Dashboard not reading TPMS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gary K, Apr 12, 2022.
  1. Apr 12, 2022 at 10:47 AM
    Gary K
    Gary K [OP] Well-Known Member
    Gary
    Florida
    2017 White Tacoma
    OV Tune, BakFlip MX4 bed cover, 17 x 9 Fuel Crush rims, 3/2 lift, Meso Custom Interior lights.
    Sensors are working and can be read with a sensor tool. There are no lights on, on the dash. However when I scroll over my diagnostics I have no Air pressure reading, for my tires.
    I have tried the reset button and waited for the three blinks of the warning light, both with the truck running and just in the on position.
    What would cause this and what is the fix???
  2. Apr 12, 2022 at 10:49 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Have you taken it for a drive? My pressure doesnt read sometime until I take a short drive.
  3. Apr 12, 2022 at 10:59 AM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
  4. Apr 12, 2022 at 11:09 AM
    15yrstacoma
    15yrstacoma Member
    ed
    22 sr blk
    none
    pg.jpg Go old school........
      File size:
      5.4 KB
      74
  5. Apr 12, 2022 at 11:43 AM
    Gary K
    Gary
    Florida
    2017 White Tacoma
    Yes I have doesn't make a difference...
  6. Apr 12, 2022 at 11:44 AM
    Gary K
    Gary
    Florida
    2017 White Tacoma
    Thanks, Not sure I understand this though...
  7. Apr 12, 2022 at 11:49 AM
    5nahalf
    Erik
    Minnesota
    So lets start at the beginning. Have you done anything to the truck, or did it just stop working one day?
    eurowner likes this.
  8. Apr 12, 2022 at 12:06 PM
    Gary K
    Gary
    Florida
    2017 White Tacoma
    Did nothing, they just stopped working. I had the tire light come on that said I had a problem. Went to check the display and had 4 lines with no PSI. Checked all the old school way and 1 was low, (had a screw). Got that patched and still nothing, for the display...
  9. Apr 12, 2022 at 12:59 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    After I hold the button down I have to drive for 20-30min for them to show up. If not, you probably have an issue.
  10. Apr 12, 2022 at 1:13 PM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Are you getting dashes for the pressure? That means that the sensors are there, just not reading. You may need to have the sensors scanned and manually entered.
  11. Apr 12, 2022 at 3:19 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    The sensors tend to lose their locating function before anything else. They probably won't auto-locate on their own but like you said they read pressures fine. Either manually program their location or replace them to get the auto-locate functionality back.
  12. Apr 13, 2022 at 6:18 AM
    Gary K
    Gary
    Florida
    2017 White Tacoma
    Well there is definitely a problem, I will try that...
  13. Apr 13, 2022 at 6:19 AM
    Gary K
    Gary
    Florida
    2017 White Tacoma
    I am getting dashes...
  14. Apr 13, 2022 at 6:27 AM
    Sungod
    St Augustine
    I had that issue when I swapped sensors for my new wheels. I deleted what was there, and reloaded the numbers manually and it started working. The sensor IDs are stored in your TPMS ECU. The scanners are supposed to be able to read and load them. It doesn't always work. Techstream is the Toyota app that allows you access to the data. You can either get the techstream software and cable and manually load the sensors yourself or take it to Toyota and have them do it. Or if you happen to be in the Jax area, you can swing by my place.
  15. Apr 13, 2022 at 7:44 AM
    Gary K
    Gary
    Florida
    2017 White Tacoma
    Where are you located?
  16. Apr 13, 2022 at 8:07 AM
    Sungod
    St Augustine
    Near Jax/St Aug
  17. Apr 13, 2022 at 8:42 AM
    Gary K
    Gary
    Florida
    2017 White Tacoma
    Sent you a profile message.
  18. Apr 13, 2022 at 8:49 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    how long of a drive did you try? After hitting the reset button, it takes a certain amount of time for them to report back with the locations and pressures. Hopefully its just as simple as meeting that time requirement.
  19. Apr 13, 2022 at 8:51 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    It's totaled. LOL
  20. Apr 13, 2022 at 8:52 AM
    Off Topic Guy
    Did the shop remove the tire from wheel when doing the patch? They could've broken a sensor, replaced it, but not successfully program the sensor ID to your ECU
