Deactivating the seatbelt chime
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HawkShot99, Jun 30, 2016.
  1. Jun 30, 2016 at 9:52 PM
    HawkShot99
    HawkShot99 [OP] Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    The seat belt chime in my truck drives me nuts at times, and I have been interested in a reversible, easy DIY way of stopping it.
    I had my seats out of the cab to wash my seat covers, so I decided to do some investigation.
    To accomplish this task, you must understand how a seat belt chimer knows to chime. Inside the seat belt housing there is a plunger that your belt presses in. It actually pretty simple when you look at it. So how do we make this plunger permanently pressed?
    You need to remove your seats to access the seat belt housing
    Using a socket, remove the belt attachment housing from the seat.
    Using a small screw driver push in the tab to allow the sensor to be removed
    You can now slide the sensor out of the large grey housing for the buckle.
    Using your small screw driver push in the tabs to remove the sensor cover.
    I chose to remove the small circuit board to make sure there was no way to damage it.
    Looking at the plunger.....The white part is pushed in by the metal of your buckle. The top left section contains a small magnet that is sensed when in the buckled postion by the circuit board I popped off before.
    Here you can see the plunger pressed in all the way. On the non magnet side of the plunger, figure out how far in the plunger slides.
    Based off your looking at how far the plunger goes, drill a small hole in the outside of the plunger housing.
    Slide a small zip tie through the hole, with the plunger depressed. It will prevent the plunger from moving outward.
    Another view...
    I didn't get a non blurry pic unfortunately, but using a set of wire dikes, cut off the zip tie where it comes out of the housing on the outside. There is no need to actually put the zip tie through its end and tighten. There is not enough room for this, and you basically made a pin through the hole to keep the plunger back.
    Since the zip tie slightly sticks out of the housing I needed to trim a small spot in the side of the housing.
    Slide the plunger back into the seat belt housing, and snap the cover back on.
    Bolt the seat belt housing back on and reinstall your seats.
    My seat belt chimer no longer goes off. Please don't tell me to just wear my seat belt, sometimes people have reasons for not wearing one. For instance I quite often have a gallon water jug on my passenger seat. That is enough weight for the seat to think there is a person and set off the passengers alarm....
    DistortedAxis, TacomaMike37 and 3coma like this.
  2. Jul 1, 2016 at 3:21 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    There are easier ways posted on here that involve just removing the spring. I just disconnected the plug under the seat on my driver side. This does not work on passenger side because it also disables air bag.
  3. Jul 1, 2016 at 3:42 AM
    jmatteau
    jmatteau Well-Known Member
    I just had the dealer disable mine in the cpu at my first service.
    Green Jeans and Naveronski like this.
  4. Jul 1, 2016 at 3:52 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Any way this mod might affect the air bag system?
  5. Jul 1, 2016 at 5:59 AM
    HawkShot99
    Kingston, NY
    I wanted it to be without the dealer. That require me to pay them, and I didn't feel like going there.
  6. Jul 1, 2016 at 6:04 AM
    HawkShot99
    Kingston, NY
    The ways that I saw was have the dealer do it with the computer, or remove the speaker from the dash. I didn't see anything on removing the spring anywhere. My way can be undone with needle nose pliers in a minute.
  7. Jul 1, 2016 at 6:14 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    does the trick with the odometer no longer work on those? ive been chime free since 2011... takes like 15 seconds total.
  8. Jul 1, 2016 at 6:32 AM
    deanooo311
    deanooo311 Well-Known Member
    ryan
    Midland, MI
    15 taco base 4x4 dclb
    OME 885, dakar leaf pack. 265/75r16 duratracs "c". Back up camera. Scan gauge. Husky floor liners. Cal trend canvas seat covers. Topper and tacoma bed mat. Tailgate skin and cap. Differential breather mod. Intermittent wiper switch. Redline hood struts.
    As did I. As I understand it if you ever reset, battery change or something like that, the chime would come back. Would be nice if we could get into program from home and change chime.
  9. Jul 1, 2016 at 7:02 AM
    HawkShot99
    Kingston, NY
    With the odometer? What is that technique?
  10. Jul 1, 2016 at 7:04 AM
    jpneely
    Charleston, SC
  11. Jul 1, 2016 at 7:07 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    It does not work with newer trucks.
    Now it's either Tech Stream, dealer, or janky modding.
  12. Jul 1, 2016 at 7:08 AM
    jpneely
    Charleston, SC
    well shit. good to know. damn kids and their fancy newer cars.
  13. Jul 1, 2016 at 7:13 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I just yanked the buzzer out. Dont have to listen to beeping when I open the door now either
    TAC1 and bluezzy like this.
  14. Jul 1, 2016 at 8:49 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    This my favorite fix! ;)
  15. Jul 1, 2016 at 9:11 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    2012+ are ecu based as far as controls for seatbelt chime.
    the way described above might affect airbag deployment etc. Have the dealer do it or do it yourself.... i can turn mine on or off in about 2 minutes with my laptop
    tomwil and Norton like this.
  16. Jul 1, 2016 at 10:24 AM
    jpneely
    Charleston, SC
    do tell...
    deanooo311 likes this.
  17. Jul 1, 2016 at 10:48 AM
    nd4spdbh
    SoCal
    Laptop with techstream cable, and techstream software.
    Or you can do it with the proper commands over a bluetooth OBD reader + telnet on a laptop / android phone
    Norton likes this.
  18. Jul 1, 2016 at 10:49 AM
    stump jumper
    Bill
    Texas
    mine were jerks and refused to do it. I refuse to go back to them for anything
  19. Jul 1, 2016 at 10:50 AM
    jpneely
    Charleston, SC
    guess ill be looking into this now. cool thanks!
  20. Jul 1, 2016 at 11:30 AM
    HawkShot99
    Kingston, NY
    Doing this makes the truck think the seat is always occupied. How would that effect the air bag? If the truck is driving, I am in the driver seat so its correct....
