per side. Not sure of the installation cost as it was part of the new rear brakes (drums/shoes/cylinders).
  6. Oct 1, 2020 at 12:46 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    As far as I can see the aluminum fitting isn't broken. Once I get inside I'll see if my suspicion is confirmed...
