Deaf Bonce Arnold or Sylvester + T25 Neo Tweeters
Discussion in '2nd Gen. Tacomas (2005-2015)' started by darkpharaoh666, May 3, 2022.
  1. May 3, 2022 at 4:19 PM
    darkpharaoh666
    darkpharaoh666 [OP] New Member
    Teo
    2015 Silver Tacoma SR5
    HI All,
    I'm new to this forum and I'm hoping I can find my answer with you guys' help, I'm trying to fit either the Arnold or the Sylvester Deaf Bonce Mids and the T25 Neo Super Tweeters on my doors, I have a 2015 Tacoma Access Cab, any of ya'll have done this?
  2. May 3, 2022 at 4:27 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
  3. Jul 15, 2022 at 2:19 PM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    I’m a little late to this thread but I’m in the process of putting 8 inch sylvesters in the front and 6.5s in the rear. I know the 6.5s will fit up front if the adapter is 3/4 inch or thicker but I have to do an inch spacer for my 8s to clear the window when rolled down. I can’t speak for the rears since I have a double cab, but mine passed the test fit just fine.
  4. Jul 9, 2023 at 10:56 PM
    braddahhtyyy
    braddahhtyyy New Member
    Tylise
    2014 Tacoma sport
    @Corny Taco do you have any pictures of your front door speakers, did you make your own speaker adapters or buy? Did you have to trim anything?
    Corny Taco likes this.
  5. Jul 10, 2023 at 7:47 AM
    Corny Taco
    Blake
    I’m still working on deadening my doors, the setup still isn’t installed yet. Started a new career shortly after posting on this thread last year so free time only comes sparingly now. Here are some links to what I’m using.
    Running these 8 inch speaker rings for the fronts. Amazing quality CNC’d ABS plastic. Excellent customer service as well.
    https://soundsgoodstereo.com/produc...aKRLBG7AgcLJTwzKflvmIJNWgVIr3O_RoCMuwQAvD_BwE
    These the AP M81SL 8 inch Deaf Bonce Sylvesters that I’m running in the front.
    https://deafbonce.com/speakers/apocalypse-ap-m81sl
    These are the AP M60SQL 6.5 inch Deaf Bonce Sylvesters that I’m running in the rear. I’m just using cheap metra adapters from Amazon with these but I’ll probably upgrade down the road.
    https://deafbonce.com/speakers/apocalypse-ap-m60sql
    All of the speakers are running on this Skar RP 150.4
    https://www.skaraudio.com/products/rp-150-4ab-car-amplifier
    For Tweets, I have a pair of these Skar SPX-T’s running on head unit power, but I’m picking up another pair soon and running them on an additional small amp.
    https://www.skaraudio.com/products/spx-t-1-inch-component-tweeters
    Regarding trimming, due to the height of the front adapters, I do not have to do any trimming besides cutting the plastic sound funneling ring thingy inside the door cards. You’ll want to do this on any install anyways since foam rings will always be superior. In the picture below, you can zoom in to where the tools are sitting and see where I cut it.
  6. Jul 10, 2023 at 10:25 AM
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
    Are you planning on replacing the speaker grill so the 8's aren't firing into the back of the door panel?
    Corny Taco[QUOTED] likes this.
  7. Jul 11, 2023 at 7:18 AM
    Corny Taco
    Blake
    I thought about this and almost got door pods, but I concluded that the cost and labor to do that outweighed the benefits. Not a lot is being blocked, maybe half an inch on top and bottom at most.
  8. Jul 11, 2023 at 10:09 AM
    gstodd
    2005 2wd base 5-lug
    I was thinking more along the lines of vibration from the sound wave hitting the solid panel. Especially as you went to the effort to deaden the panel. If you/re running a sub as well it shouldn't be too much of a problem though.
  9. Jul 12, 2023 at 8:17 AM
    Corny Taco
    Blake
    Yeah it’s a possibility, but I think that me be excessive about the sound deadening should minimize it. And yes, I’m running a sub with this setup. Skar VXF on a D4S JP23. These haven’t been installed yet either. It’s killing me because I wanna hear it all sooooo bad.
